Question about Sony Mavica MVC-FD87 Digital Camera
WHEN INSERT THE DISK SAY IT C-13 FORMAT ERROR
  • 23 Answers
Hello!
The disk drive is failing and you need the drive replaced.
We do service the camera model you mentioned and the standard cost to Replace the drive, Clean, Lube, Repair and Adjust all functions to meet manufacturers specifications is $169.00 plus return shipping.
All repairs have a SIX MONTH WARRANTY!
Include a copy of this reply and
receive a 5% INTERNET discount on your repair!!
Bring it in, or
Pack your equipment securely and insure it properly.
Send it to:
Southern Photo Technical Service
37 NE 167th Street
N. Miami Beach, Florida 33162
305-653-7355
Posted on Jun 04, 2009
  • sp-ts Jun 04, 2009
    Hello!
    Bring it in, or
    Send it to:
    37 NE 167th Street
    305-653-7355
When I switch it on, I get this error: Memory Stick error C 13:01 camera Sony cyber shot DSC-P73
Hello and Welcome to Fixya
C:13:01 memory stick error message indicates a Self diagnostic message.In C:13:01 the issue may be with the Internal Memory or with the Memory Stick.
To solve it try the following solutions
Format error with the Internal Memory which can be corrected by formatting the Internal Memory.
If it is issue with memory stick then turning the power off and on again or taking out and inserting the "Memory Stick" several times may help in resolving the issue. Error may be because of Unformatted "Memory Stick" which can be resolved by formatting the Memory Stick in the Camera If it not remove by formatting in the camera then connect it to PC and tried to format it again but either FAT instead of FAT32 which is the regular format and then reinserted the memory stick and formatted it with the camara. Now it will be solved if it still exist then it means Memory Stick is broken or not compatible which can be resolved by inserting a new compatible Memory stick
I hope it will help you
Your Rating as Four Thumbs which are given below to this solution will appreciate me
Thanks
Mar 02, 2011 | Sony Cyber-Shot DSC-P73 Digital Camera
Internal memory formatting error to sony DSC-T2 camera error c:13:01
In DSCT2 Camera, the C:13:01 error message indicates a Self diagnostic message. This message can be clearly identified by the help of a Sony Authorized service technician. Each of these codes indicates the symptoms and resolutions of the Camera. In C:13:01, the issue is with the Internal Memory or with the Memory Stick.
The Symptoms are:
1. Format error with the Internal Memory which can be corrected by formatting the Internal Memory.
2. Unformatted "Memory Stick Duo" which can be resolved by formatting the MS in the Camera.
3. "Memory Stick Duo" is broken or not compatible which can be resolved by inserting a new compatible MS.
4. There may be an issue with the Hardware part also, which can be resolved by the technicians.
Try turning the power off and on again, or taking out and inserting the "Memory Stick Duo" several times may also help in resolving the issue.
Thanks.
Oct 21, 2010 | Sony Cyber-Shot DSC-T5 Digital Camera
Dvd does not show what was recorded from my sony camcorder error message C13:02 flashing
This is Disc Access Error, Disk Access Error, Check disc error, Check disk, C error unreadable, disc error code 13, disk error code c1302, c:13:O2 DISC ERROR, Disc Error C:13:02 message Sony mini dvd finalize error code C1302 DVD not finalised, Rec Disabled Record Disable after dropping the camera, DVD not finalized, DVD Disc not finalized, DVD Disk not finalized, DVD Disc not finalised, DVD Disk not finalised, Disc won't finalize, Disk won't finalise DVD Disc Error, DVD Disk Error, DVD Disc Format Error, DVD Disk Format Error, Rec. Disable, not correct disk, the disk in drive is not formatted do you want to format it now.
Nov 15, 2009 | Motorcycles
Sony camera formatting disk error C:13:01 need to retrieve photos
Preformat : By Fix-shad0w
#1
Insert your memory card into your computer's reader if you have one. If not, you can purchase a multi-format USB Memory Card reader from Amazon.com or Buy.com
#2
Open up 'My Computer'. You should see it under the list of available drives.
#3
Check its contents first to make sure that you have the right drive.
#4
In 'My Computer', right-click on the drive and choose 'Format'.
#5
Leave all the options as they are and click on 'Start'. This is a non-reversible process so make sure this is what you truly wanted to do in the first place.
#6
Once the process is completed, take the memory card out and insert it into your Digital Camera or any other device. Try to browse to it to make sure it works fine now.
With A USB , CELLPHONE , Camera The SameThing
Nov 15, 2009 | Sony Cyber-Shot DSC-P9 Digital Camera
PLEASE INSERT A DISK INTO DRIVE(H): (pendrive problem)
1)I cannot format the pendrive. 2)when i double click on the removable disk,it says ''Please insert a disk into Drive E :'' 3)i used a pendrive format utility but the problem persists again. 4)i tried to format it using gnome also )I cannot format the pendrive. 2)when i double click on the removable disk,it says ''Please insert a disk into Drive E :'' 3)i used a pendrive format utility but the problem persists again. 4)i tried to format it using gnome also
Feb 13, 2009 | Sony 8GB Micro Drive (SUD8G) -24419 USB...
Trying to find out what code c:13:01
The problem has nothing to do with the type or quality of the formatting. It is directly related to the disk drive malignment pandemic of Sony Mavica cameras. It seems simple enough to fix, since I fixed my own. You need to unscrew and remove all the small black screws which go around the seam of the camera body (my model was a MVC FD90) Look for little black arrows indicating the screw locations (you need a precision philips screwdriver which can be purchased at the Home Depot for $5.00 under Husky brand name). After removing all screws, try the camera now and see if it works. If it does, then reinstall only 2 screws in any of the holes that appear perfectly aligned with the camera body (hole lines up perfectly between cover holes and camera body holes). Then try again to make sure it still works. If it still doesn't work, then carefully remove camera cover with caution not to damage wire ribbon connection both halves of camera body. Then simply reinstall top with bottom of camera halves. Next,install those 2 screws previously mentioned. Camera should work fine at that point, and floppy disks will now operate when inserted without error message or other malfunctions associated with drive misalignment.
jwassmer@ptd.net
Nov 20, 2008 | Sony Mavica MVC-FD90 Digital Camera
Disk error 13:02
SONY C:13:01 ERROR
1. cleaning the laser lens with isopropilic alcohol and q-tip
2. Try the reset button on the bottom of the camera. Tilt your camera and look below the LCD Display Backlight button on the bottom edge of the curved portion of the camera. You will need a paperclip or tip of a ball point pen to push the recessed little button. Place the camera on a level surface and try again. We find that the camera is very sensitive to tilting, as it gets older.
3. Make sure you format format at was FAT not fat32
4. All you need to do is "Quick format" the disk with the CAMERA rather than the memry stick plugged into the computer drive.
5. For sony error c:1301 using mini cd's: there is a program that recovers data from cd's that works with disk that have this error. It called "cdroller" Homepage is : www.cdroller.com
6. just take the memory stick off and re-insert it lot of times.. just keep doing it.
Feb 20, 2008 | Sony Handycam DCR-DVD92 DVD Camcorder
Format error C:13:01
Mar 26, 2007 | Sony Mavica MVC-CD400 Digital Camera
Looking for advise & help....................
Replace the floppy Disk, we can supply this Disk.
Nov 26, 2006 | Sony Mavica MVC-FD75 Digital Camera
Sony Mavica MVC-FD87 Digital Camera Logo
121 people viewed this question
Top Sony Cameras Experts
james laughton
james laughton
JonSnell Electronic
JonSnell Electronic
Are you a Sony Camera Expert? Answer questions, earn points and help others
