Question about Haier HP42BB 42 in. Plasma TV
Watched dvd now cannot get back to cable tried input
    President:
  • Haier Master
  • 1,779 Answers
If all the other functions work on the tv remote, then turn the tv off, then un-plug it for 10 minutes. Plug it back in and turn it on. If the input button still doesn't work then go into the tv menu and try and change it there. Let me know how it turns out?
Posted on Jun 04, 2009
2 Suggested Answers
  • 8457 Answers
SOURCE: We finished watching a dvd movie with the sony
Unplug,replug the tv about an hour later let the tv reset itself.Go into the tv menu,go to PICTURE go down to reset,this to reset ur tv Tuner signal board back to the factory setting.Those HDMI ports 1 and 2 should work again.Not than,ur Tuner signal board is defective,or the HDMI port 1 is shorted and dead.
Posted on May 31, 2010
Have a 36 inch vizio flat screen it started about four days ago.When i switch from watching a movie on DVd back to regular picture on component 2 no picture is coming up tried chanel 3 an d4 still no...
It sounds like you aren't cycling fully.
It sounds like you are on the TV (RF/Cable) input, then you switch input to Component 1 (for your DVD) and watch the DVD, then hit the input selector again, switching it to Component 2...you need to keep switching the input until you are back on the TV / Cable input.
Jul 11, 2011 | Televison & Video
I have a D-VR7KC2 DVD VIDEO RECORDER. Is there any way to hook it up, so that I can record a channel, while watching another channel? I have a digital cable box. I don't mind only being able to record non...
The short answer is "yes", but it really depends on your TV having more than one input.
You would put a cable splitter (see Google images) on the wire that comes out of the wall. One of the OUT connections would be to the cable box, and the other would go directly to your Toshiba unit.
Depending on the outputs of your cable box, and the inputs of your TV, each unit would be connected to a TV input either by cable or video connections. You would then switch back and forth between the input from the cable box - when you wanted to watch live, digital TV - or the Toshiba when you wanted to set up/watch recordings.
Mar 14, 2011 | Toshiba D-VR4 DVD Recorder/VCR
Connecting samsung dvd to Philips 47PFL6704D LCD TV
Hook up your cables from your DVD player to these input on the back of your TV. 6131e0b.jpg The group of ports should be labeled as video 1 input. Use the Yellow, Red and White on the back of both DVD Player and TV. Then, change the input on the TV remote to input or video 1 to watch the DVD Player.
Sep 28, 2009 | Philips 47PFL6704D LCD TV
Recording cable channels while warching other channels
To be able to watch one, record another, you have to split the cable when it comes into the house. Have one input go directly into the TV and the other into the Cable Box. Then hook the cable box to the DVD, then to the 2nd input of the TV. You will have to switch back & forth from your TV video inputs, rather than switching at either the DVD or Cable Box.
Jan 31, 2009 | Sony RDR-VX521 DVD Recorder/VCR
I cannot record using a DVD/VHS player.
You can record. From antenna to converter box, from converter box to vcr. From vcr to TV.
TV on Channnel 3 VCR on channel 3, and set channel on converter box. Then Record.
Time recording works the same way, but you can set for only one channel at a time. Tht is the only restriction that I have not overcome. The converter box sets the channel. Gee Whizz
Dec 14, 2008 | Philips Magnavox DVD/VCR Dual Player
DVD cables
You have to plug your DVD cables into the "input" connectors on your tv. Input audio and input video. Also there is either a switch on the back of your tv or in your menu where you have to choose "component video". Or it might be labled Video 1, Video 2, Video 3, etc. You might have both a switch on your TV and a choice in your menu. If so, both have to be set to "component Video. Sometimes on the back of your set, the switch is not labeled. It just has "arrowed" lines coming from the different switch positions and leading to the "outputs and inputs" on the back of the set. Set the switch so that the lines lead to the red, blue and green INPUTS on the back of your set. Your problem is not serious. It is just a matter of "telling" your TV that you are using "component video". Component video is when you are using the red, blue, and green inputs. It is also possible that your DVD has another output besides "component out" and also has a switch. Make sure this switch on the back of your DVD is in the "component OUT" position. Your DVD might also have a connector on the back that looks like connectors on the back of VCR's and most TVs. This is an "F" connector and the cable has to be screwed on. It's just like a cable tv cable. Screw a cable into the "out to tv" on the back of your DVD and screw the other end of the cable into the "RF" INPUT (or cable input) connector on the back of your tv. Be sure to look ALL through your TV menu and DVD menu. The DVD sets to "component OUT" and the TV sets to "component IN". Hope this helps.
Keever
Mar 04, 2008 | Zenith Z50PX2D 50 in. Plasma HDTV
Can't get my dvd/vcr to tape and play back
Color codes for A/V cables:
Yellow: Composite Video
Red: Right Audio Channel
White: Left Audio Channel (mono)
Does your TV have a video & audio OUTPUT on the back of the TV?
If so, will need another set of audio/video cables and you need to connect the yellow cable from the video OUTPUT of the TV to the video INPUT (yellow) of the DVD/VCR and connect the Red cable from the right OUTPUT of the TV to the red INPUT of the DVD/VCR. Then connect the white cable from the left OUTPUT of the TV to the white INPUT of the DVD/VCR. If your TV is not in stereo, just connect up the white cable for mono audio.
If your TV set does NOT have audio/video OUTPUTS, then you will still need another set of audio/video cables and connect the yellow cable from the video OUTPUT of the cable box to the yellow video INPUT of the DVD/VCR and connect either the red or white (or both if possible) to the red or white audio INPUTS of the DVD/VCR.
You need two sets of cables because you want to watch DVD's & tapes on your TV (Path #1) and you want to record the TV channel shows back to your DVD/VCR (Path #2).
Please let me know if I can be of further assistance to you.
Good Luck!
- Jim
Feb 21, 2008 | Televison & Video
Hitachi P42H401
Maryann,
You should have an RCA cable connector with your DVD player (three wire connector color coded yellow, red, white). If you plug one end of that into your DVD player (out) and into the input #1 in the back of your TV that should be sufficient. Then just select from the input menu on your Tv to watch that input. You do this by the buttons on the lower left of the TV. One is marked "input/exit". Pressing that button should bring-up your input menu then use "menu/select" button to select input 1 and try playing the DVD...
I do have the owner and service manual if you need it just let me know...
Bill
premtech@willapabay.org
Jan 27, 2008 | Hitachi P42H401 42 in. Plasma HDTV
Can't find a channel to watch a DVD pre-recorded DVD
you should have a input select button on your remote. video 1 should be the front and video 2 should be the back. i had to buy 3 or 4 different universal remotes when mine messed up just to get the one button to change to change it to the inputs because there is no other way to change it to that with he buttons on the tv. kinda surprised that you didn't try and push that button yet.
Aug 31, 2007 | Televison & Video
Having trouble hooking up my DVD player
Try looking on your tv's menu for "input" or "input select". This should allow you to switch to your front AV inputs. If that doesn't work hook into the coaxial cable in the back of the set (the one for your cable or satellite input. Plug the cable from the output or to tv side of your reciever into the input of the dvd player and run another lenghth of coaxial cable from the output of the dvd player to the coaxial input where your satellite or cable was plugged into the back of your set. When you want to watch a DVD just turn on the DVD player and the picture should come up. When you turn it off your satellite or cable should come right back.
Feb 20, 2007 | Durabrand DWT1905 TV
Haier HP42BB 42 in. Plasma TV Logo
230 people viewed this question
Top Haier Televison & Video Experts
Jaime Hernandez
CoppellTVRepair.com
Are you a Haier Televison and Video Expert? Answer questions, earn points and help others
