Question about RCA (RCA2VGA) TV Input
How do i set up my rca2vga adapter - RCA (RCA2VGA) TV Input
Where can i buy cheap travel adapters?
Take a look at Walmart. They have various plug adapter sets at good prices;
http://www.walmart.com/ip/Sima-SIP-3-Sima-International-Travel-Adapter-Plug-Set/10575435
Jan 17, 2013 | Luggage & Travel
I have the new black wireless adapter with the 2 antennas. Live works, but once in a while it disconnects me randomly and my network adapter flashes green. Any connection?/.
you dont have a good catch of signal connection in your area.try to power off your adapter for 5 mins. then power it on again..reset might need for your adapter.also check the settings status of the adapter if its in the right set-up.
Feb 25, 2011 | Microsoft Wireless Network Adapter Xbox...
Why does my adapter connect to the internet then disconnect for no reason?
Please check out the setup of your wireless internet. And then the settings of your adapter. They should have the same settings. If not, follow the settings of the wireless setup.
Jun 26, 2010 | Encore 54MBPS 802.11G WIRELESS PCI ADAPTER...
I got belkin wireless g gaming adapter for my xbox 360 the other day and i downloadaded the cd on my computer and followed the instructions, but when i put it in my xbox 360 the xbox couldnot find the...
You will need to match the wireless settings of your router and the gaming adapter.
Who is the manufacturer of your router?
connect your computer to the router with the cable and open the set up page of the router. check the wireless settings of the router SSID, Channel, security settings.
now you gaming adapter and the Router IP address should be in the same range. Suppose if the router IP address is 192.168.x.y and the default IP address of the gaming adapter is 192.168.a.b., then the number x should be equal to a. If it is not then you will need to change the IP address of the gaming adapter so that x will be equal to a.
after that open the set up page of the gaming adapter and change the wireless settings.
power cycle the router and the gaming adapter and now it should work.
For more info about networking Click Here
Oct 06, 2009 | Belkin (F5D7011) 802.11g/b Wireless...
Need help with setting up my wireless network adapter and the problem is it will not connect to my pc because there is some type of passcode but there wasnt one set with the router when i set it up .
it seems your problem is that you cannot save the network settings or the password.
Restore the factory defaults for the wireless networking adapter. To do this, go to the System section of the Xbox Dashboard. After you restore the default settings, the adapter status light will alternately flash green and red. The light will turn steady red to indicate that you have successfully restored the defaults.
Note If you restore the factory defaults on the adapter, you override the current adapter settings.
Before starting with this action please check additional detailed troubleshooting Xbox information at Microsoft support page:
http://support.microsoft.com/kb/907602/en-us
This should solve your issue, success
Sep 03, 2009 | Microsoft Wireless Network Adapter Xbox...
New netgear adapter on my laptop & can't get on the internt
I think you need to set up you home wireless network on your laptop again. I asume you set it up with your first adapter, but you need to set it up for the new adapter. If this doesn't help, include OS type on laptop. Then I can give a better solution.
May 25, 2009 | NetGear : WG111 54 Mbps Wireless USB 2.0...
Can't connect my gaming adapter to my wireless network
If the ethernet light -( )- is off, flip the X - II switch to its other setting.
If the wireless light is off, click on the channel button, it should me IN. If still cannot connect, then you will need to setup the wireless settings of the gaming adapter.
First, you need to know the wireless settings on your wireless router or access point. Take note of the wireless network name (SSID) and wireless security settings.
Connect the gaming adapter to the router using an ethernet cable. Flip the switch on the adapter to straight through (II).
Then insert the Setup CD of the WGA11B to your computer. Click on the Setup button once the wizard is up. It will then show you the current settings, so just click next.
It will ask you for the password of the adapter, just type admin.
Make sure that Obtain IP address automatically is selected, then click next.
On the Profile configuration, select Internet for the mode.
Then enter the SSID and select WEP if wireless security is enabled on the wireless router. Type the passphrase of the WEP key. Then click No to complete the configuration.
Connect the gaming adapter back to the PS2.
Apr 09, 2009 | Linksys Wireless-B Game Adapter 802.11b...
XBOX 360Adaptor
the adapter should have the right settings as that of the network it is trying to connect to. you may want to contact your wireless router (or wireless AP) manufacturer to get the settings then have the adapter connect to those settings.
Nov 04, 2008 | Microsoft Wireless Network Adapter Xbox...
Menu button and red switch configuration of RCA2VGA
Just ask here, they are specialized in finding english manuals for chinese import items. They helped me a lot with my SciPhone mobile.
Oct 22, 2008 | RCA (RCA2VGA) TV Input
Intel 3945ABG 802.11a/g/b Wireless Adapter Problem
look in your routers settings and see if there is an idle time setting and set this to '0'
Feb 13, 2007 | Intel 3945ABG (WM3945AGM1WB) 802.11a/g/b...
RCA (RCA2VGA) TV Input Logo
125 people viewed this question
Top RCA Televison & Video Experts
jason
matt martin
matt martin
Are you a RCA Televison and Video Expert? Answer questions, earn points and help others
