Question about Sansui DTV2760 27" TV
3inches black line
On the left side of the tv a black line about 3inches wide from top to bottom, and i can't bring up the menu,display and tv channel what can i do?
    Problem Solver:
  • 8 Answers
Even though we are at a level of technology where most things can be addressed by a button on a remote or through a menu there still comes the time when we need to think back when we used to adjust TVs manually. It sounds like this is an analog TV and it is possible there are pots or potentiometers on the rear of the TV at the bottom. If you have children, they love to turn things and it may just be if they are there they need to be set to default. Typically a bad tube will give different symptoms, however, depending on the age of the TV there are some that have circuit boards that will effect the display on a good tube. Not to many symptoms given on this one other than what you describe as "the problem"
Posted on Jun 04, 2009
Some channels are not full screen black top and bottom
that is because the movie or video is formatted for wide screen.
Feb 22, 2015 | LG Televison & Video
Youtube on my vizio 470i tv is off centered
CHANGING THE SCREEN ASPECT RATIO: ( From Manual )
The TV can display images in four different modes: Wide, Zoom, Panoramic, and Normal. Each mode displays the picture differently. To change the screen aspect ratio:
1. Press the MENU button on the remote.
2. Use the Arrow buttons to highlight the Wide icon. Press OK.
3. Use the Arrow buttons to highlight your desired screen mode and press OK:
• Normal preserves the content's original aspect ratio. Since the 4:3 aspect ratio is not large enough to fill the TV's screen, black bars are added to the left and right of the display image.
• Wide stretches a 4:3 aspect ratio picture to the edges of the screen. Since the picture is being stretched, the display image may appear distorted. If the program is already formatted for widescreen viewing (1.85:1 or 2.35:1), then black bars will appear on the top and bottom of the display image.
• Zoom expands images with black bars to fit the screen.
• Panoramic expands the display image to fill the screen.
images may appear wider than intended.
If you are watching widescreen (1.85:1 or 2.35:1) content, black bars will still appear on the top and bottom of the display image. This option is only available when the TV is displaying a 480i/480p source.
Apr 25, 2014 | Vizio Televison & Video
The TV screen is flickering and has a solid Black line about 1/2 cm wide across the bottom
Visit the site named 'Electro-help' for more details. Click this link. View it in "Timeslide" or "Flipcard" option, which can be selected from the drop down box menu by the [Sidebar] tag, at the top left corner of the display window. You can also click the [Home] tab to see the latest updates. It will make search easy. There are more than 1350 posts to different brand TVs now. Pull up older posts there or make a search by type in the brand name of the device in the "Search Box", at the top right of the display window.
Dec 05, 2012 | Samsung HL-P6163W 61" TV
Big black square in middle of screen picture top to bottom about 36 " wide good audio and picture 6" on right and left side displaying.
If you have tried using different input devices, looked for loose contacts
in power outlet, RC Jack, cable and connectors, the TV might need service.
Aug 26, 2012 | Hitachi 55HDS69 55 in. Plasma Television
Black Lines
My Hitachi TV Flat screen 42 EDT 4 1A has a one inch black line from the top to the bottom of the
screen on the left side. What or how do I fix it. I did blow it out with a air compressor as suggested by a local repairman.
Nov 09, 2008 | Hitachi 42EDT41 42 in. HD-Ready Plasma...
Acer 2410 display having 3inches wide black vertical line at the right end
Hi...there,
The problems.. your panel are damaged. Don't bother to replaced...will cost you a lots of $$$.... It's time for retired...
Oct 14, 2008 | Acer Refurbished 11 3 STN LCD DISPLAY **...
Black vertical line 3inches in from the left on my fujitsu PDS4233W-H plasma screen
If the line is all the way from top to bottom, it could be your upper and lower buffer boards or your plasma display unit is bad. I suggest you contact a servicer for your brand.
Apr 01, 2008 | Televison & Video
Got a blue vertical line on me plasma
I had the same problem, a vertical blue line from top to bottom on my samsung TV.
Try this download this http://www.jscreenfix.com/video.php i burned it to a dvd and it fixed it within a minute.
Nov 07, 2007 | Samsung HPN5039 50 in. Plasma HDTV
Screen split with black bar through center, top of picture shows in bottom
It sounds as you desribe, the vertical output IC and or the b+ feed capacitor off the Hi voltage transformer feeding the vert. IC its required voltage. Not a really hard job to replace, but not for a handi person to do. This should be left to the professional, as there are no user serviceable parts inside this set and with the HI voltage and the safety issues its best to call somesone to assist you with this repair. Good Luck
Jun 14, 2006 | Sanyo DS31520 31" TV
Sansui DTV2760 27" TV Logo
62 people viewed this question
Top Sansui Televison & Video Experts
matt martin
matt martin
Electro Med Services...
Are you a Sansui Televison and Video Expert? Answer questions, earn points and help others
