Question about Craftsman Garden
I have a Craftsman cultivator/tiller Md. 536.292500. the tines won't stop turning and it's not the engine speed, could it be the clutch?
  • sekrimmel55 Jun 30, 2009
    yes it could b the clutch it was on mine. Now i have to figure out how to replace the darn thing
SOURCE: craftsman front tine tiller 917.299011 parts
If you are looking for repair parts diagrams and part numbers they are located pages 38 through 45 of the Owner's Manual.
Hope this helps.
Posted on May 26, 2009
steve_lima
  • 181 Answers
SOURCE: what type of lube is used in 917-294261 tiller gearbox?
80-90 gear lube
Posted on Jan 09, 2009
  • 15 Answers
SOURCE: craftsman tiller tines wont engage or turn
sounds like the chain or belt inside is broke i just redid one like that with the same problem it was the chain broke i had to tear it down and change the chain its a job but it can be done unless u are not mechanically incline,if you are not it would be cheaper in the long run to take it to someone.
Posted on Apr 19, 2009
libaredneck
  • 119 Answers
SOURCE: Honda FG100 Tiller - Tines wont move
the worm gear in the lower unit is probably wore out. see it alot!
Posted on May 05, 2009
I took the transmission apart and the gears were fine. The friction pads on the centrifugal clutch don't seem to make full contact with the drum. Does anyone know what the thickness of the friction pads are suppose to be? I used some belt dressing on the pads and got some movement on the tines. With no wear on the gears, I guess I'll be replacing the clutch.
Posted on May 24, 2009
Craftsman rear tine tiller
If you cant move the tines by hand then I wouldn't think you sheared the pins, more like a gear box problem.
Mar 21, 2014 | Craftsman Garden
When I Start Mantis Tilleer it starts in gear ( tines are turning)
The Mantis has a speed controlled automatic clutch.
Lower the idle speed by turning the idle screw counter clockwise. The idle screw is attached where the throttle cable meet the carb. The screw has a pointed end that resembles a pencil point.
The engine speed should be adjusted just above stalling.
If the tines turn even when the engine pull rope is pulled, the the clutch is defective and needs repairing.
j
Aug 03, 2013 | Mantis Tiller
Tines
Either clutch is bad or teeth are striped in bottom gear box. remove tines run engine and see if you can feel movment in lower gear box, if yes the gears are gone. If no remove engine to expose clutch.
May 20, 2013 | Ardisam Inc Earthquake Mini Cultivator
The tines on a honda f220 always spin and don't change speed when clutch is engaged but speed up when throttle is increased. Adjusted cable with no luck.
I believe that unit utilizes a centrifical clutch. try decreasing the idle speed and see if the tines stop. They should then engage as throttle is increased.
Sep 24, 2012 | Honda 25cc 4-cycle Mini Tiller
Brand new tiller tines will not turn scv43
look to see if the drive belt fell out of place during shipping
Jun 06, 2012 | southland Garden Cultivator Tiller S-cv-43...
Tines rotate slow when I try to till.
The clutch is non adjustable if the clutch fails you will have drive all the time or it slips. if the tines spin at the same speed with the engine at low and high speed the clutch might be slipping, the common cause for this is the gear box is partly siezed due to no grease being pumped into it, most ppl dont even know about this untill its too late. you have to remove the LH side tines to get to the screw.
Jul 01, 2010 | Honda 25cc 4-cycle Mini Tiller
THE TINES WON`T TURN, THE MOTER WORKS THE TINES WON`T TURN
SOUNS LIKE SOME THING CAME LOOSE IN SIDE THE TRANS
Oct 01, 2009 | Craftsman Garden
I have a craftsman cultivator, 2 hp model 536.292522. the engine runs, but the tines only turn untill they touch the ground, then they stop. does anyone know how the centrifugal(?) clutch works? does it...
the centrifugal clutch is steel on steel, if the tines are turning at all, the clutch is okay. unfortunately, what you are describing is a worn sector or pinion gear inside the transmission. not difficult to repair but time consuming and pretty expensive
Apr 21, 2009 | Craftsman 8.50 Torque Rating Dual...
Craftsman tiller engine dies when I try to engage tines
tilt the back of the tiller up and check for a rock or stick wedged in between the tines and the shield
Mar 22, 2009 | Craftsman 8.50 Torque Rating Dual...
Garden Logo
187 people viewed this question
Top Craftsman Garden Experts
Wade Mobley
Wade Mobley
Jim Parker
Jim Parker
Dean Gruber
Are you a Craftsman Garden Expert? Answer questions, earn points and help others
