Question about Compaq EVO D510 CMT P4 2.5/20GB/256MB (268899999) PC Desktop
Installed Win. XP. Now no drivers for internet connection
The resolution is set too low and I can't change it. Seems in safe mode. Good old computer trying to get running. Given the retired computer from my job so I had to use Windows XP to wipe hard drive and start over. XP installed but that is about as far as I can go until I can connect to internet
    An expert whose answer gotĀ voted for 100 times.
    Sniper:
  • 80 Answers
Assuming you are able to post this means you have some sort of internet connection and the drivers will need to be downloaded from another computer and transfered through USB or other means.
Drivers for you computer (D510 convertable minitower) can be found at below link:
http://h20000.www2.hp.com/bizsupport/TechSupport/DriverDownload.jsp?lang=en&cc=au&prodNameId=97128&taskId=135&prodTypeId=12454&prodSeriesId=316510&submit.y=5&submit.x=6&lang=en&cc=au
Please rate this if it resolves your issue.
Posted on Jun 04, 2009
Input out of range
The problem is likely to be screen resolution too high in windows 8. Boot it to safe mode, (which should be at a lower resolution) and reduce it down to the lowest setting. Reboot to normal mode and then adjust your resolution to a higher setting that works. Alternatively get (beg, borrow or ... otherwise obtain) a monitor with a higher resolution and make adjustments required.
If it does turn out to be a driver problem, you should also be able to fix this from safe mode.
Jan 02, 2014 | ATI Computers & Internet
My monitor says out of range
You have set the resolution or refresh rate of your display adapter to a value which is too high than what is supported by your monitor.
In order to fix this, you have to do the following:
1. Reboot your computer & press F8 to boot into Safe Mode.
2. Once in Safe Mode, open Device Manager.
3. Remove the display adapter device driver form Device Manager.
4. Reboot your computer again. Windows will boot up normally & will detect the display adapter. It will prompt you for the device driver for the display adapter.
5. Use the CD that came with your display adapter to install the device driver. Once done, your problem is fixed.
Sep 01, 2011 | Insignia D300a PC Desktop
Hi, My monitor has dull display. After starting my computer, I could see the desktop but after few seconds it disappears. I am sure whats happening. Please suggest me what to do.
My answer will help Windows XP and Windows 7 users.
When the computer starts, start pressing F8 button. After several seconds you will see the following menu.
Safe Mode Safe Mode with Networking Safe Mode with Command Prompt ---------------------------- ---------------------------- ----------------------------
If you have Win XP, there will be a menu item as 'Enable VGA Mode'. In Win 7 you will see 'Enable low-resolution video (640 x 480)'
Select this option and press enter. (XP users will have to enter again).
After the computer is ready, goto display properties and save the resolution.
- In XP right-click on desktop, select 'Properties', Click the 'Settings' tab (last tab on top), and click 'OK' button.
- In Win 7, Right-click on screen and select 'Screen Resolution'. Click 'OK' button.
(Ignore any warnings)
Restart the computer.
Set the screen resolution again to a reasonable setting.
- Be careful! If you set it too high (if the monitor does not support the resolution you select), again the screen might disappear! (Sometimes this happen automatically after installing a game)
Jul 19, 2011 | Dell E176FPC Monitor
I adjusted resolution on my HP notebook now when I turn on cant see screen. Please help
Hi Jess,
Boot the computer in SAFE MODE by Restarting the computer, and the moment its on keep tapping the F8 key untill you see a screen saying "Windows Advanced option...".
1. Select Safe Mode using the keyboard arrow key and hit enter.
2. This will load all basic drivers to start safe mode operation.
3. Go to Display Properties (WindowsXP) or Display Settings (Windows Vista) by right click on empty blank space on Desktop, then select Properties(Windows XP) or Personalize(Windows Vista).
4. Then change the resolution by sliding the Low to High slider bar. Do not press "OK" or "Apply" at this time.
5. Instead, click on Advanced Settings, and then click OK. Windows in Safe Mode will change the screen resolution according to new settings, and prompt a "Monitor Settings" dialog box prompting that desktop has been reconfigured, with countdown timer. Click on Yes to keep the new settings.
6. Alternatively, simply click on Advanced, go to Adapter tab, then click on List All Mode. Select a mode with screen resolution size and color mode that you prefer, and click on OK. Windows will apply the new resolution size and color quality on Safe Mode too.
Regards
Riztech
Oct 17, 2010 | HP Mini 1000 Netbook
When Windows XP tries to load, I get the following message: "We apologize for the inconvenience, but Windows did not start successfully. A recent hardware or software change might have caused this." My...
indicates that the hard drive is starting to fail
save everything to an external hard drive
have the system tested by an computer repair shop and if faulty install a solid state hard drive that has no spinning disc
also up grade to win 7 operating system as win xp is no longer supported by Microsoft and many other products are not compatible with win xp
Aug 10, 2017 | MSI Wind U100-423ES Notebook
Emachine t3104 installed the VIA/S3G UniChrome Pro IGP Video Driver on my win xp then changed the color to 256 trying to resolve a java vm issue and gave me a message to change the resolution, but when the...
go to the safe mode by pressing f8 at startup.
in safe mode set the resolution to its default and restart. this will now run in normal mode.
dont forget to vote...
Sep 13, 2009 | E-Machines eMachines Desktop PC
Error: Cannot Display This Video Mode
You may have to boot into safe mode and reset the video settings to a safe setting like 1024x768.
  1. To get into safe mode, continuously press F8 while the computer is booting up.
  2. Eventually you will get a Windows XP Boot Menu.
  3. Choose the option for Safe Mode.
  4. Go to Start, Control Panel and double-click Display.
  5. On the Settings tab, drag the slider bar to 1024x768.
  6. Click OK
  7. Shut down and reboot.
If the problem goes away, then you are good. Otherwise, you'll have to boot menu again (F8) and choose Enable VGA Mode.
Aug 29, 2009 | Dell OptiPlex GX620 PC Desktop
Trying to install a logitech rj45 network adapter (ethernet card). I have xp. BUT (a) the computer does not list it under network adapters (i already have one which i think is integrated on the motherboard...
Dear sir,
Welcome to once again Fixya support
According your problem it seems to be your try to install faulty Network card. So better is check with new good card.another possibility is some time pci slots fail to recognise a hardware, so try it with another pci slots of mother board.According to you onboard network card is dead, means motherboard fails to work when connect to a network,after successfull installation of network card also the possibility of motheboard not allow you to work with new network card ,same situation may arise,i am also managed same problems in several customer place while working as an computer hardware engineer.So try with new network card it may solve your problem
good luck
Jul 23, 2009 | Computers & Internet
HP Pavillion dv9000 will not boot up in normal mode, only safe.
Have you tried an XP repair?
Then you can save your data .
XP repair
When you boot with the Win XP install CD-ROM, it loads a minimal operating system, similar to DOS, but compatible with Win XP. At the first screen you select install Win XP (not Recovery Console) and at the next screen it will find that you already have Win XP and offer to attempt a repair. This repair should not touch your Applications or data; it just reinstalls the Windows files. This is great because when it works you don't need to reinstall all your software.
If I could be of further assistance, let me know. If this helps or solves the issue, please rate it.
Thanks, Joe
Jul 18, 2009 | HP Pavilion dv6208nr Notebook
Task-bar & start-menu disappeared
Sounds as if the video card is going down. This is a common problem on these laptops. Have you checked Device Manager to see if the drivers are installed. Hit Win key and pause then select hardware and Device Manager. If nothing seems out of place there then I would most certainly suspect the video card. This is part of the motherboard and not replaceable.
As another check try connecting the laptop to an external monitor via the VGA connector at the back. The resolution problem should be resolved then.
Dec 08, 2008 | HP Pavilion dv6000z Notebook
Computers & Internet Logo
290 people viewed this question
Top Compaq Computers & Internet Experts
Abhinandan  Patil
Abhinandan Patil
mukhtar21 shaikh
mukhtar21 shaikh
Are you a Compaq Computer and Internet Expert? Answer questions, earn points and help others
