Question about Nikon 20MM F2.8 AF NIKKOR Lens
Repairing 20mm af nikon lens diaphragm lock
The diaphragm lock on my 20mm 2.8 AF Nikon locks but the camera (D100) it's on doesn't see that its locked anymore? HELP!
  • 1 more comment
  • Kibo Dec 23, 2007
    Thanks for the reply - The lens works on a D200 & F100, but not a D100. So I guess it is not the lens. But the lever you describe seems to be working fine on the 100.
    Appreciate your help,
    Kibo
  • Kibo Dec 23, 2007
    This is the only lens (7) I have that doesn't work on the D100. I also have a 50mm same vintage and type and it works fine. I've checked and cleaned everything I can find on the 100 and the lens. Thanks for the suggestions! I have a feeling that it may be the diaphraghm activeation lever on the body or lens that aren't alligned correctly.
    Kibo
  • Anonymous Mar 27, 2014
    is it compatable with the Tamron 18-270mm f/3.5-6.3 Di II VC PZD AF Lens
    Scholar:
  • 48 Answers
Since this lens is the only one with a problem, it sounds like the EE tab on the aperture ring is damaged or missing. The EE tab is a small protrusion on the rear edge of the aperture ring at the 4:00 position when you view the lens from the rear with focus index at 12:00 and aperture set to highest number. That EE tab is what pushes the microswitch cammedic mentioned. The D200 recognizes it fine because it doesn't use that EE tab to sense minimum aperture setting, it uses the AI ridge.
Posted on Feb 07, 2009
  • 667 Answers
I'll offer the same answer I just gave on a D200 question: With the lens off, look at the camera mount area. If you are looking straight at the mount, there is a small tab sticking out at about 7oclock on the outside edge of the mount ring. The tab is spring loaded and may be damaged. You should be able to push the tab toward the base of the camera and it will snap back if functioning properly. If it feels loose or doesn't spring back, then switch that ab controls is not being activated.
Posted on Dec 23, 2007
  • Kevin Pettit
    Kevin Pettit Dec 23, 2007
    Ok, try another lens just to make sure. The D100 may have dirty contacts at the top of the mount area. Make sure the pins on the lens connector are springy and clean on the 20mm
Diaphragm stuck
It's serious enough that you will not be able to fix it yourself. You should send your lens to Nikon for a repair estimate. You will find information on the Nikon USA website regarding where your closest Nikon Repair Depot is located and return procedures.
May 29, 2013 | Nikon Nikkor 55-200mm f/4.5-5.6 G AF-S...
My camera won't take pictures and up in the righthand corner, it reads fE E when I press the shutter. I have the Nikon AF Nikkor 28-105 lens affixed (1:3.5-4.5D)
Turn the aperture ring on the lens to its smallest setting (largest f/number) and lock it. You control the aperture from the camera, the same way as on a lens without an aperture ring.
Feb 06, 2011 | Nikon D100 Digital Camera
I have a D90 Nikon, I mounted my Nikkor 50mm 1.8d
Make sure you set the aperture ring on the lens to its smallest setting (largest f/number) and lock it. Without doing so, the lens will not communicate properly with the camera and thus you will not get the autofocusing.
May 30, 2010 | Nikon Normal AF Nikkor 50mm f/1.8D...
Lens is jammed....
Try switching between MF and AF mode and seeing if you can free the lens. If not then your AF motor has probably locked up and will need professional attention to release/repair.
Jan 18, 2010 | Nikon 18-70mm f/3.5-4.5G ED-IF AF-S DX...
Nikon d3000 autofocus issue
you should change the focus lock to AF-S, instead of AF-C
Jan 02, 2010 | Nikon D3000 Digital Camera
Error message shows F -- with lens attached. Lens was cleaned with compressed air, now willnot work. Lens type Nikon 28-80 AF
Check to see that the lens aperture ring is set to the smallest (largest numerical) aperture setting (usually f22 or such). Nikon AF cameras have to have their lenses set at the smallest aperture for most of their program modes to work. Nikon AF lenses have a small slide or twist lock adjacent to the aperture ring to lock it in place at the smallest aperture. This may have been unlocked during the cleaning.
Another possibility is that the lens's electrical contacts were damaged during cleaning, so the body is not "seeing" the lens. Do you have another lens you could attach to the body to test this theory?
Aug 06, 2009 | Nikon N50 35mm SLR Camera
Nikon DX AF- S Nikkor 18-55 mm lens won't Auto focus
Is the switch on the side of the lens set to manual or auto? Sometimes it's the little things like this that we don't notice.
Apr 16, 2009 | Nikon Normal AF Nikkor 50mm f/1.8D...
Nikon SC-29 REMOTE CORD
Hi Kathy,
Are you ready?
1. Make sure the Nikon SC-29's Red Panel's Lock Switch is set to the Left. Pointing at Left Black Screw.
2. Connect the Nikon SC-29's (Red Panel) to your camera's Hotshoe by pushing it as far as it goes.
3. Turn Lock Switch to the Right (turn CW). This locks down to camera.
4. Make sure Nikon SC-29 (other ends) AF-ILL is set to OFF.
5. Make sure your Nikon SB-800's Lock Switch is set to the left side.
6. Attach your Nikon SB-800 into this Hotshoe.
7. Switch the Lock Switch on flash to the right.
8. When you wants to AF from flash, set AF-ILL to "OFF"
9. For the best results, set AF-ILL to "ON".
I teaches, do repairs, services and modifications on all photographic equipments.
I hope they are helpful to you as well as for any Nikon Photographers using the Nikon SC-29 Cable.
Mine has Autofocus, ITTL, Slave and Wireless Radio Remote Flash.
Truly,
atdlee@netzero.com
Jan 31, 2009 | Cameras
Nikon D100
izzy41,
make sure the lens is properly connected and aligned, if it has been remove recently it may not of been put completely back to the right position causing the contacts to not align. Turn off the camera and remove and then remount the lens. The motors and the cost to replace/repair are almost as much as a new lens. Your lens can and should last a long time unless it has recently been dropped or tried on a camera (forced) the wrong way and the contacts were bent or damaged.
randy320sgi
Nov 29, 2008 | Nikon D100 Digital Camera
Nikon 20MM F2.8 AF NIKKOR Lens Logo
591 people viewed this question
Top Nikon Cameras Experts
Steve
Jeff Marcus
Are you a Nikon Camera Expert? Answer questions, earn points and help others
