Powers on with leds lights. Hard drive leds comes on and goes off. Fan does not come on at all and has been replaced with new one. No video on lcd or external monitor, and all cables and connections has been checked. Tried with and without battery and ac adapter, also with new ac adapter, and new motherboard installed. No Fan and no display
Sandy4u
  • 107 Answers
SOURCE: no display
hi ,
this can be problem with CMOS ,reset CMOS by jumper or disconnecting CMOS battery .after this still problem with display please disconnect Processor from motherboard get cpu on without processor for 2 min .& after that cut off power assambled it as it is with processor & cheak it out
Display will come
If this information is useful for you please rate me ............
Posted on Jun 10, 2008
Sandy4u
  • 107 Answers
SOURCE: No display on LCD monitor
hi ,
Display will come
  • 126 Answers
SOURCE: Replacing Motherboard
There are things to consider when buying a motherboard.
  1. The type of processor you are using must fit on your new motherboard (compatibility issues)
  2. Memory.
Better ask your local store for a compatible motherboard. Unless your going to buy the same board .
If your purchase a new motherboard it comes with a instruction manual complete with installation guidelines and illustration to help you out. In case you have trouble doing so you can always contact your vendor or the manufacturer for help (online, toll free numbers).
If your having doubts whether your motherboard is defective you can run tests but you will need extra parts. You could ask your friends if they have one. In my case I usually test other components ex. processor, memory with a spare working motherboard. Fit in the componenets with your spare motherboard and if it runs chances are your suspected board is defective. Or better have it checked at another service center for a 2nd opinion.
Posted on Jun 21, 2008
SOURCE: VGC-RB50 Display Problem
I have the sony vgc rb40. I lost all video. I installed a new video card in the slot and only get the startup screen saying VAIO. It will not load windows. Plus, can't load the drivers from the cd because I can't see what to click. Any suggestions?
Posted on Sep 10, 2008
SOURCE: SimpleTech 320GB external hard drive power adapter
I have the same drive and it uses an Accurian AC/DC Adapter. It's output is 6.3V. Also the model number is XKD-C1500NHS66.3-12. I hope this helps.
Posted on Nov 11, 2008
Error why coming
Can you hear any fan or drive sounds? If you don't hear anything at all when you try to turn the laptop on, no little LED's light up, the problem almost certainly isn't related to the hard drive. So if you don't have a live screen, start with the LCD troubleshooting flowchart, and if you don't have any activity at all, start with the power troubleshooting flowchart. Even if the hard drive has failed at the electro/mechanical level and won't spin up, this wont prevent the LED's on the laptop from lighting up, or the LCD from displaying the BIOS information and complaining about the lack of a boot device.
Ford F150 Body Kits
Jun 07, 2012 | Computers & Internet
Everex StepNote NC1510 Model VA250E. No video on LCD screen. No video with external LCD screen either. Power and WiFi lights come on and hard drive spins for about 3 seconds. Then nothing else happens. ...
If it is still under warantee, take it back.. It has too many (different) hardware problems to warrant paying for service. replacement hardware would cost more than a new machine. Save your hard drives for the data and purchase a newer model.
Sep 13, 2011 | Everex StepNote NC1500 Notebook
Dear Sir, I have a NEC LT 260 K Lcd projector. The lamp of the lcd was busted.I replaced it with a new lamp. After replacing the lamp the lamp is not lighting when projector is put ON, I think the...
the clicking sound hopefully is the high voltage trying to start the lamp, but for some reason there may be a connection problem between the lamp and the projector power supply.
take the lamp out.
look at the lamp and check that the 2 connecting plugs are ok.
then look inside the projector at the power sockets that connect to the lamp (when it's installed).
check that the pins are not damaged or pushed down too far to prevent the lamp plugs making a proper connection with the power sockets in the unit.
Jul 01, 2011 | NEC LT 260K Multimedia Projector
System will not turn on
hard drive error get a new hardrive -might work or call sony for a replacement ps3
Aug 16, 2009 | Sony Playstation 3 (PS3) Console
Gateway T-1625 Laptop won't boot up at all
It sounds like a motherboard issue. The fan spinning and the LED lights are running off of battery power. This indicates that power is getting to the system. You should look into replacing the motherboard at this point. Before you replace the motherboard feel your system to see if there are any really hot spots that would indicate overheating. If not proceed with the replacement. If so, let me know where the hot spot is.
Regards
Dec 20, 2008 | Gateway T-1625 Notebook
My ibm thinkpad booting and hanging fault
Try this... to see if your video card is bad...
Connect your laptop to an external monitor and press the Function key plus F5 on the laptop... if your OS shows up on the monitor screen, then you have a bad video card...
If its not the video, Bad Ram might be the cause.
And worst case.. Need Motherboard replaced...
Jun 09, 2008 | IBM ThinkPad T42 Notebook
Wont power on
Try powering the system on with only the AC adapter, see if you get any power indications.
If you do not, then the system is not getting AC power.
See if the power adapter has an LED on it and if it is lit with the computer disconnected. If the LED doesn't come on at all, replace the adapter. IF the LED is on with the computer unplugged from it, then goes out when you plug it in, then try a new AC adapter.
If a new AC adapter doesn't resolve the problem, then you may want to look into buying a new computer as replacing the motherboard on this system may cost more than replacing the computer with a new system.
May 10, 2008 | Dell Latitude CpX Laptop PIII 500 Mhz...
Asus a8v fail
does the power supply fan run when switched on.
does the hard drive spin up .
Have you reseated the video card.
Jan 26, 2008 | ASUS A8V Deluxe Motherboard
Emachines 1900+ gets power to the monitor and computer but wont boot
There could be a number of causes. Do you hear any beeps when the computer starts up? Try seating all the chips in the motherboard. That means, apply pressure to each individual chip on the motherboard with your finger or thumb. The goal is to make sure each chip is securely attached to the board. Sometimes, heat or new h/w installs partially "pop" some of the chips out of the motherboard - causing the circuitry to be disconnected...
Aug 03, 2006 | E-Machines eMachines Refurbished EMA...
Computers & Internet Logo
29 people viewed this question
David Payne
David Payne
