Question about Radio Communications
Will not turn on at all fuses good getting power to radio
Hi could some one help
i have a ft-890 took it from shack to my shop to check a amp turned it off went and to do other things got it out of shop hooked it up in shack and it will not come on no parts of it i have tor it down checked sw good looks like it may be down in the bottom it will be hard to get all wires loose to get under the plate have worked in electronics all my life but this is tuff for a old man hi hi
has any one had this trouble larry k0smo
email beardin2002@yahoo.com
  • 7 Answers
Hi Larry, sounds to me like you may have popped a diode likely due to inverting your power connections and yes, the older we get, the harder it is for us to deal with surface mount stuff which gets smaller by the minute it seems.... hi, hi! Anyway, that is what I would check for 1st is a popped diode..... hope this helps!
73 de Tom ~ WV6Z
Posted on Jun 26, 2009
HI, I BOUGHT A RADIO SHACK BASE CB IT'S A 495, VINTAGE,AND A OLD ATTENNA BUT IT WAS STILL WRAPPED, @ A TAG SALE, I NEVER SOLDER THE GROUND I THOUGHT I HAD A GOOD STRONG CONNECTION, WHEN I TURNED ON T
Hi Jack , little pun. the radio should come on no matter what. Take the radio ( no coax ) plug it into the wall ,now see if it comes on. Look in the back to see if its on AC or DC. Which ever way it is turn it the other way. If the radio doesn't come on you should open the radio and look to where the power cord come in for DC. there is a diode there called a reverse polarity diode. It is probably a 1n4003 but check it anyway to see if its burnt. If it is replace it and the radio should come on . Also check the fuse .
Nov 30, 2014 | Radio Shack Radio Communications
On my 2012 chevy impala,i took out my radio,which worked.i took it out because my 2yr old put change in the cd player,to get that to work again.i got the change out easily,but when I installed the radio...
u may have blown the fuse when u took the radio out look under your steering wheel open up the fuse box and pull the radio fuse it should be a 10 amp fuse u can tell if the fuse is shot if the wire in the middle of tthe 2 prongs looks to be fried if its fried u will have to go buy a 10 amp fuse at your local auto parts store they are very cheap and easy to install good luck
Oct 27, 2013 | Chevrolet Impala Cars & Trucks
It will not turn on, took it to a Radio Shack just now and he could not get it to come on either.
Probably a burned out fuse on the power cord. Unscrew the end of the 12v plug and check the fuse with an OHM meter or just replace the fuse. Check that you have 12volts at the gps end of the cord.
Jul 14, 2011 | Garmin nuvi 260W GPS Receiver
Need to install a cdplayer in 70 chevy truck?
Because of the year of the truck you will not have any wires pre-wired in the truck, go to a Radio Shack, car audio store or Best buy and buy yourself some speaker wire for vehicles, about 5 ft of 14 - 16 gauge yellow wire, 5 ft of 14 - 16 gauge red wire a couple of 10 amp fuses and 5ft of 4 gauge black wire.
You are going to run the Yellow, Red, Black wires together from the radio space where the radio sits in down to your steering column, the speaker wires will go to your speakers from the radio, a + and a - lead to your speakers and connect them as needed.
Now back under your dash you will connect the yellow wire from the radio to the 12 volt + wire under your steering columns 12 volt power wire with a fuse inline, if you hook up a test light to this wire it will light up the test light without the car switch being turned on, the red wire will hook up to your ignition switch wire and your balck wire to the vehicles ground chassis, basically ground that wire to a non painted surface of the vehicle. This radio needs to be hardwired like I explained.
Good luck and hope it helps.
Lex.
May 21, 2010 | Car Audio & Video
Panasonic ct-32sl13g blowing fuse by power supply
You will need to remove the back of the TV. Don't worry, it's not that bad.
There are 4 screws across the top, one on each side, one right next to where the power cord goes into the back of the case, and the two more by all of the video connections **These are the most important to remove because they attach the main board to the back of the case.
Once you have remove the screws then the entire back of the set will slide off. If you look where the power cord attaches to the board you will see a small fuse. This is a 6.3 Amp 125 volt fuse. You can replace it with a 6.3 Amp 250 volt fuse from your local Radio Shack. A four pack costs between $3 and $5.
Make sure that you check that it works before putting it all back together. Check for any loose connection cables while you're back there. I found a few when I did this.
Apr 15, 2009 | Panasonic CT-32SL13 32" TV
Kicker zx 400.1 amp no power.. is it fried?
Well Friend, the chances that your amplifier is Fried are very low. First of all deactivate the Auto Turn On Feature on the Amplifier. Second, check that the voltage is received at the Power connector of the Lead that is coming from the Battery using the Multimeter to make sure that the Main Fuse is all right. If No Go, then check the Amplifiers fuses thoroughly. Then check if the Protection LED is lit. If it does not work after all of it, get it checked at any local radio shack as I'm sure, it cannot get fried just like that, as it is possible that some internal connection has fried or became loose and will be fixed without spending much. I wish it will help you..
Mar 14, 2009 | Car Audio & Video
I have a yaesu ft 890 transeiver
I've had good luck repairing a FT-890 with the same problem. I repair electronics for a living so there's a very good chance I can help you. Feel free to contact me at 941.748.1941 or at andros2112@yahoo.com.
73s - Steve
Feb 23, 2009 | Radio Communications
JBL Eon 15 Blown Fuse
These fuses are most likely 3 Amp fuses. Please note that if the replacements blow as well, that there is a problem within the amp section that will require repair.
Dan
Aug 14, 2008 | JBL EON 15-G2 Powered DJ Speaker With EQ...
Panasonic CT-32sl 13 32" TV
This sight rocks! And so do the people that posted information! Went to Radio Shack and got the 6.3amp 250 volt fuse. Fuse was easy to get to once I removed all of the screws and easily slid off the back. $2.99 fix (foe the fuses)
Jan 04, 2008 | Panasonic CT-32SL14 32" TV
Radio Communications Logo
77 people viewed this question
Top Radio Communications Experts
eradiostore
eradiostore
Are you a Radio Communication Expert? Answer questions, earn points and help others
