Question about Car Audio & Video
I have a problem with my amp
Ok i have a sony xplod XM-1002HX amp and every time i put power to it the lights come on on the power/ protecter side all of them the offset the thermal and the over current lights are all on. whats the deal with it. im lost help me please.
                                         Bradley Dugan
  • 6 more comments
  • dugan_67 Oct 28, 2007
    yeah they are all green but when i plug my sub up theres nothing no noise or crackling or nothing. its like the lights or on but no ones home. im still lost.
  • dugan_67 Oct 30, 2007
    yes and yes.... still lost
  • dugan_67 Dec 14, 2007
    yes the speakers all work
    but all the lights are on
    is there any way to fix it without costing a fortune
    ok thank helps alot
  • jmhottness Aug 08, 2008
    everytime i hook the power up and put the remote wire on a power sorce it comes up with a thermal light but the main power supply is on what do i do?
  • clu7ch Jan 06, 2009
    im willing to learn if ur willing to direct me in some way of sovling it. i can solder and wat not
I agree
Posted on Feb 03, 2008
  • 631 Answers
Are they all green? If so, that's normal. They go red (or maybe amber?) when the protection circuit detects a problem.
Posted on Oct 25, 2007
  • 2 more comments
  • Perry Babin Oct 29, 2007
    Have you confirmed that you have good signal getting to the amplifier?
    Have you checked the speakers to confirm that they're in good working order.
  • Perry Babin Dec 14, 2007
    It appears that the power supply may have failed in the amplifier.
    The power supply (switching power supply) is used to generate voltage for the amplifier's audio circuits. The LEDs are powered by the B+ input voltage. The switching power supply doesn't have to be working for the lights to be on.
    If the FETs have failed, it can be repaired relatively easily but the repair would require buying the parts, removing the old parts (requires soldering) and installing the replacement parts. It's also possible that there could be other problems that caused the supply to fail. If you're not interested in learning to do this type of work, it may be better to to take it to a repair shop to have it repaired.
Sony xplod amplifier xm-1002hx
It saw a spike on Circuit Board.
Mar 08, 2014 | Car Audio & Video
Sony xm gtx1852 amp new and worked for 1 day now is in protect mode even with nothing hooked up but the remote and power and ground.
meter the power side of the amp. sometimes the amp will go into protect if it doesnt have power. if power and remote and ground are good the amp is probably bad.
Dec 29, 2009 | Sony Xplod XM-1652Z Car Audio Amplifier
Xplod amp will not get off of power protection mode
if the protect light stays on the amp is blown or has flawed components and is only repairable by expirenced sony tech
May 18, 2009 | Sony Xplod XM-554ZR Car Audio Amplifier
Sony xplod amp(XM-1652Z ) power/protect light
if your amp is overheating your sub is needing to much power that the amp doesnt have.
if its cutting out and the red light comes on you need to check the wiring. nothing not even the tinyest speaker wires can be touching.
proper wiring would be your best bet.
but i would upgrade amps.
cheap bang isnt reliable.
Apr 06, 2009 | Sony Xplod XM-1652Z Car Audio Amplifier
Hi i have a 600 watt sony xplod amp model xm-554zr and it recently stopped working. when i turn my car on the amp turns on but only for a sec then the protection light comes on, on the amp and it wont...
sounds like maybe a speaker short, try unhooking your speakers and then powering up your amp, if it then powers up with the speakers unhooked try hooking up each speaker one by one untill the amp goes back into protection and then you have your bad speaker.
Mar 08, 2009 | Sony Xplod XM-554ZR Car Audio Amplifier
Sony Xplod 1000W workign strangely
need a bigger gauge hot wire going to your amp ,maybe a battery cap. amp isnt getting enough power to perform so it cuting out.
Mar 01, 2009 | Sony Xplod XM-1652Z Car Audio Amplifier
My sony xplod 1000w xm-1652z doesnt work anymore
First off, according to the manual, the protect light should be green. That's normal operation. If it is red, that's a problem.
If it does go red, disconnect all of the wiring to the amp except the +12V and ground. Short the remote connection to the +12V to force the amp on. If the protect light still lights red, the issue is inside the amp and will need repair. If the issue goes away, try reconnecting one wire at a time until the protect light goes red again.
Mar 23, 2008 | Sony Xplod XM-554ZR Car Audio Amplifier
Sony xplod xm-554zr amp
try disconecting ur battary for 2 min and try it again
Jan 18, 2008 | Sony Xplod XM-554ZR Car Audio Amplifier
Sony xm-1002hx
If the fuse blows only after the remote voltage is applied, the output transistors have likely failed. Never use a fuse larger than the one recommended by the manufacturer. It can lead to more extensive damage (including damage to the circuit board) which will make the amp much more expensive to repair.
Sep 23, 2007 | Sony XM-1002HX Car Audio Amplifier
Car Audio & Video Logo
903 people viewed this question
Top Car Audio & Video Experts
xxxxxx xxx
Are you a Car Audio and Video Expert? Answer questions, earn points and help others
