Question about Toshiba 65HDX82 65" Rear Projection HDTV-Ready Television
Toshiba 65HDX82 is distorted on top 6" of screen
When the TV is first turned on, the picture is completely distorted. It gets better slowly and evenly and after about 5 minutes, it becomes clear except for the top 6 inches of the screen which now stays slightly distorted. It is most visable when a banner is played across the top of the screen or close ups where faces are at the top.
Also, I purchased this TV many years ago before HD was available. Do I need a HD converter or other part in the TV or will an HD digital box from my cable company be all that I need?
Thanks,
Tony
http://www.tacp.toshiba.com/televisions/product.asp?model=65HDX82
    President:
  • 1,952 Answers
Check the screen voltages goinfg to all three tubes. Another thing you could try is unplug the crt socket to the red and see if the other tubes stay lit . There ia a possiblity that the red tube could be over powering and shutting the others off or down.
Posted on Jun 04, 2009
  • mohammed marika thambi
    mohammed marika thambi Jun 04, 2009
    check the screen voltages goinfg to all three tubes. Another thing you
    The culprit is nearly always failure of the two ICs called STKs. They
    will cost around $400 to have a repair expert do the job in your home.
    The STKs are common and if you have an experienced electronics tech
    around they can replace them for much less money but the tech must have
    advanced soldering and IC exchange experience.
    The STK ics, two of them, can be purchased on line for around $20 to $40 each.
Muffled sound, blury picture
If your TV looks 3D, warped, or distorted it likely has a convergenge problem.
If however it just looks dull, washed out, redish, or if it looks like objects on the screen have halos the fluid in the lens has soured.
You can search google for parts or you can get the parts with repair instructions from sites such as www.TvRepairKits.com
Feb 27, 2011 | Toshiba 65HDX82 65" Rear Projection...
Toshiba 65hdx82 has a squiggly distorted side to side picture from all inputs. It gets slightly better after it is warmed up but still very bad. When you go into a menu screen that seems to be OK.
Ur convergence is the problem.U know how to solders?Tries websites.Tv repair World.com,Tvrepairkits.com for convergence kit,replaced what in the kit.
Dec 15, 2009 | Toshiba 65HDX82 65" Rear Projection...
Distored picture on top half of the screen
This is one of the sets with bad HYPER boards. If it clears up after a while this is your trouble;I just checked a site in LA--the only way to get the board is to go to PTS electronics and send them the original board for repair--part alone is over 200 and is soldered in--a lot of these sets are having this problem.
I know I am not giving you good news but I am pretty sure this is what is wrong with your set--seen dozens of them.
if you think I helped you in some way--give me a vote here I do this for free. IF YOU HAVE QUESTIONS OR NEED MORE HELP contact me by responding to this post.
SD TECH (SAN DIEGO)
Aug 29, 2009 | Toshiba 55H70 55" Rear Projection...
Card reader replacement
I suspect that it won't play any source that uses progressive scanning. The likely problem is the hyperboard or scaler board. This component allows the TV to switch from sandard definition TV to HD. Typically, the hyperboard will cause shaking and wiggly images especialy noticeable at the top of the screen. It will generally work better the longer its on. Expect to spend $400-500 to resolve this.
michtech
Dec 09, 2008 | Toshiba 65HDX82 65" Rear Projection...
Distorted Picture
the hyper module is defective needs to be repaired or replaced.
Aug 03, 2008 | Televison & Video
Distorted Picture
Projection TV sets need to have all three colors - RED - BLUE - GREEN - lined up correctly on the screen in order for the video to look normal. When its out of alignment the video will look 3D, wavy, distorted, etc. Most of the time you just need to adjust your convergence in the TV menu. If you cannot adjust it in the menu - then your convergence is broken and needs to be repaired.
Convergence problems are very common on all Projection TV sets including Sony, Samsung, JVC, Philip Magnavox, Panasonic, Akai, Pioneer, Hitachi, Zenith, and others. You can get a convergenece repair kit from the link below.
Common Symptoms include....
  • Screen looks 3D
  • Colors don't line up
  • One or more colors can't be adjusted when using the convergence menu.
  • Screen is bowed or warped.
  • TV shuts off after powering on - TV may also make a chirping noise.
Here are some photos of convergence problems.
Here is a quick test....
Using your original remote go-to the settings menu then goto the convergence section.
Try to adjust the red and then the blue convergence.
You should be able to move RED and BLUE in all directions - up, down, left, and right.
If you can't move them in all directions or cant move them far enough your convergence chips are bad and should be replaced. This is a common problem.
Note: If you TV has as flash focus or magic focus button only try pressing the button. If it fails to fix the convergence your need to fix it. See below for a solution
93a1209.pngCONVERGENCE SOLUTION
You will need to replace the convergence chips and possibly some convergence resistors and pico fuses.
This is a a fairly easy DIY job if you know what you are doing. If you have never done this before we would advise calling a shop or if you want to do it yourself get a complete kit with instructions and support from www.TvRepairKits.com
Aug 02, 2008 | Toshiba 65HDX82 65" Rear Projection...
Warped picture Toshiba 65HDX82
Projection TV sets have several common problems listed below.
Problem #1) Convergence
Symptoms:
  • Screen Looks 3-D
  • Colors wont align
  • Screen may look distorted
  • No Audio/Video - makes a chirping sound.
Example Photo:
Problem #2 CRT Fluid has clouded over.
Symptoms
  • Dull Video, Washed out
  • White/Bright looking video
  • Halos around objects
  • Red/Orange looking
Example Photo:
You can see more examples and find a fix here...
bb0cf99.pnghttp://www.fixya.com/support/r2861467-solution_video_looking_whiteish_dull
Jul 12, 2008 | Toshiba 65HDX82 65" Rear Projection...
Re 65HDX82 Squiggly distorted screen
You are giving mr ** information on what your problem is, the model number, or make of the TV set. what are you trying to tell me?
Mar 10, 2008 | Toshiba 65HDX82 65" Rear Projection...
Arcing Picture tube
get a different tech from a different store to come out, needs to replace convergence ic's good luck
please mark the post with a fixya
Feb 16, 2008 | Toshiba 65HDX82 65" Rear Projection...
Distorting
if it is wavy lines across the top it is probably the scan converter/ hyper bd they are becoming hard to find/expensive you can repair them but it requires many surface mounted capacitors and requires some VERY skilled soldering.
Apr 23, 2007 | Toshiba 57H82 57" Rear Projection...
Toshiba 65HDX82 65" Rear Projection HDTV-Ready Television Logo
109 people viewed this question
Top Toshiba Televison & Video Experts
Jaime Hernandez
Are you a Toshiba Televison and Video Expert? Answer questions, earn points and help others
