Question about Maxtor MaXLine Pro 500 500GB 7200rpm 300MBps Serial ATA II Serial ATA/300 Internal (7H500F0FT) Hard Drive
I was given a MAXTOR 500 GB SATA HDD which I installed into my desktop. Once powered up, the HDD had an audio (almost chime)tone. The desktop installed the drivers but would not display the HDD in MY COMPUTER directory and it could not be accessed. My question is then this: Is the audio chime an indication of proper operation or is it a error POST? How can I determine what to do about it? I cannot find any references relative to serial ATA drives POST codes/audio chimes. Anyone out there with a solution? . All responses are welcomed!!!!
  • 489 Answers
Hard drives do not generate audio tones for error messages or POST codes. Any problems should be reported by the BIOS on boot. The disk may not be showing up under Windows Explorer for other reasons, so...
Open up Disk Management (right-click on My Computer for XP, Computer for Vista) and select Manage from the context menu then select Disk Management from the left-hand pane. In the middle pane, scroll down until you find a disk that is Not Initialized or Offline.
If it is marked as Not Initalized, right-click on it and select Initialize Disk. After the disk has been initialized, you need to create a parition by right-clicking on unallocated space of the disk and selecting New Partition from the context menu. Follow the wizard to create the partition. Once the partition is created, right-click on your new partition and select Format from the context menu and follow the wizard to format the newly allocated space. Once this is done, you will be able to utilize the disk.
If it is marked as Offline, right-click on the disk and select Reactivate Disk from the context menu. If the disk is partitioned and formatted already, you should be able to use the disk immediately, otherwise follow the instructions above for partitioning and formatting the drive.
Posted on Jun 04, 2009
How do i use SATA to recover my data from my WD 500 gb mybook? you see my power source is working at all.
You dismantle the case and extract the hard disk. Then you take that disk and you put it in a desktop pc (you will need a SATA dat cable, a SATA power cable and 4 small screws tu secure the disk inside. Once it's installed just start the pc and open My Computer - the disk will be there, copy from it whatever you want.
Sep 16, 2010 | Western Digital My Book Essential 500GB...
500 Gb sata hdd not detected on k8mm-v motherboard
Find in your BIOS if you have an option that says configure SATA as IDE, AHCI and raid. Set it at IDE and try again to install the OS. After intaling do not switch back because it will not work.
Apr 06, 2010 | Computers & Internet
Maxtor exter hdd 500 gb green light flashes but cant be detected
maxtor one touch 3 -500 does not detect on my macbook pro worked fine on my G5
Sep 11, 2009 | Maxtor MaxAttach NAS 3000 40 GB Network...
I need to replace the power adaptor for a Maxtor One Touch 4 500 GB. I need to know the volt and amp output for it. PN:9NT2A4-500
Power Adapter for Mactor OneTouch 4
AC Input : 100 AC - 240 AC (50/60HZ)
DC Output ( V/A ) : 12V / 3.5A
Output Power : 42W
Apr 17, 2009 | Maxtor OneTouch 4 500GB External USB 2.0...
ATA HDD on IDE connector with a SATA drive on a SATA connector?
Yes. You can leave the ATA-IDE and add SATAsCan you not still buy a 150?
Dec 31, 2008 | HP Compaq d530 PC Desktop
What new HDD will match my Maxtor DiamondMax Plus 8?
Mark,
You can use any size HDD in your computer as a slave and it does not have to be an exact match for the maxtor. You will however need the make sure that the connections on the new drive match. For example SATA drives will not attache to an IDE cable and vice versa. The drive that you mentioned is an IDE style drive so unless your MOBO has SATA connectors on it you will need to buy an IDE/EIDE drive.
Dec 29, 2008 | HP Compaq d530 PC Desktop
P4VM800 SATA HDD Problem Plz Help me!!!
Your P4VM800 won't detect a SATA II (3 GB/s) drive, only a SATA I (1.5 GB/s). You basically have 2 options:
1. if you have a friend or colleague with a machine that supports SATA II, install the disk in that machine and us the manufacturer's utility to set the SATA to 1.5 GB/s (Seagate/Maxtor disks, but only these do have a jumper to do the job but SATA is in other respects jumperless). Then you can reinstall the disk in your machine.
2. Buy a host adapter card for SATA II and install it in a free slot in your machine - but may be better to put the money towards a new motherboard.
Oct 17, 2008 | Asrock 775Dual-880 Pro Motherboard
Can i use this maxtoe diamond max 21 500 gb drive for a c drive i am removing a 80 gig that is defective
If you mean remove your old 80 gb drive and replacing with the Maxtor 500 gb drive you should be able to. The Maxtor 21 series is equiped with SATA. Just make sure that your computer can run SATA. If not, I believe that there are adapters out there.
Oct 01, 2008 | Computers & Internet
Sata drive not detected
just no other solution except upgrading BIOS properly
Sep 24, 2008 | Seagate Barracuda 7200.10 500 GB SATA Hard...
Instation of Maxtor diamondmax 21, 160 GB which is connected to my pc running Xp Home. The Bios and xp home do not seem to recognize it. How can I get a installtion software. Please help.
dont think you need a driver unless you are installing it in a raid ...the purpose of sata was to elliminate hdd jumpers and configuration ... just go into the bios and make sure the sata channels are enabled
Mar 21, 2008 | Computers & Internet
Computers & Internet Logo
153 people viewed this question
Top Maxtor Computers & Internet Experts
Arora Singh
Arora Singh
Computer Links
terminalcon
Are you a Maxtor Computer and Internet Expert? Answer questions, earn points and help others
