Question about RCA E13309 13-Inch Diagonal XL-100 Color Television Television
REMOTE SENSOR DOESN'T WORK SYMPHONIC 27" wf2703
SYMPHONIC TV WF2703 REMOTE SENSOR NOT WORKING CAN THE PART BE REPLACED
  • Harleen Nash May 11, 2010
    1.Yes, you can replace the sensor. All electronics can be repaired if the parts are available however you will need the original part to correct this. 2. You will need experience in electronic troubleshooting/ repair to not only replace this part but to know if the surrounding parts that are associated with said part are ok or not defective. All electronics parts in circuit are connected to something else and must be tested to see if they contributed to the breakdown of another electronic part. More details of what you are experiencing is needed to check what is really the fault.
  • 214 Answers
SOURCE: MY DTA800 REMOTE CODES WANT WORK FOR SYMPHONIC TV
I would return it and try to get a General Electric remote. They are nice and very inexpensive. I have many tv's and it works for all of them.
Posted on Nov 03, 2012
Kimi
  • 277 Answers
SOURCE: Remote sensor in the TV
First Inspect the remote batteries. also make sure TV is not on a LOCK ON option... now, the sensor is a small smoothly part near the TV front buttons, you can clean it carefully FYI, exposing unit remote sensor to direct fluorescent or outdoor light may cause signal interference.
Posted on Nov 16, 2005
silly girl
  • 513 Answers
SOURCE: RCA F27665 27
If still under warranty or if you have no electronic repair experience take the set back to the shop or to a repair person. Some of the solutions described below can be dangerous, TV's are very hazardous to service. If the TV fell recently the following might apply to you: 1. Cracked circuit board very possible, try changing it. There is a very good chance that the circuit board has some broken traces. You would not be able to see this by eye unless this was very bad. The way to find this, is to troubleshoot the set on the bench to determine which stages are not working correctly, and pursue from there to find where the signal paths, or missing voltages are sourced from. If the set fell, there is also a good chance that the CRT is damaged inside. These tubes are extremely sensitive to being hit or jarred abruptly. I have seen a TV set banged against the side of a door frame while being moved, thus causing damage to the shadowmask of the tube. 2. Check for A/V input circuit board not seated all the way. If this board comes loose, your video will disappear. In case no violence disturbed you set: 1. It is very possible that something is changed in the user setup that is causing the no useable input condition. Check the owners manual and verify the proper user settings, especially the Tv-Guide settings for use with or without cable box or vcr if tv has that feature. 2. this is a fix for a similar set, might apply to yours: Try resoldering all 3 legs of q2300 the if amp transistor and usually pins 1-8 of u2300 the IF ic. This usually takes awhile because there are sometimes a lot of poor joints in that area of the board, look it over very carefully it usually fixes these sets. Good luck, and please try not to take any chances
Posted on Jan 29, 2006
MNfisherman
  • 11896 Answers
SOURCE: lost original remote t the symphonic tv which has
You can get the original remote for a decent price. It is an original replacment remote. You can find it at any of these places.
www.replacementremotes.com
remotes.com
www.mr-remote.com
www.neworiginalremotes.com
You will need the original remote to access the features you want to use.
Posted on Nov 23, 2009
  • 21 Answers
SOURCE: I have a RCR312W and Symphonic TV and i need a
Go to http://remotefinder.rca.com/default.aspx?site=RCA follow steps, should be very simple.. Good Luck
Posted on Dec 05, 2009
My TV Symphonic model WF2703 needs a new remote control. where can I buy one?
go online and purchase from manufacturer directly
aftermarket remotes do not work for all functions properly
good luck
Mar 13, 2011 | Televison & Video
I have a Symphonic WF2703 TV with no remote. How can you access the external inputs without remote
you will have to access the menu-if you do not have a menu button-you can purchace a universal remote-try symphonic or funai codes
Sep 07, 2009 | Televison & Video
Green tint
Check 3.58 MHz color oscillator,, little metal can near large ic,
Also check color output transistors or any loose connections in the output stage
Jan 19, 2009 | Symphonic ST420FF 20" TV
WF2703
You're gonna wanna cycle the video input by pressing
1. Video Source
2. Input
3. TV/Video
4. Source
on your remote or your TV itself. Eventually you'll find it.
Dec 12, 2008 | Symphonic ST420FF 20" TV
Tv won't recognize remote codes
If the manufacturer of the universal remote cannot give you codes for the Symphonic you are out of luck. U will either have to get an original replacement or get a Harmony universal remote.
Jun 25, 2017 | Universal Remote Control Remote Control
Had a universal remote for my symphonic wf2703 tv my daughter tryed to change something with the remote now plays the dvd player ok turn it off all that comes up is a black screen with video on it the...
I had to clean the sensor area for the remote on the tv somehow got something on it. I wonder how, my little 4 yr old daughter had know idea how it got there lol.
Aug 01, 2008 | Televison & Video
Remotes quit working
Take your Tv to the Technician to check for you if the sensor is working properly.
Mar 24, 2008 | Symphonic ST419E TV
Symphonic model wf2703
Do you have "standby" power? In other words, does the set click or buzz when you try to power up using either the remote or the front panel?...accordianman
Oct 20, 2007 | Symphonic ST420FF 20" TV
TV remote quit working
Here is my blog how to repair remote controls:
Here is my blog on the subject how to repair remote controls
http://www.instructables.com/id/Repair-your-remote-controls/
To dignose if your remote control is faulty just point your digital camera towards your remote and push the buttons.
If your remote works you should see light flashing on the LCD view finder of your camera.
Repairing the remotes can be succesful about 90% of the time unless the remote has been chewed by the family dog ?
Apr 25, 2007 | Symphonic ST420FF 20" TV
RCA E13309 13-Inch Diagonal XL-100 Color Television Television Logo
587 people viewed this question
Top RCA Televison & Video Experts
matt martin
matt martin
Computer Repairing
Computer Repairing
Are you a RCA Televison and Video Expert? Answer questions, earn points and help others
