Question about LG Vu CU920 Cellular Phone
I have the same problem!!!! I just dropped mine 2 hours ago!!
I dropped mine in a puddle of water like 2 hours ago and it worked for the first 30 min. then i went to use it and it was off. i turned it back on and it showed my pic and everything but the screen didnt work then it said "emergency download" My cousin dropped hers in the toilet a couple of months ago and she tried the rice thing and it never worked. She decided to wrap in a paper towel and put it in a zip lock baggy and checked everyday, it took 8 days for it to come on but it works perfect like it never even got wet!!!! Im doing that now and hopefully in a few days it works!!!! And insurance doesnt cover water damage anyways, if you look behind your battery there is a little white dot well if ur phone got wet now its red!!! Thats how they tell if the phone got wet.
    President:
  • 570 Answers
Http://www.fixya.com/support/r3771170-phone_water_damage
Posted on Dec 31, 2009
How long will it take to cook a 15lb. turkey? From the Utube, I saw 30 minutes at 450
Just cooked a 15 pounder with stuffing wrapped tightly in foil on a rack in a roasting pan at 450 degrees 1/2 hour then dropped to 350 for 4 1/2 hours in a convection oven, the foil keeps the moisture in. Uncover last 1/2 hour for crispy skin
Nov 23, 2017 | Grilling
I was letting the engine run to charge battery after a a jump start when smoke and steam were pouring out. also noticed water puddle under car
You have overheated the engine, check the engine cooling fan operation there is a problem I suspect.
Apr 08, 2017 | 1999 BMW 323 Series
Leaking clear water
Mine did the same thing. I took off the bottome cover (you'll need a tamper-proof hex key) The seam on the bottom of the carafe warmer where the water passes though to heat up to make the coffee had a slight hair-line crack. I tried to order part from Delonghi but they said they wouldn't sell it to me because I was not an authorized dealer. (mumbling) I went to a hardware store and bouth a 2-step adhesive. (you need to make certain that it is heat resistant. (mine was 250f) I applied it according to directions and let it cure for 24 hours. Try to force some of the adhesive into the crack.. It has not leaked in over 30 uses. I checked it and found no deterioration of the adhesive so far. Good luck.
Apr 14, 2012 | DeLonghi Caffe Nabucco BCO70...
I have a Jenn-Air refrigerator, Model JCD2389DE, and in the last two weeks we have noticed water puddling on the floor in front of the "freezer side" door. We thought maybe the water dispenser...
Mine did this a few years ago. I had to call service out to replace the system board. I guess it's a common problem. Something on the board fails and the defrost operation does not work properly, resulting in rapid meltdown of ice build-up and puddles on the floor.
Nov 14, 2010 | Jenn-Air Refrigerators
Propel Dropped in water. Now the screen's blue and green
I put mine in a seal bag of uncooked rice for a day (to absorb the moisture) and then tried this solution and it worked!! Good luck
noavatar_s.gif N1XGamerGod
Rank: Guide
Rating: 78%, 14 votes
Okay heres what you do guys!!! Just happened to me today and I fixed it. Mine was at the bottom of a hottub for 2 days XD.
The power in the phone needs to run out
then, plug the phone up
wait about 30 seconds(download screen should be up and it is charging xD.)
Then Take the battery out and unplug the charge from the phone
Stick the battery back in
Wait about 30 more seconds
Hold down the Red Phone untill it turns on.
FIXED! YAYYYYY!
Aug 14, 2009 | Samsung Propel A767 Cell Phone
Dropped my walkman nwz-b133f in water and it turns off when i turn it on
i dropped mine into water too, and at first I think it's hopeless to cure but i still tried because i just bought it several months ago. i tried to dry it with the hair-dryer for about 15-20 mins. it didn't work well right after but 2 days later, it seemed to be normal again. life still has miracles^^
May 12, 2009 | Sony Walkman NWZ-S616F MP3 Player
Dropped cell in water
well if your phone stills works (making and reciving calls) use it till you get a new one. i dropped mine in the toilete and and work but the screen didnt work. if you have insurance call them.
Oct 28, 2008 | Samsung SGH-t629 Cellular Phone
Flat blade stuck on KA stand mixer
Using one of the bowls, filled it with hot water up to the shaft and where the paddle is hooked up. Using a cotton cloth, wrap it around the paddle and shaft, let it soak for 30 to 40 min. After 30 min, twist the paddle back and forth to loosen up whatever got stuck inside the shaft and paddle. Put a little of mineral oil so that the paddle will be easily remove and it will just slide out from the shaft.
Jul 04, 2008 | Food Mixers
LG Vu CU920 Cellular Phone Logo
205 people viewed this question
Top LG Cell Phones Experts
Computer Repairing
Computer Repairing
Raphael Josiah
Are you a LG Cell Phone Expert? Answer questions, earn points and help others
