Question about Samsung 206BW Monitor
After 30minutes and over,monitor display disappear
I just bought the 206BW but after 2 week, the monitor display disappear when i open the monitor about 30 minutes or over. It never happened before, but lately until now, it has been worsen. When the display disappear, i push the off button and on button again. But only within 1 minute, the display disappear. But the on-lamp-button is still remain on.
  • Aozora Jan 23, 2008
    I have a similar problem but worse--I started an app and the screen went black. It would stay black for a minute, flicker on for 10 seconds, then go black again. Is it the backlight?
I had a similar problem with the same model; the cable connection into my computer was not good. Try fiddling or replacing the cable.
Posted on Feb 04, 2008
Losing TV picture, screen goes blank,
If your LCD TV or monitor has stopped working, or is displaying one of the following symptoms, then it's a candidate for some new capacitors
- Flickering screen
- Screen image disappears after several seconds
- Dim screen
- Slow start
- Power LED on, but no picture
- Unusual colors and/or lines
The primary cause of LCD TV and monitor failure is caused by faulty capacitors. You can examine the capacitors in your LCD TV or monitor and actually see if they are bad.
If they appear bulged on top, then they need to be replaced.
New capacitors will solve a host of problems in LCD monitors and TV's and will extend the life of your monitor or TV by several years.
Check the cables, connectors and connections.
Take it to a repair shop.
Apr 21, 2014 | Televison & Video
SYNCMASTER 206BW PROBLEMS I started having the same problem about 2 weeks ago. The screen flickers on and off for about 15 minutes. Although I can see windows is running in the background, the screen...
Common problem with just about 905 of failed LCD monitors; bad caps.
If you are going to DIY and have proper tools and know safety precaution then please read on:
Most common failures in the LCD monitors are bad capacitors (bulging top/seal or leaking) in the power supply (they should be replaced in a set), blown fuses; poor solder joints, failed inverter circuits (blown fuse, shorted transistors, shorted/open transformers), bad lamps (poor solder connections or worn out lamps). You will need to open it up and inspect the inside, see example of failed SAMSUNG monitors to get some ideas what to look for: http://s807.photobucket.com/home/budm/allalbums
Post back what you see inside so we can guide you further and it will help out other people in the future also.
Basic LCD monitor troubleshooting guide:
http://www.fixya.com/support/r6150077-basic_lcd_monitors_troubleshooting
http://en.wikipedia.org/wiki/Capacitor_plague
Capacitors kit: http://lcdalternatives.auctivacommerce.com/ he can make you a set of caps for you.
Sep 26, 2010 | Samsung 206BW Monitor
White screen on a Samsung 206BW after it fell onto the floor
Something is wrong inside the monitor. I would call samsung support and get an answer from them. You could probably trade your monitor in aswell if its still under warranty.
Apr 18, 2010 | Samsung 206BW Monitor
E228WFP display disappears Posted by
disconnect all the cable from the monitor except the power cable .
see if you see any test screen and keep it on ,if the test screen blacks out you monitor is bad ,better buy a new one as usually repairs cud be expensive
Apr 17, 2010 | Dell E228WFP LCD Monitor
My display resolution shows 640x480 only, the system says i cant go any bigger?
Hello Dbaut72, hi, I have several options you need to try.
  1. try setting up your display on another PC, and see if the problem is your PC or your monitor,
  2. locate you driver CD for your PC VGA graphics, loading the driver to properly setup the video display may help resolve the resolution.
thanks and that all, keep me posted.
Mar 22, 2010 | Samsung 206BW Monitor
My samsung 206BW flickers and will not stay on
change your resoulotion settings by connecting your display with some other display device
Dec 15, 2009 | Samsung Computers & Internet
Can't display native resolution.
Dear Sir,
Better you have to try for once 1360X768 resolution. Its almost fits for Wide screen.
Please try for this.
Thanks
Sep 19, 2009 | Samsung 206BW Monitor
Samsung 206bw Monitor Flashes/Flickers on and off
Set the Hrts to 60 in Display Properties in control panel
Jan 14, 2009 | Samsung 206BW Monitor
Language problem
Hi , open the control panel cleck regional and language option .
Jan 17, 2008 | Samsung 206BW Monitor
Samsung 206BW Monitor Logo
171 people viewed this question
Top Samsung Computers & Internet Experts
Computer Repairing
Computer Repairing
Are you a Samsung Computer and Internet Expert? Answer questions, earn points and help others
