Question about Toro Lawn Mower With Toro Power Tools
Broke dr cable on my honda mower
How do i replace the drive cable on my honda mower
HRR2162SDA
The drive belt on my Honda HRT broke. I replaced it and within a few seconds the new belt broke. I know the blades are turning, but I'm wondering if the wheel on the transmission is not turning thus the...
could be rear end is locked up you will have to get another belt try turning wheels by hand if loose see if there are broken bearings anywhere on the drive usally thats the case with the belt bearing goes out and shreds thr belt try those ideals
Jul 30, 2013 | Garden
Belt diagram
see if the wheel is locked up check to see if belt broke or rolled off pulley see if cable didnt brake has to be one of those
Jun 21, 2013 | Husqvarna 7021RH 21Inch 160cc Honda GCV160...
How to replace drive cable on honda hrb 216 tda
Disconnect both ends, attach new cable. Google model number parts for illustration.
May 08, 2013 | Honda Garden
I have a honda mower that was serviced last week.The power drive cable was replaced and now the mower will not roll backwards
to change the cable you need to take apart the drive something was not installed correctly
Apr 12, 2012 | Honda Garden
Cable broke on self propelled 7021r. Is this easy to replace?
Here's a diagram of the mower, I not familiar with the Husqvarna lawnmowers but have replaced many cables from other brands of mowers, should be simple with some basic tools.
http://www.partstree.com/parts/?lc=husqvarna&mn=7021+R+%2896143004600%29+%282009-01%29&dn=90_25_0003
Sep 04, 2011 | Husqvarna 21" Lawn Mower with Honda GCV160...
Broken rear axle on my Honda hydrostatic drive push mower
The last time I had a Honda mower in my repair shop I noticed that Honda doesnt do individual parts on its transmissions for mowers OR tillers.
You can fix this mower...but the transaxles are a bit expensive. Honda mowers do tend to be worth it though.
If the axle broke cleanly maybe someone would weld it back together?
I mean, the wheels dont turn that fast that balance would be an issue right? And I am sure the axle metal is cold rolled steel....which is to say it isnt thin cast material that would resist welding. If you take the transmission out of your mower and just take the parts to a good jobber maybe they would give it a try for 10-20 bucks? Dont expect a guarantee...but, for 20 bucks most shops wont even pick up a mower let alone try to fix it.
If this gives you another couple of years of service that would give you time to consider a replacement mower when the unit needs service again.
Good luck and be careful!
Jun 22, 2010 | Honda Garden
Honda lawn mower wheel drive works, but needs adjustment, how?
Take the covers off the drive,there should be a hollow bolt the cable comes thru, it should have 2 adjustment nuts This lengthens or shorts the cable. There also may be a adjustment on the handle.
Oct 25, 2009 | Garden
Honda HRB 216 self propelled mower Cable Broke for self propelled
there is a panel in front of the gear that completes the curve of the blade path that you can remove with a single bolt on the outside of the mower between the wheel and the deck
Apr 29, 2009 | Garden
Toro Lawn Mower With Toro Power Tools Logo
177 people viewed this question
Top Toro Garden Experts
Jim Parker
Jim Parker
Joseph Mueller
Joseph Mueller
lnbn1975
Are you a Toro Garden Expert? Answer questions, earn points and help others
