Question about Saeco Magic De Luxe Espresso Machine
Coffee Grind I have tried to change the grind but the coffee is very weak no matter where I have the wheel.  What is the cause of this!
  • 515 Answers
After you change the grind, how many cup of coffee have you make?
Posted on Jul 14, 2008
How do i fix my esam 3400 coffee grinder quantity?
I have change grinding from 7 to 1 ( it depends from coffee beans) and quality of coffee get much better (knob located inside the bean container).
Mar 09, 2016 | DeLonghi ESAM Coffee Makers & Espresso...
Why are black particles being dispensed into the hot wqter from my Keurig coffee maker? How can this be corrected?
Hello, Irwin -
Those "small gritty black particles" are most likely coffee grounds which are so small they slip into the hot water and eventually the brewed coffee.
The grind size of your coffee may be too fine. Drip coffee method coffee makers, including the Keurig, require medium or medium-fine grind coffee.
Source of information:
Coffee Grind Size: Why It Matters and What You Should be Using, by Taylor Martin, December 22, 2015
CNET Best Products
https://www.cnet.com/how-to/coffee-grind-size-why-it-matters-and-what-you-should-be-using/
You may wish to check your coffee maker to determine if coffee grounds leaked into the space between the k-cup and the k-cup holder:
https://www.youtube.com/watch?v=jZrQhlQpLbs
Best wishes.
Mar 12, 2012 | Coffee Makers & Espresso Machines
My gaggia titanium is dispensing very weak coffee. No idea why. Have tried different beans. No change.
try a finer grind coffee , you cant use a "store" grind in a cappuccino machine it requires a much finer grind than that
Dec 07, 2011 | Gaggia Titanium Espresso Machine
Too coarse a grind
have you tried adjusting anti-clockwise whilst grinder is in operation ?
Nov 11, 2011 | Jura Capresso Jura Ena 5 2Cup Coffee Maker
My Rancilio Silvia, about three years old, does not seem to be generating sufficient pressure. Standard espresso grind requires about two minutes for a shot and coffee is bitter. Is there any way to...
First things first, remove the screw and shower in the head and clean. Then change grind to something a little coarser, since we are testing the machine we will not tamp the coffee(we are doing this to have a constant in our coffee brewing equation). Note how long it took to brew, if it brewed longer than 40 secs, then adjust grind and try again. If coffee shots looks better and taste better then we are on the right track, we are looking for any thing between 15 and 30 sec depending on the coffee blend from light to dark. If you are getting the same results over 40 secs for a shot no matter what grind you use then the pump needs to be replaced.
Nov 28, 2010 | Rancilio Silvia Espresso Machine
Coffee is too weak
I just spoke to someone at customer service. My coffee has been weak and kind of thin. We had the Superautomatica by Saceo for years and I remembered the coffee being richer.
Anyway! The person suggested that I adjust the grind but slowly. So set it to the coarsest setting, brew 2-3 cups. Then put it to the 2nd-coarsest setting, brew 2-3 cups. To the third, brew 2-3 cups. To the forth, brew 2-3 cups. Etc. Until you're at the finest grind setting. Again, brew 2-3 cups. An awfully sensitive machine. It seems to have worked although the last few seconds of brewing continue to be a kind of milky colour (as opposed to a deep black coffee colour). You can, though, press the "cup" button to stop the brew. So once, it starts running milky, you can stop the cycle.
I hope this helps. I know I've been struggling and cursing the machine for a while :)
Dec 30, 2009 | Saeco Odea Giro Plus Coffee Maker
How can I ajust my machine the coffee is coming out weak and watery I don't get that creamy,strong coffee anymore
HI
There are more than a few things that can cause weak coffee.
Grind is too coarse. It should look like coarse sugar.
You cleaned the brew unit and left a part out or put it in incorrectly.
Grind adjustment is set too high. Turn to a lower # while the grinder is operating.
Grinder is been taken apart and not put back together correctly.
Grinder is broken and the grinds are just big chunks.
Oct 23, 2009 | Spidem Trevi Digital Coffee Maker,...
Saeco Magic De Luxe Espresso Machine Logo
96 people viewed this question
Top Saeco Coffee Makers & Espresso Machines Experts
eyecam
Marvin
Marvin
Are you a Saeco Coffee Maker and Espresso Machine Expert? Answer questions, earn points and help others
