Question about Linksys Wireless-G WRT54G Router
No internet connection to main computer when router connected
I have had my linksys WRT54G for a little over a year and for some reason i have no internet connection to my main computer when i plug the internet into the router, but i have connection when the router isnt connected
    Novelist:
  • 79 Answers
I am going to go for the most simple solution first.
This will depend upon your type of internet connection:
If this is a Cable Internt connection, typically you must restart the modem
in order for it to recognize the router.
If this is DSL, you must enter your DSL connection information into the WRT54G configuration.
While this is not as likely, either of these may, depending upon carrier, be linked to the specific MAC address of your computer. The Linksys WRT54G has the option of putting that MAC address into it's configuration so it can 'imitate' your computer.
For a definition, see: MAC address - Wikipedia, the free encyclopedia
If none of this works, post a comment & we'll try again.
Good Luck!
Posted on Jun 04, 2009
    President:
  • 2,187 Answers
If you are getting lights on the Internet LED. Go to the router's setup page 192.168.1.1 and put in your username and your password if you are on DSL. For cable connection try to reset your router by resetting the router
I want to connect a Scientific-Atlanta WebSTAR 2000 series Cable Modem to a Linksys Wireless-G WRT54G wireless router but the linksys doesnt detect the modem and the computer wont let the setup program for...
Most Cable Internet Service Providers (ISPs) use Media Access Control (MAC) Address authentication to establish Internet connection for end-users. MAC address is a unique identifier assigned to the network adapter/s of the computer.
To set up your Linksys router to work with a Cable ISP, you have to enable the MAC Clone feature of the router. MAC Cloning is a procedure which enables a router to copy the MAC address of the computer that's registered with the ISP.
To setup a Linksys router with Cable connection you need to perform four steps using the computer that's been registered with the ISP:
i. Verifying Internet Connection
ii. Connecting Devices Together
iii. Checking the Router's LEDs
iv. Configuring a Linksys Router for a Cable Internet Connection
If you need more help come back.Post / thumbs / testimonial are welcome!
Nov 19, 2010 | Linksys Wireless-G WRT54G Router
I HAVE A WRT54G. I AM DROPPING MY WILDBLUE SATELLITE INTERNET SERVICE BECAUSE MY DIAUP IS FASTER AND MUCH CHEAPER. I WANT TO RUN THE NEW PHONE LINE TO A PC WHICH HAS A PHONE MODEM AND AN ETHERNET PORT. CAN...
The answer that he gave you is not accurate. In fact you can use your wireless over dial-up. This however takes a little work. You will need to setup internet connection sharing on your desktop with the modem. If you can get the sharing working, then you can use your ethernet card on your PC to transfer the internet back to your wireless router.
This will work, it has been a few years since I have done it, but I used it this way for several years.
Feb 01, 2010 | Linksys Wireless-G WRT54G Router
Laptop says no internet connection
First you need to ensure proper connection and filtering. Make sure the source cable is plugged into the Linksys router first. Direct connections must be made to the router, meaning the cable to your main computer should come from the router, not the main source.
Next make sure that the connection is made. You should see a light on the router indicating proper internet connection. Once this is accomplished, connect your main computer and you should have access to the internet on it.
Now comes the easy but somewhat tricky part (tricky only because icons can vary a little). If you haven't already done so, run the setup disk for Linksys. It's has simple, easy-to-follow instructions to set up your network. Now for the laptop. On the blue bar at the bottom of the laptop screen there should be an icon indicating internet connection. Click on that icon to show available wireless networks. Most likely your Linksys router will show up as a secure network. When you click on that connection it will ask you for a WEP key. That key is usually a 10 digit alpha-numeric key written on the back of the router. Sometimes it's on the box the router came in. Sometimes it requests a 12 digit WEP key, in which case simply add two zeros to the front of that same key. If you set up a password for your wireless network you will need that as well.
NOTE: if you have neighbors close, you should always secure your network with a password.
You may need to shut down and restart the laptop in order for the changes to take place.
It sounds confusing, but once you start you'll find that it's actually fairly straight forward. I hope this helps. Good luck!
Jan 12, 2010 | Linksys Wireless-G WRT54GS Router...
Can connect to internet directly through modem. When connected through Linksys WRT54GS router, all lights are ok on both modem and Linksys--including internet. (Have had this router for 2 years...no...
As last resort you might want to use a JTAG cable and debricking programming software. If your router is brikced or you want to change the firmware this cable can do it. The cable will connect to your parallel port and your wireless router so you can repair your router. They are about $5.95.
Jan 11, 2010 | Linksys Wireless-G WRT54G Router
Linksys WRT54G Wireless Router Issue Allows 1 Computer at a time
Your router my not be DCHP enabled or it might not be assigning the IP addresses either.
I would do a reset and start all over with your security settings and see if that works. Worst case scenario you could always turn security off when your parents or others are there.
Link HERE for more Linksys information
pls rate 4 stars
Dec 01, 2009 | Linksys Wireless-G WRT54G Router
Need to connect my old Linksys modem to a new Motorola SBV5121 cable modem.
THE MAIN LINE GOES INTO THE WAN PORT FROM THE MODEM PROVIDED FROM YOUR MOTOROLA .....THEN THE 4 PORTS ARE TO CONNECT THE COMPUTER ....HAVE FUN
Jun 02, 2009 | Linksys Wireless-G WRT54G Router
Linksys Wireless-G WRT54G not connected to internet.
YOU NEED TO CALL THE 800 # FOR LINKSYS AND THEY WILL CONFIGURE THE ROUTER WITH YOU FOR FREE OVER THE PHONE JUST HAVE PATIENCE THE TECHS ARE INDIAN.
Jan 23, 2009 | Linksys Wireless-G WRT54G Router
Linksys Wireless-G WRT54G Ver6
Try reconfiguring the Linksys router. Click on this link for instructions on how to configure the router with a cable Internet connection.
http://www3.nohold.net/noHoldCust56/Prod_6/KnowledgePortal/KPScripts/amsviewer.asp?docid=4da24a60bfc84fe9ad65ce672b4b8b52_KB3686_EN_070208_v1.xml&amsstatsid=4067617
After configuring the router and if you already have an Internet connection, then connect your second computer to any numbered port of the router (port 1,2,3, or 4) and test the Internet connection.
Configure the wireless settings of the router by following the steps on this link.
http://www3.nohold.net/noHoldCust56/Prod_6/KnowledgePortal/KPScripts/amsviewer.asp?docid=2f99c35863934424a932742692a5e83b_KB4024_EN_070329_v1.xml&amsstatsid=4067626
If you want to have a wireless security for your network, you may clck on this link for instructions.
Then try connecting your wireless computer to the name of your wireless network and enter the security key (if you have created one).
Sep 08, 2008 | Linksys Wireless-G WRT54G Router
Hooking up wireless linksys
From ethernet of embarq plug it to the Internet port of Linksys. Your PC should be connected to port 1 of Linksys
Aug 17, 2008 | Linksys Wireless-G WRT54G Router
Linksys Wireless-G WRT54G Router Logo
256 people viewed this question
Top Linksys Computers & Internet Experts
Prashant M
Prashant M
Michael Galve
Michael Galve
Are you a Linksys Computer and Internet Expert? Answer questions, earn points and help others
