Question about JVC AV-32D303 32" TV
I CAN'T TURNED ON, BUT THE TIMER LIGHT IS ON AND SOMETIMES IS BLINKING.I TRY BY THE POWER BOTON AND REMOTE.I DISCONNECT THE PLUG FROM THE WALL AND CONNECT BACK AGAIN BUT DON'T WORK.
  • 378 Answers
Probably your problem is inside the tv, the IC component maybe damaged.
Posted on Jun 04, 2009
Casa Vieja ceiling fan w/remote; worked well. Then wall switch was turned on/off, chains pulled. Everything working: fan high, med and low, and light on/off/dim - except now fan won't turn off !
The chain pulling and switch flipping causes the simple logic in the remote receiver to become confused. Your only hope for restoring normal operation (short of replacement) is to disconnect power at the source, then remove remote battery and press all buttons to eliminate "stuck button" problem. Reconnect power and test operation using only the remote. If normal, you will have to decide whether to disable pull chains, wall switches, or both. If not normal, you will have to try an infinite number of combinations of pull chains, wall switches, and power on-off to get things back to normal.
Aug 11, 2016 | Casa Vieja Dryers
A power outage last night. The tv was off, now it wont turn on. A blinking timer light on the front of tv is on.
Always include model numbers since problems are sometimes associated with particular models. This may be a sign that a line surge during power fluctuations has damaged the power supply. There are a least two supplies in any modern set; a small supply that provides voltage to the remote circuitry and this one is always on. The second supply is the main one that is turned on when the set is to be used. Reluctance to turn on is often a signal that certain components (capacitors) are failing in the main supply and they will continue to degenerate. Try pulling the plug and leaving the set overnight without any power. If a circuit is only 'confused' (locked up) this should reset everything. If it still will not turn on, then either the small supply for the remote circuitry was damaged during a surge or that the main power supply is not responding to the power on command.
Jun 09, 2011 | Mitsubishi Televison & Video
The power light is constantly blinking in yellow. before this happened the yellow light was on without blinking I turned it off, once I turned it back on the light turned green but the screen...
try unplugging your t.v for 10-20 seconds. plug it back in. if your power light continues to flash your t.v is the issue. you should be able to google your issue or check your owners manual about the problem. unplugging the t.v is the last ditch effort. Good Luck!
May 18, 2011 | Akai LCT2715 27 in. LCD Television
My 32LG350 wont turn on. I just pluged it for the first time i bought it like a month ago. it was working but suddenly it turned off by itself and wont turn on either by pushing the TV on/off boton neither...
Try unplugging the the TV from the power outlet for 30 seconds to a minute and plug back in again. Try to turn on again. Some TV's have to be in a "ready mode" to operate by remote - so besure it is in that mode - or use the power button on the TV.
Apr 01, 2011 | LG 32LD350 32 in. LCD TV
I was playing a game and it made a sound then shut off now my on timer light is blinking. when i unplug and plug back in the timer light stops blinking for a second then starts again.
Something shorted in the set, possibly the horizontal output transistor or a power supply diode. The reason it starts blinking again after plug in is because JVC try to come back on if they were on when the problem started. In other words, if it quit while it was playing it will always be in the on position until the problem is repaired and it can be turned off normally. Have a shop check it out for you. There are a lot of things that can cause one to go out. Thanks
Nov 01, 2009 | JVC AV-27020 TV
Fujitsu Heat Pump - problems with timer? When starting the heat pump - the operation light, together with the timer light blinks twice, then the operation light blinks another five times. Then the...
I had the same problem. The heater did not work in heating mode. However it was OK in air-conditioning mode. The operation light and the timer light blink twice and then the operation light blinks for 5 times followed by few seconds non blinking, then the cycle repeats again. I have read on the internet that you better unplug the power cord and then plug it again so that the heater re-sets itself. My only problem was that my heater is directly plugged to the power with no visible plug. So I went to the main distribution board and put off the power for about 20 seconds for the whole home. HOORAY!! The heater worked after that.
Jun 24, 2008 | Fujitsu Heating & Cooling
Green power light will not stop flashing and tv will not turn on or off
You need to replace the 1000uf capacitors on the DM board thats the classic symptom of the DM caps being bad the light continues to blink repeatedly. If you need more info on the repair let me know.
May 15, 2008 | Mitsubishi WS-55909 55" Rear Projection...
Blinking green timer light
Check C81A2, C81A3, C81B3 and C81B4 (1000 uFD, 16V, 105C) on the DM PCB.
Check C8F19, C8F21, C8F22 and C8F27 (1000 uFD, 16V, 105C) on the FMT PCB.
If any are bad, replace all of them with part # 181P734030 (680 uFD, 16V, 105C).
May 07, 2008 | Mitsubishi WD-62725 62" Rear Projection...
Green Blinking Timer Light Mitsubishi WD-62527
hold the menu bottun for 10 seconds
after press power
see if that works
Sep 22, 2007 | Mitsubishi WD62527 62 in. LCD HDTV
Won't turn on
Still have the tv?  I can  help you  910-8936663
Mar 25, 2007 | Akai PT5492S 54" Rear Projection...
JVC AV-32D303 32" TV Logo
105 people viewed this question
Top JVC Televison & Video Experts
Jaime Hernandez
Henry  Thomas
Henry Thomas
Are you a JVC Televison and Video Expert? Answer questions, earn points and help others
