Question about Kenmore 24 in. 16049 Built-in Dishwasher
Kenmore Elite dishwasher not cleaning well and leaving dark stains on the dishwasher walls. water pumps in to correct level and pumps out. First cup of soap the water is just warm. Second up its hot and also the rinse cycle. Bottom filters are clear.
  • 6,784 Answers
Check the following to address this issue
1. No water
Make sure you get water to the dishwasher. Check to see if the water shut-off valve (located under the sink) is open. If you get water to the dishwasher, but there is still no water inside during the fill cycle, the problem might be with a faulty water valve (located at the bottom of the dishwasher, behind the kick panel, on either side), in which case replace the water valve.
2. Not enough water
If there is not enough water, the dishes would not get cleaned. This could be caused by a partially closed water shut-off valve (located under the sink), or a faulty dishwasher water valve (located at the bottom of the dishwasher, behind the kick panel, on either side).
3. Clogged spay arms
There is usually two, sometimes three spray arms in a dishwasher. Make sure there is no debris blocking the holes inside each spray arm.
4. Water temperature is too low
To get the best results, the water has to be at 120 degrees Fahrenheit when entering the dishwasher.
5. Not enough soap
If you only fill one part of the soap cup, try adding soap to both parts.
6. Smoky film on dishes and glasses
This problem occurs due to excessive calcium build up inside the dishwasher. Try cleaning you dishwasher using a dishwasher cleaner.
Posted on Jun 04, 2009
My Kenmore Elite Top-Load Series 700 Washer leaves streaks on clothing. It looks like dusty powder. I use liquid HE detergent. It was a normal cycle of dark clothes, not heavily soiled or dirty. Also
THE stains on your clothing especially on whites are most likely due to a top seal failure on your transmission. transmission leaking oil. if the clothing affected or the stain can be removed with a solvent like gas, kerosene, paint thinner repair on washer will exed the value .... if the streaks or stains can be removed with a water soluble detergent then the stains are caused by the soap and or hard water deposits in your washer . then the solution to cut way down on soap usage in your washer and or running an acid wash (soap is alkaline acid will dissolve it . make sure not to over solvent your clothes and to rinse all solvents out completely . be careful !!!! a solvent soaked t-shirt bunched up and left in tightly sealed plastic bag WILL CATCH ON FIRE!!!!
Jan 22, 2015 | Kenmore Washing Machines
Dishwasher spray arms don't spin & spray water
Check that the water pumped on arms has enough pressure.
Aug 15, 2008 | Kenmore 24 in. 17482 / 17484 / 17489...
The dishwasher doesn't seem to be cleaning very well any more. The glasses are always dirty and the dishes just don't seem to be clean like they used to be. Does the dishwasher need some maintenance? ...
Check the following:
- The Salt Container - Found at the bottom of the Dishwasher. (If required, replenish salt)
- The spray arms (They usually get clogged at the small holes where the water should spray out of)
- Us less heat (High heat can leave white visible stains on glass)
Hope this helps :-) - J.Q
Feb 16, 2011 | Kenmore Elite Stainless Steel 24" BuiltIn...
Water coming out front of dw at start of wash cycle. I leveled the unit. no luck. if you open the door during fill cycle the water does not shut off. also, may be a problem with float shut off working...
Hi
Check float to insure that it is free to move, it sounds like the dishwasher is over filling. That is assumed that you have not changed the type or amount of detergent being used.Also there is a probability that the drain inside the machine could be plugged. Also check the latch and the rubber gasket/seal around the door.
Also it could be the water solenoid is faulty. The valve is staying open. In back of the lower front panel near the front you'll see copper tubing going into a blue or green plastic solenoid with two wires going to it. This is the water solenoid. Inside is a steel slug that moves to open the water feed. Yours is stuck open. So guess it's time for a new valve.
Dishwashers use an inverted cup float to measure the water level in the tub.
The tub has a tube extending up from the bottom that serves as a standpipe. The inverted cup has a rod that goes down through that tube and rests on a cam from the water level micro-switch. As water enters the tub air is trapped inside the inverted cup and the cup floats upwards as the water rises. In turn the rod rises and allows the cam on the micro switch to rise also. When the tub reaches its preset limit the float has raised high enough to allow the micro switch to open, which in turn closes the solenoid water valve turning the water off.
Often the shaft of the float switch or the inside of the standpipe tub gets coated with soap scum or cooking oil and making it gummy. This then sticks the float down so it cannot rise to signal when the tub is full.
Lift the float upwards, it is loose and will lift right out. Clean the inside of the cup, the rod which extends downward and the inside of the standpipe tube. Replace the cup and check the function. The cleaning should resolve your problem. If not the problem is either a defective micro switch or solenoid valve.
Please get back to us if you have further query else please accept the suggestion.
Thank you for contacting fixya.com
Jan 03, 2011 | Kenmore Elite Stainless Steel 24" BuiltIn...
I am getting stains on my dark clothes that look like oil stains.
Check that the dispenser is clean, it may be gunged up with black gunge, use soda crystals and put machine on hottest wash. If all is clean it could be down to seal gone in drum letting grease into system. Good luck, let me know how it goes.
John
Sep 03, 2009 | Kenmore Elite Oasis 27052 Top Load Washer
Kenmore Dishwasher - stops cleaning dishes - 2 techs just scratch their heads - any suggestions? water is hot, changed soap, still not even coffee stains inside cups are cleaned, let alone the rest.
ensure spray arm holes are not blocked, the water level is good, the spray of water is strong, it is heating and the tablet is entering the wash, not much else can cause a bad wash. note dishwasher may not always be able to get rid of some coffee stains.
Mar 04, 2009 | KitchenAid 24 in. KUDI02IRBS Stainless...
Dishwasher Soap scum left on dishes
the problem is hard water. There is a new product out called The Dishwasher Filtration System. It filters the water going into your dishwasher leaving your dishes spot free with every load. It is very affordable and fits right under the sink. You will be amazed how sparkling your dishes look just after one load. You will love this product. Get it at www.dishwasherfilter.com.
Nov 01, 2008 | Bosch 24 in. SHU53 Built-in Dishwasher
White stains on dishes and clogging film in the sink. Plumber snaked sink and mentioned we need to change the filter in our kenmore elite dish washer.  Don't know where the filter is orb how to find it....
The problem is hard water. www.dishwasherfilter.com has a product to solve this problem once and for all. It filters the water going into your dishwasher and removes the hard minerals that leave those spots. It is very affordable and even has a money back guarantee. You will love the way your dishes look with this product.
Sep 08, 2008 | Kenmore 24 in. 17482 / 17484 / 17489...
Black stains on white table cloth
Hi! topjdog
I hope you have been running the monthly cleaning cycle. This includes cleaning the front gasket.
InMrFixIt
Aug 16, 2008 | Kenmore Elite HE4 Electric Dryer
DARK CLOTHES END UP WITH BLEACH DOT STAINS
SOME BLEACH DISPENSERS USE COLD WATER TO FLUSH THE BLEACH FROM THE CUP. CHECK THE COLD WATER FOR GOOD PRESSURE. IF THERE ISN'T GOOD PRESSURE, REMOVE THE COLD WATER HOSE FROM THE MACHINE AND CHECK THE SCREEN INSIDE THE VALVE WHERE YOU REMOVED THE HOSE. PUT THE END OF THE HOSE IN THE TUB AND TURN IT ON. CHECK FOR GOOD PRESSURE. CLEAN THE SCREEN AND RECHECK THE WATER PRESSURE AFTER REINSTALLING THE HOSE AND TURNING ON THE WATER. IF YOU STIL HAVE POOR PRESSURE REPLACE THE VALVE.
Apr 07, 2008 | Kenmore 22422 Top Load Washer
Kenmore 24 in. 16049 Built-in Dishwasher Logo
507 people viewed this question
Top Kenmore Dishwashers Experts
Ken Johnston
Ken Johnston
Level 1 Expert
vince
D. E. Hev
Are you a Kenmore Dishwasher Expert? Answer questions, earn points and help others
