Question about Soyo DYLT032D 32 in. LCD Television
Sound doesnt match lips
I have a Soya HDMI flat screen TV. The voice of people talking doesn't match the lips of the people talking
    Problem Solver:
  • 10 Answers
Hi
Theirs no doubt you have a software problem with this set,happens a lot on the sharp range too,the software will need upgrading to the latest one for that model.Go to manufacturers website they may have it their with a "how to"note
Posted on Jun 04, 2009
Connect desktop pc to my samsung big screen tv?
match the display outputs on the back of the computer to the inputs on the TV. ..use Appropriate cable and switch TV Input to that type
No matching input ??
Search amazon for converter cable
DVI to HDMI usually work
VGA to HDMI can be problematic and not work
Amazon com DVI to HDMI
Nov 15, 2016 | Samsung Televison & Video
My Vizio flatscreen 60" HD tv background music sound overpowers talking. How can I lower background music? When no background music, the sound (talking) is perfect.
This is typical of sound systems that come with TVs, especially flat screens. You need to look into purchasing an external sound system, such as a sound bar or a surround sound system. That way you can have better control of background/voice ratios.
Jan 04, 2016 | Vizio Televison & Video
How do I install an antenna on a soya tv?
Do you mean a Sanyo? Ok,is your tv made after 2006? It has to have a high definition tuner,unless you are using a digital converter box.The tv only uses 1 channel when using converter. If not the tv has to be set up on air,not cable and needs to be auto programmed.Need more info about what you have please!
Jan 13, 2014 | Soyo Televison & Video
I have a vizio plasma 42" hdmi 720p 1080i tv with
The panel part #'s will have to match exaclty, the Ysus board # will have to match as well.
Dec 30, 2012 | Televison & Video
Just hooked up a new 47" LED TV to my Blu Ray Home Theater and have no voices played through the speakers. The background music and such is also low but the voices are like a "mute" I just...
You need to verify that the TV on screen audio setuo under HDMI is set to 'AUTO' so it will choose the audio through HDMI port not through the aduio Analog or SPDF/TOSLINK PORT. Check the set up of the DVD HDMI audio setting also.
Dec 02, 2010 | Televison & Video
What would cause the sound on a lcd hdtv 32 inch flat screen tv to just stop?
What other device are you connecting to your tv and how are you connecting it?
If you connect via a single HDMI cable that may be causing your audio problem. Some Tv and STB have handshacking issues which can knock out audio and/or video. The only solution would be to replace the HDMI cable or switch to composite cables.
Dec 14, 2009 | Element Electronics FLX3220F 32 in. LCD TV
No sound with HDMI cable and Xbox 360
FROM THE TOSHIBA MENU, (FIRST MAKE SURE YOU ARE SET TO
THE HDMI PORT THAT THE XBOX IS PLUGGED INTO) THEN SELECT
HDMI SETTINGS, UNPLUG HDMI CABLE FROM THE TOSHIBA TV (LCD
FLAT, MINE IS A 42") WAIT FOR THE SETTINGS TO HIGHLIGHT OR NOT
BE GRAYED OUT, THEN TURN OFF THE THREE SETTINGS, FOR COLOR
AND LIP-SYNC., SCROLL DOWN AND PRESS THE RESET BUTTON,
WAIT FOR MESSAGE TO APPEAR. TURN OFF THE TV AND PLUG IN THE XBOX.
TURN EVERY THING BACK ON. SEE IF IT WORKS.
NOT ALL CABLES ARE THE SAME AND NOT ALL TVS ARE THE SAME.
READ THE TV OWNERS MANUAL CAREFULLY, (RTFM), I FOUND A NOTE ABOUT
THESE SETTING ON THE SPECIFICATIONS PAGE.
Mar 26, 2009 | Toshiba 40RV525U 40 in. LCD TV
Fuzzy
have you tried updating the software fo your device?
Jul 27, 2008 | GE MiniCam Pro HO98756 Webcam
Sound problems with Insignia Flat Screen 37
It may be that the set is set for alt sound. go to the menu and set the audio to stereo. If the audio is set wrong it thinks you are set for spanish and if the broadcast is not in an alt language there will be no sound.
Jul 10, 2008 | Televison & Video
Sounds don't align with lip movement
if you are saying that your tv has no sound to match the lips movements then you will have to get a tech to repair your tv the problem is in the audio circuit could be a cap or the audio output ic.if you are saying that the tv has sound but it is not syncronizing with the lip movements have your tech check the sync circuit it is possible that the operating voltage is too small to allow the sync circuit to operate.good luck my friend.
Jun 15, 2007 | Westinghouse SK-26H240S Television
Soyo DYLT032D 32 in. LCD Television Logo
466 people viewed this question
Top Soyo Televison & Video Experts
ted dux
Are you a Soyo Televison and Video Expert? Answer questions, earn points and help others
