Black Flat Screen, sometimes works for a second
My LG flat screen has gone black. I double checked the connections at PC and screen. Can't find driver to reload. Any suggestions?
  • Ben Wabnick
    Ben Wabnick May 11, 2010
    Are you getting any lights to come on the monitor at all?
    Scholar:
  • 47 Answers
This is most likely the power inverter board in the monitor - this is common in many monitors. If it started taking longer and longer to display an image, and the power light is blinking on-and-off, that's most likely the problem. You can confirm that it's actually the monitor and not your computer or the cable by plugging in another monitor if you have one to try. If it's under warranty, send it back, if not, there are inverter boards for many common models of LCD monitors that are replaceable. The board can run anywhere from $50 on up. Depending on how old your monitor is, and how much you've invested into it, you may find it better to just replace it with a gently used one from ebay.
Posted on Jun 18, 2009
My LG TV set (LG brand) has a black thin double horizontal line at 1/3 of screen from the bottom,how to fix this?
If this is a LCD or LED your panel is bad. If it is a plasma you have a bad driver board, ribbon connection to the driver board or a defective panel. Panels in either case are not worth replacing.
Feb 26, 2015 | LG Televison & Video
Replaced digitizer now black screen only
If the LCD was working before replacement, the most likely suspect is a loose cable connection. It is also easy to crimp those tiny flat cables, or to break the locking mechanism so the cable can work its way loose. Sounds like you booted to a black screen after repair, so I would walk back through it and double check every connection, then look at all cables closely in bright light and with a magnifying glass, to be sure nothing sustained damage (twist, crimp, etc.). Remember to check the power cable to the LCD, as well. No power, no backlight, no video.
Mar 22, 2014 | LG Electronics Unlocked Optimus G Slate...
LG M227WDP turns black a couple of seconds
Do you have the "sleep" mode turned off on the computer?
As well, you can try different screen resolutions and refresh rate settings on the video section of your computer. That might make the connection to the TV more stable.
Nov 27, 2013 | LG M227WD-PZ LCD TV
Connecting pc to tv - tv shows pc screen then goes black
Try running through all the different resolution settings on your laptop, some tv's are very specific about which resolutions will display and which won't.
Nov 06, 2013 | Televison & Video
My Logik TV has no picture - it has sound. It has been doing this since I purchased it 5 years ago after just over a year. I tried getting them to fix it but they looked at it and made it work for a...
  • lucky goldstar some re solderings activity special on some supression coils in the backlight inverter/power supply and a little capacity roling not always but maybe but its not an easy problem sometimes connecting fcc sheets trouble , sometimes wet cleaning of the screen made problem on contact sheets on the screen that will give some different troubles. search some hobby technical people who can repair it , but repair or patch up the problem are 2 different things in case of this kind of problems on LG flat panel screens
  • here some things to watch there are several options https://www.youtube.com/results?search_query=lg++flat+panel+screen+repair
LG 42LE5500 Service Manual
Jul 12, 2017 | LG 32LD550 32 in. LCD HDTV
I double clicked an icon and the screen went black.now on srart up the screen goes blank after power saving mode
Try it on another PC first, if it still does not work then you will need to open it up, most failures are in the power supply section due to bad caps (leaking/bulging tops)
http://s807.photobucket.com/home/budm/allalbums
http://en.wikipedia.org/wiki/Capacitor_plague
http://www.badcaps.net
May 21, 2010 | LG Flatron L1951S-SN 19" LCD Flat Panel...
Screen went black...audio still working..Shuts off after 5 seconds..LG 32lcd7d 42" flat screen
Ur LCD inverter backlight board is dead.Replaced this LCD inverter backlight board.U will get ur picture back.Tries websites Shopjimmy.com,Ebay.com to buy a refurbish LCD inverter backlight board for the replacement.It a long board in shape.
Mar 15, 2010 | LG 32LC7D Television
Have LG 42 inch plasma, 1 inch black line down center of screen, picture good other than black line blocking center of screen, comes and goes sometimes
Sounds like the middle scalar board is defective. Since the issue comes and goes it could just be a loose connection to the between the scalar board and the PDP Module (plasma panel).
Great caution needs to be taken when checking this connection because it is a ribbon cable connection it and needs to be put in correctly aligned or it could cause a short in one of the circuit boards.
Oct 07, 2009 | LG 42LC2D 42 in. LCD HDTV
Screen going black on LG60PG60 TV
It does seem to be a tv problem, check the input connector to the tv next time when it happen, this tv seems to have problems with connectors or could be the video processor good luck
Nov 22, 2008 | LG MU-60PZ11 60 in. Plasma Television
Computers & Internet Logo
200 people viewed this question
David Payne
David Payne
