My DVD drive in ACER Aspire 4720 not reading burnt DVDs and CDs
It works fine with the commercial DVDs and CDs but the drive fails to read a self-burnt DVDs or CDs. It used to be alright initially but suddenly the problem arose. Please help me.
Either
* your "optical" device can only read CDs, not DVDs;
* it should read DVDs, but something is "dead", and the device is not performing as it should
* you need to install software to "play" a DVD-movie.
Define "will not accept" -- can you hear the drive spin the disc?
Does any program "auto-start" on your computer, when a DVD disk is inserted?
You need a software made for DVDs which you can use for the CDs to.
To read DVDs (and CDs) use Power DVD.
To burn DVDs (and CDs) use Nero DVD. You may purchase them almost to any PC shop.
This is just an example. You may find some free software on the Internet but if you are not used with this I suggest to ask a friend to help you or to buy a software as I have already said.
Try reading a prerecorded or original DVD disk for a movie for example, if it can read this then it means the DVD you are tryng to read were burnt at speed faster than what your DVD can read.
Jeff - If you have not changed your software configuration in any way since the last time you could successfully play a DVD, it could be that the drive has failed. You can test this most easily by taking these DVD's that won't play in your Acer now, and play them in another good computer, or a regular home DVD player. If they play in your other systems/players, you will see right away. And if the machine is that new, you might be able to get it easily fixed under your manfuacturer's warranty.
If you have made any kind of changes to your system software that could affect your dvd burner, that could cause it to not recognize them perhaps, as well. By changes I mean - installing some kind of alternative dvd playing software than what came with your machine, etc. If you did not make any software changes, it is likely a hardware problem.
Chances are, your DVD player uses one laser to read CDs, and a different laser to read DVDs (since Cds and DVDs are read at different wavelenghts of light). If the DVDs you're trying to watch work properly in other DVD players, it probably means that the DVD laser is dirty, damaged, or burned out. Though you can try cleaning the laser (use Google for suggestions on how to do this, or check the Audiovox website), you will most likely have to get the DVD player repaired, or buy a replacement.
Many of the newer CD/DVD players sold today use a single combination laser, which reads both CDs and DVDs, which means that when the laser fails, it will not work at all. Wish I had better news for you, but I guess that the only consolation you have is that your Audivox player still works with CDs...
