Question about Bose 321GS Series II System
Mitsubishi big screen TV no sound! The TV is about 4 years old. The picture is great but as of 3 hours ago not a peep. When it's a snowy screen we can hear the static through the speakers, otherwise zip. Hope this helps you help me! :) Thanks, Caroline
I called my cable company and they reset our digital box. Problem solved!
Posted on Jun 04, 2009
Color distortion, hazy snowy screen with thin red lines, suddenly happened had perfect pic 24 hours ago
Tv have a problems known as a convergence problems,it dead.Tv have colors lines R,G,B mis alignments,have colors shadows pictures or 3D pictures look alike?The tv convergence board is dead.The tv convergence board require replacing 2 STK convergence ICS and some or all of it resistors too.To fixed the tv convergence board to solved the tv convergence picture problems.The shop,will cost u like $300-350 for parts and labors.
Feb 01, 2011 | Mitsubishi VS-50705 50" Rear Projection...
Sound takes up to an hour to come on, Mitsubishi 35'' tv
A $700 dollar estimate for a sound problem seems out of line - get asecond opinion (did some one look at it or just a guess). If the sound eventually comes on you probably have a connection (internal) problem or a intermittent part in audio section -cap o/p IC.
If you use a satellite or cable box can you hook your sound from that to an audio system thereby bypassing the TV?
Sep 30, 2009 | Mitsubishi CK-35308 35" TV
Mitsubishi VS-50707 screen is jittery when it first turns on
Sounds like the verticle circuit is failing a honest shop will take of this for you around 180-230 if you want to do yourself youll need a iron and some filters and an verticle ic
Sep 26, 2009 | Mitsubishi VS-50707 50" Rear Projection...
No picture; black screen; only red light blinking.
take to a service station i think just changing the displsy IC would do . but check in service centre
Jun 19, 2009 | Toshiba CZ32V61 32" TV
No picture
Try a "hard restart"', which simply means unplugging the power cord of your TV, and replugging it after 4 hours have passed. This technique helps to reprogram the electronics of your TV.
Hope this suggestion works for you.
Jun 05, 2008 | Mitsubishi VS-60607 TV
Mitsubishi VS-45607 45" Big Screen
Good Day, Delano1981;
It may cure the problem but I would suspect the 9 Volt source
CHECK C2P05 100 UFD 16 V OFF PIN 3 OF IC2P01 AND
IC2P01 PART # 270P466020 (9-VOLT REGULATOR). BOTH
ARE ON THE SIGNAL PCB.
This should resolve your TV"s condition.
Good Luck, big IRISH.
May 27, 2008 | Mitsubishi VS-45607 45" Rear Projection...
Mitusuhuibi big screen
start shopping around for new TV
good deal jan 1
Dec 14, 2007 | Mitsubishi WS-55807 TV
RCA F27650 27" TV - Snow Bursts
The model you listed, F27650 uses the new ATC113 series chassis, which is only about 3 years old. The ATC113 chassis is not known to have snowy issues, but if yours is then I would suspect that a solder joint is loose in the tuner. If your set is actually around 9 years old, then it might perhaps have the notorious CTC175 - CTC187 series chassis, which went snowy all the time due to cracked solder joints on the shield grounds around the tuner and microprocessor. In either case, some good quality resoldering should cure your trouble. If you have never done fine solder work on PC boards with small surface-mount parts, allow a qualified tech to handle it for you.
Aug 08, 2007 | RCA F27650 27" TV
Mitsubishi VS-5041 50 Inch Rear Prorjection TV No image but there is sound!
After 11 years???? OMG This set is a tired pup and should be put to reast. My experience with older sets and your complains are all capacitor problems and is only gonna get worse as the first time around repair will take several capacitors to repair. This set has no user serviceable parts inside so you should not attempt a repair suchj as this on your own.. This repair if you decide to go through the first time will be About 300 to 600 bucks the first time and cost will continue to raise till the sets put to sleep. Good luck
Jun 01, 2006 | Mitsubishi VS-50605 50" Rear Projection...
Bose 321GS Series II System Logo
484 people viewed this question
Top Bose Audio Players & Recorders Experts
Electro Med Services...
Ben Armstrong
Are you a Bose Audio Player and Recorder Expert? Answer questions, earn points and help others
