Question about Intel S6240 Notebook
My notebook (Fujitsu Lifebook S6000 series) screen back light just died. How do I fix it and what type of backlight do I need to get?
  • camila_buech Jun 04, 2009
    My screen is completely black and it still boots up into windows.
  • Ben Wabnick
    Ben Wabnick May 11, 2010
    Do you have a dim screen or a completely black screen? Also does the laptop still boot up into windows?
  • Intel Master
  • 32,281 Answers
You most likely have a defective screen - a defective inverter or a CCFL lamp or simply the video cable needs reseating. After reseating the video cable and the problem is still there then :- To determine if you have a LCD screen or video card problem, read this and follow the instructions. Defective CCFL backlight, it may have the following symptom: Screen flashs on red/pink and off. Picture stays on in red and slowly be come normal. Picture flickering with dim display or appear black. Picture flickering on and off. All these symptoms indicate that the LCD backlight lamp (CCFL Lamp) has reached the end of the life and all you need to do is replacing the CCFL lamp Connect an external monitor to your laptop and power it up, if you see the normal Windows images then the video card and laptop is OK and the problem is definitely the backlight. Dim image and/or dark display on the laptop's LCD screen indicates a faulty LCD backlight and it could be the inverter that supplies high voltage to the CCFL lamp or it is the CCLF lamp is nearly burnt out or burnt out, most likely this is the case. The inverter can be replaced easily but the CCLF lamp is more time consuming and requires soldering skills. Check out www.lcdparts.net for parts, repair service and DIY info.
Posted on Jun 04, 2009
Lifebook c series no display
If your laptop appears to boot up and the hard disk LED flashes, then the problem is probably a back light fault. This can be a faulty inverter or a faulty CCFL lamp. Please click on this link and follow my instructions to identify the fault and possible fix :- http://www.fixya.com/support/r3598095-faulty_laptop_lcd_screen
Feb 06, 2013 | Intel Fujitsu LifeBook S7020 NoteBook...
Need an owners manual for fujitsu lifebook s6000 notebook
Here's a link where you can download the manual for your Lifebook. Though you need to specify the exact model. (ex: S6110, S6120 etc)
http://support.fujitsupc.com/CS/Portal/support.do?srch=GUIDES
Select "Notebook PC" under the 'product', "S series" under the 'series' and the exact model of your Lifebook under the 'model' box.
Hope this helps.
Sep 09, 2011 | Computers & Internet
Lifebook S6110. .Batt lcd says power ok. hdd operates. no display !6v ok from psu. No backlight or display from screen. Both memory replaced with good ones and symptom repeats. What can it be??
If your laptop appears to boot up and the hard disk LEDflashes, then the problem is probably a back light fault. This can be a faultyinverter or a faulty CCFL lamp. Please click on this link and follow myinstructions to identify the fault and possible fix :- http://www.fixya.com/support/r3598095-faulty_laptop_lcd_screen
Jun 17, 2011 | Fujitsu LIFEBOOK S6110 PC Notebook
I'm using fujitsu life s series s7211 and could not start up my laptop . the fan is running, the battery icon is showing, but no screen.
Try to unplug the power from the back of the notebook and take out the battery and any other accessories. While no battery and power, press the power button for 10 seconds to drain everything inside. Plug the power back, turn it on w/o the battery. If you have a POST screen then try to go Fujitsu website to see if there's a new firmware for the notebook. If no screen then you need to take it to a tech/repair shop.
Mar 19, 2011 | Fujitsu LifeBook S7211 Notebook
What are the specs of a fujtsu lifebook s4572
here's the link
http://www.fujitsu.com/vn/en/news/pr/fpcap_20010521-03.html
Jan 18, 2010 | Fujitsu LIFEBOOK S4572 PC Notebook
Adding memory to Fujitsu LIfebook Series A3040
You remove the access cover which is where the power button is right under the screen by sliding it to the left until it comes off.Then you push the keyboard up to the back of the laptop until it will lift up exposing another cover. You remove the second cover and that is where the ram is located.Ram is under the keyboard.
Oct 09, 2009 | Fujitsu Siemens LIFEBOOK A3040 PC Notebook
Display problem in Fujitsu LifeBook C Series(c-6631
the internal bulbs of ur monitor screen have deteriorated...the manufacturers are real smart, these monitors dont last forever. So if repair estimate is too expensive then replace the whole unit.
Always purchase laptop or notebooks NEW or never more than 5 years old.
May 24, 2009 | Fujitsu LifeBook C6631 Notebook
Wont completley load up just ends up to a blackscreen
You could have a defective screen - a defective inverter or a CCFL lamp.
To determine if you have a LCD screen problem, read this and follow the instructions.
  • Screen flashs on red/pink and off.
  • Picture stays on in red and slowly be come normal.
  • Picture flickering with dim display.
  • Picture flickering on and off.
Apr 22, 2009 | Fujitsu LifeBook A3040 Notebook
Fujitsu Lifebook N3520 - Screen pixellates and goes blank
lol, sounds like the deathbook to me.... try reverting to the last version of the video driver, uninstall the current one if u need to, but try it, it helped me with my dell when it did the same thing,
Nov 25, 2008 | Fujitsu LifeBook N3520 Notebook
Intel S6240 Notebook Logo
1,566 people viewed this question
Top Intel Computers & Internet Experts
Tony
Alun Cox
David
David
Are you an Intel Computer and Internet Expert? Answer questions, earn points and help others
