Question about Danby Heating & Cooling
Danby APAC9030 can I cover the intake hose with a filter re aller
My daughter has pollen allergies. we have a hepa filter in the bedroom but it is soo hot now! We run a Danby APAC9030 Portable AC in the room. In the manual it says that both intake and exhaust hoses have to be out the window. It also says that for dehumidify and fan the hoses can both be inside the house and not out the window. Our concern is that the intake brings in pollen filled air into the bedroom. It this the case/ I have emailed Danby to no avail. I have a small vent cover that would fit over the intake hose but am worried I could burn out the unit. PLEASE HELP!
5 Suggested Answers
SOURCE: Air intake via hose & window or intake from room only?
Hello artrey3 The answer is yes, BUT the unit will be exausting room/basement air outside ruining any efficency the unit is rated for.Also you will need makeup/fresh air in the basement. The unit exausting air can put the basement in a vacuum/negitive pressure pulling in air from the chimney!
Posted on Jul 09, 2010
SOURCE: danby standup aircondioner ( 3 in 1) , does not MODEL APAC9030
If you receive an answer to this I have the exact same problem... dougakers at msn dot com
Posted on Aug 14, 2010
  • 24 Answers
SOURCE: Hi, two days ago I
Comperssors have a thermal overload. If there is a starting problem or low on freon the conpressor will shut down until cooled off. Try restarting and listen to compressor.
Posted on Sep 03, 2010
ercupa190
  • 12223 Answers
SOURCE: Blows very cold air during dehumidify mode.
se this fact: God bless you
air conditioning system cools but does not dehumidify the room. The most common cause of inadequate dehumidification by an air conditioning system is the installation of a cooling unit which has too much capacity, or is "over-sized" for the space it is being used to cool. What happens is simple:
If an air conditioning compressor unit is oversized (too many BTUH of cooling capacity) what happens is it cools the room so quickly that the system does not move enough total volume of air across the cooling coil to remove much moisture before the room temperature has dropped to the A/C cut-off point.
In other words, an air conditioner needs to run longer, and move more total volume of air through itself to drop room humidity than it does to just cool the air. So "bigger" cooling capacity or higher BTU capacity for an air conditioning system is not necessarily better, and it can actually be a problem.
Posted on Sep 30, 2012
My DC18 Allergy is blowing out dust from the rim of the first clear plastic cylinder under the removeable emptying compartment
Hi Angela, it's Jack at Dyson.
This sounds very unusual - by the time the airflow exits the machine it has passed through the Root Cyclone assembly, pre-filter and HEPA post-filter. It would be worth checking the black rubber bin base seal from the clear bin that sits directly above the HEPA post-filter, just to make sure this isn't missing or damaged.
If you need some help you're welcome to contact our experts directly. You can reach us by calling 0800 298 0298 (UK), 1-866-693-9766 (US) or 1-877-397-6622 (CA).
Mar 06, 2014 | Dyson DC18 Allergy Bagless Upright Vacuum
Tip
Dyson DC08/08T/19/19T2/20/21/29 - Washing the filter
To wash the pre-motor filter in your Dyson DC08/08T/19/19T2/20/21/29, please follow the simple steps shown in the video below. This procedure applies to the following Dyson variants:<br /><br />DC08 - Origin, Animal, Allergy, Carpetpro, HEPA, Base, Toolkit, DC08i, Standard.<br />DC08T - Origin, Allergy, Carpetpro, Complete, Animal. <br />DC19 - Toolkit, Allergy, Comet Exclusive, Plus Tools, Precision. <br />DC19T2 - Multi Floor, DC19T2i, Animal. <br />DC20 - Origin, Allergy, Animal, Stowaway Blitz It. <br />DC21 - Stowaway Motorhead.<br />DC29 - Exclusive, Allergy Parquet, Allergy Parquet Plus, Origin, All Floors, Allergy, Allergy Complete, Animalpro, Origin Plus.<br /><br />The filter should be washed every 3-6 months using cold water. Always ensure the filter is totally dry before refitting it - this may take up to 24 hours.<br /><br />For further help and advice please visit <a href="http://www.dyson.com/">www.dyson.com</a> and click on Support. <br /><br />Dyson Customer Service<br /><br /><utube src="TIsdhNkiIQs&feature=relmfu"><br />
on Jun 22, 2011 | Vacuums
Tip
Dyson DC08/08T/19/19T/20/21/29 - Washing the filter
DC21 - Motorhead.
For further help and advice please visit www.dyson.com and click on Support.
Pollen filter
The filter will clean most of the pollen and other particles up. Just be sure to clean or replace the filter regularly. Some modern air conditioners will let you know when they think the s dirty and needs to be replaced usually located in the front if u have allergies id say wear a mask and if u talking about a car it's under dashboard u can't miss it
Nov 25, 2013 | 2010 SsangYong Kyron 270
I want to change filters. please help
Hi and welcome to DixYa, I am Kelly
The only two parts requiring any service are the activated carbon pre-filter and the HEPA filter. No tools are needed. To change either filter, disassemble the unit as shown.
1. Loosen the carrying handle by turning it counterclockwise and lift filter cage cover from unit.
2. Lift HEPA filter and activated carbon pre-filter from the base.
3. Remove the fasteners from the activated carbon pre-filter and remove it from the HEPA filter cartridge.
4. Replace filter(s) as needed, and discard used filters.
5. Wrap the activated carbon pre-filter around the HEPA filter cartridge and secure it with the fasteners provided
Pictures are here:
http://www.american-allergy-supply.com/hd/hwc.htm
Thanks for choosing FixYa,
Kelly
May 25, 2011 | Honeywell Enviracaire 13520 Air Purifier
Hello, How can I clean the lower filter on our Dyson DCO8.
HI there,
By Lower filter i am going to assume you mean the one below the clear plastic dust bin. The machine you have described has a thick hepa filter (probably with a purple plastic rim) and unfortunately they cannot be effectively cleaned. If you are keen to try then I would suggest using an air compressor blowing from the top to the bottom.
What I would really suggest you do though is throw it out and replace the hepa filter with a new one. If you are in Australia I would try Vacuumspot or Nelson Vacuums.
Jan 01, 2011 | Dyson DC08 Hepa Allergy Bagless Canister...
Danby standup aircondioner ( 3 in 1) , does not MODEL APAC9030
Jul 13, 2010 | Danby Heating & Cooling
Miele Revolution Vaccuum cleaner manual
Under the download section is the owners manual. This is for the same series Miele that you have so this manual will have most everything you need to know. The black filter is a charcoal filter, this is good if you want to control the odor but don't have allergies. If you have allergies you might wont to get a HEPA filter. I would recommend changing the filter every 6 months to a year. You need to use the empty filter when you want to use it as a blower. The hose will not fit into the opening with the HEPA or charcoal filter in place. I hope this helps.
https://www.centralvacuumstores.com/item.php?id=4545#
Jan 06, 2009 | Miele Revolution 600 Bagged Canister...
Replacement HEPA filter for Danby DHCC6020?
We just ordered from Danby... call 1-800-26-danby... it's part number 6020.02
Nov 23, 2008 | Danby PHD DHCC6020 3-in-1 Home Comfort...
Heating & Cooling Logo
189 people viewed this question
Top Danby Heating & Cooling Experts
Dan Webster
Dan Webster
Dennis Boxerman
mintvl
Level 1 Expert
Are you a Danby Heating and Cooling Expert? Answer questions, earn points and help others
