Question about Nikon 20MM F2.8 AF NIKKOR Lens
Camera (D200) no longer sees that the diaphragm lock is on. If I jiggle the diaphragm ring it works for amoment. How do I fix this?Thanks
    Scholar:
  • 48 Answers
Sounds like the AI ridge on the aperture ring may be slightly damaged. The D200 senses when the lens is set at minimum aperture using that ridge. The AI ridge is the raised part on the back edge of the aperture ring. On that lens, the contact edge is between f/11 and f/16, closer to the 16. Look closely at that edge, it should be smooth with even corners. Since it works a bit if you jiggle the ring, it sounds like maybe just a little piece missing. If it's damaged, replacement is pretty your only option.
Posted on Feb 07, 2009
  • 667 Answers
With the lens off, look at the camera mount area. If you are looking straight at the mount, there is a small tab sticking out at about 7oclock on the outside edge of the mount ring. The tab is spring loaded and may be damaged. You should be able to push the tab toward the base of the camera and it will snap back if functioning properly. If it feels loose or doesn't spring back, then switch that ab controls is not being activated.
Posted on Dec 23, 2007
SOURCE:
EE NIKON D 200
Do you mean "fEE"?
You're apparently using a lens with an aperture ring. Turn the ring to its smallest setting (largest f/number). If the lens has an aperture lock, lock it. You can control the aperture from the camera body, the same way as on a lens without an aperture ring.
Apr 20, 2013 | Nikon D200 Digital Camera with 18-70mm...
I used my 80 - 200 f2.8D ED nikon lens on my D200 body, There is " fEE" blinking sign on it. But if i use my 18-70 lens there is no problem. What wrong with my lens ?
nothing is wrong with your lens. when you mount the 80-200 make sure the aperture ring is set on the highest f-stop (F22 or F32). there is a small lock that will lock the aperture ring in this position. if the camera thinks the ring is not in the "highest" "F" position you will get the error.
Oct 06, 2010 | Nikon D200 Body Only Digital Camera
When mounting either of my Sigma 70-300mmD lens on my Nikon D200 I get the fEE symbol. I've locked the lens at f22 with no results. It's worked flawlessly for me for years. Both lenses work beautifully on...
Have a close look at the iris ring to see if any think is broking off
or try moving the lens when it is locked on the camera to see if you lose the fee if so it may need a new mount
Aug 17, 2010 | Sigma f/NIKON- 28-90/3.5-5.6 Aspherical...
I have a Telephoto AF Nikkor 85mm f/1.8D Autofocus Lens on Nikon D200 camera body, and I've been using it for a few months with no problems. I love the lens. But a week ago I was in the middle of...
You may want to check what the aperture ring is set at on your 85mm. Nikon SLRs for most purposes, require that the f-stop on the lenses be set at the minimum aperture number, ie f-16,22,32. This is so the camera has the full range of the aperture to control it properly. Most if not all lenses for Nikon have a small button, usually marked with orange, to lock the aperture ring at that setting
Jan 11, 2010 | Cameras
D200 will not turn on
Have you checked for dirt in the camera battery compartment. Take some high powered air spray and blow it clean. See if that fixes it.
Aug 17, 2009 | Nikon D200 Body Only Digital Camera
Very soft focus on D200
Hi Amanda, welcome to FixYa.
Try this to fix your focusing issue. It's a custom AF setting.
Press the Menu and select the pencil icon. Then you'll see Custom Setting Menu on the LCD display. Click down to Autofocus and then click to the right.
There are 3 choices here: FPS Rate, FPS Rate + AF, and Focus.
Set it to Focus.
FPS Rate is the default setting, the camera will take 5 frames per second whether it's in focus or not.
FPS Rate+ AF forces it to slow down hoping to get more frames in focus.
Focus sets the camera to fire only when in perfect focus. It slows you down some, but it will save you from deleting all the blurry ones.
Try this and let me know if it works for you with a comment.
Ken Rockwell has alot of tips and tricks (including the one I just gave you) in a pdf telling all about your camera. You can read it here. http://www.kenrockwell.com/nikon/d200/users-guide/d200-users-guide.pdf
Enjoy your camera and feel free to rate my solution.
Rob
Mar 02, 2009 | Nikon D200 Digital Camera with 18-200mm...
Nikon d200 sprayed with water
I would suggest that you give the contacts a good clean (gently of course) on both the camera body and lens'.
Also although the water would make no difference, make sure if you have any lens' with aperture rings to put them round to F33 or the smallest aperture, if they aren't this will cause the fEE.
Hope this helps
Drew
Oct 06, 2008 | Nikon D200 Body Only Digital Camera
80~200 not focusing on my D200
If lens has aperture ring, set to min aperture before mounting (f22 etc)
With heavier lenses it is not so easy to tell when lens clicks in all the way to mount, Lens wont autofocus if not clicked in to mount just so. Also both camera and lens should be set to AF.
May 17, 2008 | Nikon D200 Body Only Digital Camera
Repairing 20mm af nikon lens diaphragm lock
I'll offer the same answer I just gave on a D200 question: With the lens off, look at the camera mount area. If you are looking straight at the mount, there is a small tab sticking out at about 7oclock on the outside edge of the mount ring. The tab is spring loaded and may be damaged. You should be able to push the tab toward the base of the camera and it will snap back if functioning properly. If it feels loose or doesn't spring back, then switch that ab controls is not being activated.
Oct 24, 2007 | Nikon 20MM F2.8 AF NIKKOR Lens
Quantaray 28-90 for Nikon N65 zoom ring locked up
There is no secret locking switch. If a little gentle jiggling doesn't free the zoom ring, then I can only suggest you take it in to a reputable camera shop for a Clean-Lubricate-Adjust (CLA).
Sep 03, 2007 | Quantaray 28-90mm f/3.5-5.6 for Pentax
Nikon 20MM F2.8 AF NIKKOR Lens Logo
90 people viewed this question
Top Nikon Cameras Experts
Ric Donato
pictureman4u
Geoff Hone
Are you a Nikon Camera Expert? Answer questions, earn points and help others
