Question about Whirlpool 24 in. ADP5962 Free-standing Dishwasher
Whirlpool adp5966 fault f6
My dishwasher readout is saying F6 any ideas what the problem is and how tosolve it?
2 Suggested Answers
SOURCE: Whirlpool ADP5966 - flash code 12 and fault on display F6
chech drain pump
Posted on Mar 03, 2008
SOURCE: whirlpool dishwasher fault code f6
get a Maytag
Posted on Sep 05, 2008
0 characters
1 Points
How can I correct a recurrent F6 error?
you may have got a water inlet valve that is faulty, return and exchange.
press the helpful button
Feb 04, 2016 | Whirlpool Dishwashers
F6 code and red star symbol
f6 error is the waterflow to machine if your water is ok then check your flow meter its a bib plastic part on the side of your dishwasher it a common problem with whirlpool
Feb 01, 2014 | Whirlpool 24 in. ADP5966 Free-standing...
Whirlpool dishwasher error code f6e4
F6 error fault code...
This is the Water tap closed. What that means is that the flow meter is not recording water entering the dishwasher, this can be a water tap turned off (suprisingly more common than you'd think, after new flooring or decorating has taken place),water hose kinked or blocked, the dishwasher water soleniod valve defective.
Dec 18, 2013 | Dishwashers
Error F6
Might a problem with the MCU [Motor Control Unit].
Try changing the Motor Control Unit and the wire harness to the motor.
Feb 29, 2012 | Whirlpool Dishwashers
Fault code F6 on whirlpool adp6940. what is it?
Hello there
F6 error code - The dishwasher can't take on water. Check that the water inlet is properly connected, the stop tap valve is open and that water supply is otherwise available to the dishwasher. Also check for kinks or blockages on the water hose. if all is good than you may have a problem with the solinoid valve for the water or the cycle timer may be faulty and the door switch may be bad or not working properly so
you will want them checked for ohms and resistance if they are found bad they need to be replaced
Jan 05, 2011 | Whirlpool 24 in. ADP6940 Dishwasher
Please could you tell me what an F4 fault is on a whirlpool ADP5966 dishwasher please
f4 fault on a whirlpool ADP5966 dishwasher means (1)Not draining or water level sensor not working . there might be blockage in the drainnage . find the blockage and remove the blockage. Other problems can be wiring or problems with the control board. hope this helps pls do let me know
Jun 06, 2010 | Whirlpool Dishwashers
Power Light Flashing - Machine wont Start - Whirlpool ADP5966
this is a fault code. it will flash so many times and then pause.
let me no how many flashes before the pause and i will tell you what fault code it is
Feb 21, 2008 | Whirlpool 24 in. ADP5966 Free-standing...
Whirlpool ADP5966 fault code F8
just choose another prog setting and hold the start button in for a few seconds.
Nov 16, 2006 | Whirlpool 24 in. ADP5966 Free-standing...
Whirlpool 24 in. ADP5962 Free-standing Dishwasher Logo
312 people viewed this question
Top Whirlpool Dishwashers Experts
Mike Cairns
Mike Cairns
Michael Thomas
Michael Thomas
Are you a Whirlpool Dishwasher Expert? Answer questions, earn points and help others
