Question about Canon PIXMA MX310 All-In-One Printer
How do i fix the setting reccomend new b crt?
My Hyundai tv 74 cm The color it not show good
Nice big screen but CRTs are getting old So, if you can't set correct colors with your Hyundai it might have some serious issue with tube. Probably replacement might cost you more then a new new 27" Flat Panel. See some tutorial and info about bad color of CRT
Fix your own CRT Television Color Problem
How To Diagnose Bad CRT or LCD Monitor
http://www.electronicrepairguide.com/monitor-color-problem.html
LG M2762D 27 Inch Widescreen 1080p LCD TV Monitor Black
LG Electronics LG M2762D 27 FLATRON LCD TV widescreen 1080p FullHD HDTV...
RCA F27440 27 CRT TV
Samsung TXN 2798HF 27 Tantus CRT TV 1080i
Aug 02, 2015 | Televison & Video
Reboot when playing games
You'll need to check your system logs to see what caused the reboot. Usually it's a graphics problem that can be fixed by upgrading your GPU. Without knowing which one you have I couldnt reccomend one but I do reccomend rebuilding your machine (put all your data either online or on external storage and then install a new operating system and all drivers - will be clean and fast again)
Mar 20, 2012 | Compaq Computers & Internet
Hp 5550n printer its giving Error "59.C0" i think it's related to motor how i can know the part number for the motor witch ineed to replace ? and how to install the new one...
59.C0 indicates the disengement motor problem.
HP reccomends reseating J16 on the motor and J1100 on the DC controller
Then the 1st part they reccomend replacing is the disengaging drive assembly
Finally replacing the DC controller PCB itself.
Any of these jobs should be performed by and experiance qualified technician as none are "easy fixes"
Mar 17, 2011 | HP LaserJet 5550DN Printer
I cant dawnload flash player
the router might be defective or try to reset it, off and on both the router and the modem and try again, try also to consider your dsl it there might be upgrading in your area. if it did not fix your problem, just buy a new router and i recommend LINKSYS ROUTER
Mar 05, 2011 | Computers & Internet
The retractable seat belts in my 1990 honda accord LX coupe only work sometimes. Is there something I can do myself to fix this problem. cheap and inexpensive.
you can attempt to repair the inertial retractors, I have done so on many of my own vehicles in the past... However, the tensioning spings and other parts may be worn to the point of dangerous consequences without any warning! I highly reccomend you purchase new units or at least get a good used set from a respectable salvage yard.
Sep 09, 2010 | Honda Accord Cars & Trucks
Cannot receive fax. It goes into memory. LCD reccomends new B-CRT regarding my Canon PIXMA MX310 printer . No problem sending fax,copying or printing.
B-CRT is just asking for a new black cartridge, fax will not print until it's replaced so you don't get a partial fax that you can't get back after printing.
Nov 05, 2009 | Canon PIXMA MX310 All-In-One Printer
Moniter colour gone pink
Cables do periodically go bad. But If I were you I'd be more worried about a bent/broken pins on the end of the cable. Take a flashlight and shine it on the pins on both end of the cable to see if they have any bent/ broken pins. If you do see a broken pin you will want to check the connectors on both monitors to make sure you don't have a broken connector pin stuck in them. Also  If the broken pins are stuck in the monitors I'd reccomend going to an electronics repair shop to have them fix it for a low price, But this is a worst case scenario. I'd bet its just a bad cable, or the cable just went bad.
If you don't see any signs of broken pins, then I'd reccomend getting a new cable and a higher quality/heavier duty one.
If its a "VGA"(analog) cable with blue connectors, I would reccomend upgrading to a HDMI or DV(Digital format) I cable if possible. And if thats not doable and you must use VGA for some reason I'd reccomend getting a heavier duty cable from an online shopping site like newegg.com. I personally just got a Rosewill VGA cable and it works perfectly for me. Just make sure you get the correct female-female connector types and also make sure its the appropriate distance. And remember if your getting a VGA(analog cable) the shorter or less cable you need the better, since analog cables degrade over larger distances.
May 24, 2009 | AOC CT720G 17" CRT Monitor
My tv seems to be hazey how do i fix
You have contaminated fluid in the blue and green picture tubes.I do not reccomend that you try this repair.Very difficult.A repair shop should be able to get this set looking like new again for about $275.
Dec 12, 2008 | Philips 60PP9202 60" Rear Projection...
19 " laptop monitor drivers
On Notebook monitors it is reccomended that you set the monitor at the optimal resolution that is reccomended by the manufacturer (usually the highest) Based on my experience , it is normal for a laptop to display fonts kind of iffy at lower resolutions. This is because image stretching is taking place and things are out of proportion.
Aug 21, 2008 | Medion Computers & Internet
Red CRT is dim....
Yes I did. You will need to get a service manual for this TV set to trace the voltage coming from the sweep power supply. If this is a problem that is new after you replaced the convergenbce4 board, you for sure have a broken wire or connection somewhere in the set. Have seen this happen may many times after a novice repairs a TV set. Good Luck
Sep 06, 2007 | Samsung HCL4715W 47" Rear Projection...
Canon PIXMA MX310 All-In-One Printer Logo
842 people viewed this question
old marine
old marine
