Question about Refrigerators
Fridge of Fridge/Freezer keeps freezing contents.
Fridge part of the fridge/freezer keeps freezing all of the contents. Freezer working as normal.
  • 15 more comments
  • smartwt Nov 04, 2007
    I have the same problem. There a square in the temperature display.
  • Anonymous Nov 16, 2007
    I have the same problem. Even with the temp set to the 'warmest' it will go. It happens a lot when we go away for the weekend and the fridge is not opened. Freezes everything. Really annoying.
  • Anonymous Dec 24, 2007
    Same problem,fridge freezes vegetables. Its a frost free fridge freezer.HOTPOINT FUTURE FFS70S please help if possible.
  • Pwog Feb 07, 2008
    I have the control turned to the lowest setting, yet the produce is still freezing. The frig is not that old, maybe 4 years. It has been doing this for the past year or so.
  • Anonymous Mar 24, 2008
    me too....whats the deal?
  • dawney62 May 23, 2008
    I have a hoover frost free Aclass fridge freezer and the fridge section keeps freezing up.
  • Rexy1 Jul 20, 2008
    I have exactly the same problem. Any ideas on how to fix this problem would be appreciated.
  • Jane Smith Aug 17, 2008
    fridge part freezing all contents. freezer working fine. temp same in freezer as it is in fridge. temp control already changed. worked for a few days back again!
  • clarkey2004 Sep 24, 2008
    I have a hotpoint ffa70 and my fridge part keeps freezing up and is ruining the contents, please help me soooo much foods keeps on getting wasted!
  • Anonymous Mar 13, 2014
    daewoo fridge freezer not freezing at top
  • Anonymous Mar 17, 2014
    I have a 20.0 cf frostless fefri./freezere model #HMG50103 and it has quit freezing and keeping cold any thoughts
  • Anonymous Mar 18, 2014
    freezer is not freezing fridge is operational
  • Anonymous Mar 20, 2014
    fridge freezer model ff220
    at all can you help
  • Anonymous Mar 23, 2014
    Freezer not working only installed today
    Brand new american fridge frezzer freezer not freezing up
All the food going to ice temperture at 2
Posted on Nov 25, 2007
    New Friend:
    Problem Solver:
  • 12 Answers
Turn of fridge for 24 hrs, most likely damper assy is blocked with ice
Posted on Oct 15, 2014
    New Friend:
I just had my compressor replaced on my Fridgemaster fridge freezer and the thermostat replaced and the fridge still freezing up. what can I do next?
Posted on Jun 20, 2013
    New Friend:
  • 17 Answers
There is a thermostat in the fridge area of your fridge/freezer, get your model number and look up your fridge and find the part you need and replace it.
Posted on Feb 21, 2013
Fridge section keeps freezing up.
Hi,I had trubble with my fridge so done a bit of reserch the main reason for the fride freesing up is,
fridge not set at right temp (3 to 7 c ) or vent where water drains blocked,shelves not in right place as in manuel,and if you put veg that has alot of mosture content can also course freezing at the bottom of the fridge,hope this was some help,maybe buy a fermomiter to test.
Jul 03, 2016 | Refrigerators
Freezer turns of in cold weather
Many residential refrigerator / freezers are designed to work at temperature considerably above above freezing. Most modern refrigerator / freezer have a single electric thermostat - located in the fresh food compartment. This lone thermostat will control the compressor to keep the fridge (fresh food) section at the desired temperature (usually between 34 - 38 degrees F). The freezer will get colder regardless of how cold it is already whenever the fridge thermostat turns the compressor on.
Now that you see how the thermostat works, let's look at what happens when the fridge is placed in an unheated space - like a garage. In winter time, the temperature can drop considerably below 38 degrees. If the outdoor temperature remains cold enough, for long enough - it will affect the thermostat in the fridge. The temperature inside the fridge could drop below 38 degrees, preventing the thermostat from telling the compressor to turn on. Meanwhile, the temperature in the freezer compartment slowly rises from the normal -10 to 0 F degrees. It will continue to rise until it is the same temperature as the fresh food compartment or until the thermostat in the fresh food compartment tells the compressor to turn on again. This means the freezer contents will thaw.
If the temperature in the garage is even in the 40 to 50 degree range, the loss of cold in the fridge may not happen often enough to keep the compressor coming on often enough to keep some freezer items frozen solid - such as ice cream. Remember, water freezes at 32 degrees F, other products may require lower temperatures to remain frozen, and could thaw at 28 or other temperature.
Feb 13, 2012 | Refrigerators
The contents of the refrigerator freeze even on low settings
One of the most common problems with freezers is their tendency to build up a thick level of frost and ice that can disrupt performance. The ice can form on the hoses and cause the fan to freeze up. While you want the freezer to be cold, too much ice is not good for the freezer or the food inside it. There are multiple reasons a freezer could start to develop frost buildup.
Freezer Overstocked
Frost can build up in the freezer if there are too many items inside of it. Air cannot properly circulate around the freezer, so the areas with the sitting cold air can freeze the moisture. Frost continues to build up and accumulate, which then allows it to spread. If food is stocked up near the fan, cold air can't get past it, and the fan itself could develop frost to the point where it freezes and stops working entirely. This can be prevented by not overstocking the freezer and by evenly distributing food throughout.
Temperature Setting Too Low
The freezer should have a thermostat that regulates how cold it gets. If the temperature is set at too low of a setting, the freezer kicks into high gear, the air freezes outright and frost quickly builds up. Adjusting the thermostat to a higher temperature or level can counteract this problem, but you may need to de-thaw the freezer to eliminate the frost that has already built up inside.
Keeping the Fridge Door Open
Many people keep their fridge door open for extended periods of time while they examine the contents inside to see what they want to eat. This can contribute to frost buildup in the freezer, because the fridge is taking in a lot of warm air during this process and the fan pushes it up into the freezer. The moisture in that air is then quickly frozen, and ice can build up substantially as a result. The longer the fridge door is held open, the more likely this can occur, so the best solution is to only keep the fridge open for short intervals and then to not open the door again for a while.
Hope this tips will help you. : )
Aug 17, 2011 | Refrigerators
Fridge walls very warm around freezer door
that is ok these fridges have the condencer lines within the walls of the fridge or some have heaters this is for condensate not to form on the fridge it keeps the fridge dry on the outside
Sep 26, 2009 | Frigidaire 20.6 cu. ft. Top Freezer...
My daughter's mini fridge has a freezer compartment. Her issue is, if she turns it up high enough so the freezer freezes, the fridge compartment also freezes everything; if she turns it down so that the...
This is a drawback of most mini-fridges. Start by defrosting everything. Then fill ice cube trays with water and keep lowering the setting until the water freezes. Just go a little lower, no more. Fridge should not freeze food. If the fridge stays closed all the time food will freeze. Also if the freezer element gets ice buildup it must be defrosted. Not automatic like home fridge. Most kids today weren't born when the last fridges that had to be defrosted were in service.
Sep 01, 2009 | Refrigerators
Zanussi ZFC 45/30 SS is hot at front between the doors..
This is normal. This is a defroster to keep moisture from condensation from freezing the doors shut.
Jun 30, 2009 | Refrigerators
The fridge part of my fridge freezer keeps freezing everything,
Hello
I have the same problem and have talked to the manufacturer. They said to turn off the appliance for 24 hours then it should be good as new when you switch it back on. Obviously you'll have to find somewhere for your freezer contents. I'm going to try this myself tonight.
Fridge Reboot!
Jan 05, 2009 | Hoover HCA390FFK Bottom Freezer...
Food is freezing
usually there is an adjustment at the back for the difference between the fridge and freezer compartment. Often is just a vane that blocks freezer air, too much air would freeze the food. Normally you set the fridge thermostat for a normal food temp, then adjust the air to keep the food warmer than the freezer.
Jan 28, 2008 | Arctic Air R22CW Refrigerator
Indesit Fridge Freezer
YOUR DEFROST TIMER OR A BURN OUT DEFROST ELEMENT
Oct 17, 2007 | Engel Freezer 22 Qt. Fridge/Freezer
Refrigerators Logo
1,947 people viewed this question
Top Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
Marvin
Marvin
