Question about Kitchen Appliances - Others
Bread not rising enough
Panasonic breadmaker: Bread is not rising as it used to. Changed the yeast, given it a longer program(French bread instead of rapid) but loaf still comes out half the size it used to. Is the thermostat going?
  • 3 more comments
  • Anonymous Jan 10, 2008
    bread used to be perfect. lately it is small and doesn't rise enough and smells burnt while cooking.
  • Anonymous Jul 08, 2008
    Bread used to rise beautifully, but last few times it is only 2/3 of its normal size. I purchased two new bottles of bread machine yeast and even increased the amount of yeast in each loaf and the bread hasn't been rising to its normal capacity. I also noticed that at times there is just a small area in the loaf that is not fully baked and there seems to be some large sized air holes in some places in the loaf. The bread has still remained edible but rather heavy in texture. Hope the problem can be easily solved because I love the bread the machine used to make and really miss having freshly baked homemade bread.
  • demerest Jul 11, 2008
    the heat cycle thay incubates the yeast doesn't appear to be functioning.how to repair it?
  • maria62 Nov 23, 2008
    panasonic bread maker. bread not rising enough, changed yeast to no avail.
  • ljgaz Dec 19, 2008
    i have the same problem, pls help me find a solution
We had exactly the same problem. We contacted Panasonic who supplied bogus "advice" about changing the type of flour and using more water. We eventually discovered the reason for the problems: the mixing paddle was now a loose fit to the spindle. Part way through the baking process it would stick. We also have a solution. You jam tin foil in the gap between the spindle and the paddle, it works a treat. Don't waste you money on a new paddle, this won't be a tight enough fit.
Posted on Jan 17, 2009
White bread not rising
A couple of ideas. Firstly get fresh yeast, I use active dry yeast from the bulk barn, it is way cheaper than "breadmaker yeast" and I use a bit more. When I want more rise to my bread, I add an egg, which works wonders.
Aug 30, 2012 | Black & Decker Bread Machine
Every time I make a loaf of bread it overflows the pan and pushes the lid up. I have followed the recipe in the book that came with the machine. What am i doing wrong?
You're using a fast-acting type of yeast instead of the standard active dry yeast. It's a very common mistake made even more common by the erroneous bread machine recipe writers.
Here are the rules concerning bread machines and the yeasts they love the most:
Use standard active dry yeast for all your standard-rise bread recipes.
For the fast-bake white bread recipes use only fast-acting dry yeast.
Fast-bake type mode selections are available on most newer models and the custom recipes provided in their instruction manuals are the only ones you should use. You should never experiment with recipe ingredients and their portions when using the fast-bake mode on any breadmaker.
P.S. Always refrigerate your yeast with a close eye on the expiration date.
When using grocery-bought bread mixes always substitute the yeast packet provided with fresh active dry yeast. Tip: A packet (or "sachet") of standard active dry yeast contains 2-1/4 teaspoons.
Hope this helps.
Jun 22, 2011 | Black & Decker B2250 Bread Machine
Bread does not rise enough I have carefully measured ingredients use rapid bake setting fleichmans rapid rise yeast checked water temp still having problems I have tried 4 times regular and rapid rise and...
A few tips.
The yeast must be absolutely fresh, use sachets instead of packets.
Keep yeast well away from the fats and liquids.
The fast rise setting will produce less rise than the full program.
You must only use strong bread flour.
Open lid immediately beep sounds.
Jan 10, 2011 | Panasonic SD-YD250 Bread Maker
Our bread has not been rising, and so it comes out sort of hard and misshapen. We've been using the rapid course, and have been adjusting the amount of rapid rise yeast
The rapid rise will not produce as good a texture of bread as the normal full program. Never let the yeast come into contact with liquids or fats in the pan. It must stay dry.
Dec 15, 2010 | Breadman Pro Dual Bread Maker
New machine yesterday. Made a loaf-didnot rise. New yeast was used. Decided to get more yeast today. Made the recipe for Herbed French Bread- the recipe is in the book that came from the machine....it did...
please tell me what kind of flour you are using....in other words what does it say on the bag....does it say "all-purpose flour" or "bleached bread flour" etc..etc....let's start there.
Nov 28, 2010 | Black & Decker Bread Machine
With the 5838 the bread looks good till the bake cycle as than the bread falls about halh an inch
Accurate measured ingredients, fresh and best ingredients (especially yeast and flour), warm liquid (110 degrees), use peanut oil instead of butter (raises well and stays fresh longer), pkg. Rapid Rise yeast is same as bottled bread machine yeast and is always fresher (1 pkg equals 2 1/4 tsp.so use jarred yeast for odd amounts, ie. 5 tsp=2 pkgs + 1/2 tsp from jar). Wheat bread will rise good and drop a little but stays good for slicing. Oster's pan is too large so I cut loaf in half length ways for smaller and easy to slice pieces.
Aug 18, 2010 | Oster 5838 ExpressBake Bread Maker
Dough will not rise
I have run into this same problem. If you add a little more bread flour to your gooy dough it may help. as for the not rising enough maybe your yeast is either to cold or to old.
May 10, 2010 | Regal Ware GL2850 Bread Maker
Never get a good loaf. Either bread doesn't rise or crust is very dark even when on light setting
your not letting the yeast rise enough first sweety ! i used to have that same problem always let the yeast rise outside of the machine first!! then put it in there
Jan 14, 2010 | Cuisinart CBK-200 Bread Maker
Bread Rises Beautifully - then sinks in middle during bake cycle
Sinking in the middle means that there was too much rising for the amount of structure in the bread.
Usual causes:
-too much yeast (reduce 1/2 tsp.)
-too much sugar (reduce 1/2 tsp.)
-not enough salt (increase 1/4 tsp.)
-too much water (reduce 1 tbsp)
Another possible remedy: use "best for bread" flour, it has more gluten, or add gluten separately, 1 tbsp.
Start with reducing amount of water.
Jan 04, 2009 | Breadman TR520 Bread Maker
Having difficulty
Try different batch of yeast. If still a problem increase the amount of yeast and/or sugar. Also if it rises and then falls there may be too much liquid.
May 29, 2008 | Cuisinart CBK-200 Bread Maker
Kitchen Appliances - Others Logo
1,027 people viewed this question
Top Kitchen Appliances - Others Experts
Angel Joseph Jr.
Angel Joseph Jr.
Irene Tulloch
Are you a Kitchen Appliances - Other Expert? Answer questions, earn points and help others
