Question about Symphonic ST420FF 20" TV
Color the color has gone all phlooey and the color control on the menu cannot correct it.
  • Anonymous Dec 30, 2007
    color is all different along the edge of the screen
  • 93 Answers
Did u check the chroma chip
Posted on Oct 24, 2007
No color
Have you gone through to the system menu and checked the colour settings for the screen
Jan 21, 2014 | Bose Lifestyle 135 Home Entertainment...
My dell 1201 projectors displays only in yellow
you have most likely lost 2 of your color guns, most projectors have RED, Green and BLUE as the projector colors (some newer projectors have added a 4th color). if one of your color guns has gone out, you may experience colors that are not correct. that is where I would start. go to the convergence routine, in your setup menu. this is where you can determine if one of your "guns" has quit working.
Mar 23, 2011 | Dell 1201MP Projector
Sharp XR1S It projects the image on screen, use to show the correct color. last time the image was projected but in pink hues. is this an adjustment issue or is the lamp going or gone?
first of all check the tint setting on your projectors picture menu.
if not get the correct color then, your projector is a dlp projector that means it have a color wheel in side. if the synchronization of color wheel is not correct this problem can occur. there is a sensor for couting the rpm of color wheel. also have a black mark on the color wheels rotating portion. the sensor scene this black mark for making count. if there is any dust in that portion it will make difficult to the sensor making the counts. you have to remove the color wheel to clean the same.
i have added a video how to clean the color wheel . not the same projector.
Feb 02, 2011 | Sharp XR-1S Multimedia Projector
HI,the color on my monitor has gone blueish its like
try reseating or/replacing the cable. If the connection isn't good then you can lose one of the three basic color channels resulting is a tinted screen color
Jan 08, 2010 | Acer AL1916B 19" LCD Monitor
Wavy colors across the screen and the color has separated. ghosts on picture -four eyes ect. I can't adjust the convergence.
This is a common problem. Your convergence has gone out.
Common symptoms are...
1) 3D Video
2) Warped Video
3) Convergence menu does not adjust the red or blue correctly.
Go here for a solution...
Sep 05, 2009 | Samsung HCL4715W 47" Rear Projection...
How to apply color to start menu and taskbar in windows vista
These little things can drive you let's go...Right click in an open area of your desktop-at the bottom of the box that opened- click on Properties then- Appearance tab- under Windows and Buttons- select -Windows Classic style. Now in the -Color scheme- select Rose or whatever color you like...then click on Apply and then OK.
I think you are missing the Apply and then OK.... this will do it for you, Enjoy your world of Roses..bye
Mar 21, 2009 | Dell Inspiron 1525 Laptop
Red has gone off from the blue and green
you can use color managemnt option on your t.v to fix this problem. Also some newer tvs now have grid color managment, which lets you play around with it and let you pick what you want or where you might need or not need the color.
Feb 07, 2008 | Philips 46PP9302 46" Rear Projection...
Color printing problem~only green, yellow, blue
The TekColor correction options provide simulations of different color devices. Automatic is the default correction for general image processing. Use the following table to determine what option you want to use.
Automatic Applies the best color correction to each graphic element: text, artwork, and photographs Office Color sRGB Display: Approximates the colors on a computer display.
sRGB Vivid: Produces brighter, more saturated colors than sRGB Display. Press Match SWOP Press: Matches specifications for Web Offset Publications.
Euroscale: Matches Fogra glossy paper specification.
Commercial: Approximates U.S. commercial press target.
SNAP Press: Matches specifications for Newsprint Advertising Production. None Applies no color correction. Use with other color management tools, such as International Color Consortium (ICC) profiles, ColorSync, or the PANTONE Color Chart for the printer. Black & White Converts all colors to shades of gray
From the workstation, select the color correction in a supported driver.
Microsoft Windows 98 SE / ME / 2000 / XP/ Server 2003 / NT 4.x Operating Systems (OS):
NOTE: Some of the color corrections are grouped under Office Color or Press Match.
  1. Within an application, click [File] from the toolbar, and then select [Print] from the menu. The Print window will be displayed.
  2. Click on the [Properties] button located on the top, right of the window. The Properties window will be displayed.
  3. Click on the [TekColor] tab.
  4. Select the required color correction.
Apple Macintosh OS 9.x:
  2. Click on [General], and then select [TekColor] from the pull-down menu.
  3. Select the required color correction.
Apple Macintosh OS X, (version 10.2 and higher):
  2. Click on [Copies and Pages], and then select [Image Quality] from the pull-down menu.
Dec 05, 2007 | Xerox Phaser 8500/DN Printer
Symphonic ST420FF 20" TV Logo
23 people viewed this question
Top Symphonic Televison & Video Experts
Computer Repairing
Computer Repairing
matt martin
matt martin
Are you a Symphonic Televison and Video Expert? Answer questions, earn points and help others
