Question about GE WCVH6260F Front Load Washer
Washer will not fill
When I press start it will lock, spin, unlock, lock and a few seconds later the drain pump will start and run for a minute or two. Then everything stops and the start light flashes at you. The only thing that happens after that is the timer counts down. HELP!
  • djawife Jun 04, 2009
    We knew about this and have already cleaned it out a number of times - any other ideas??
  • 58 Answers
Your drain pump is obstructed. You need to remove the bottom panel to access the drain pump. The drain pump will be in the front center of the unit. Once accessed you will see a large knob/screw this will need to be turned clockwise (be ready with some towels and bucket) once you have it open, you should be able to clean out the trap. Reverse to reassemble.. Good luck.. Hope this helps... Bill
Posted on Jun 04, 2009
  • Bill Brignoni Jun 04, 2009
    Door lock assy. If you've cleaned the trap & it continues to error out with a countdown, Then it would be indicative of the board not receiving a signal from the door lock.
Error message SUD and F21 even after unclogging the filter
Push the pause/cancel button twice to clear your message. Then run through a rinse/spin cycle. Next try a normal load without any detergent. SUDS is usually from too much detergent. If this fails, checked the hose for kinks. Check connections and if all that fails, you will probably have to replace the pump. Good Luck!
Feb 04, 2014 | Maytag MAH6700AWW Neptune Front-Load...
Lid is not locking properly, washer sensor is overfilling, and the washer wont spin
Check door switch: If the lid switch is bad it will not drain or spin. Try this test: With lid open let it finish wash cycle. Press lid switch down with screwdriver. Washer should begin draining. Release switch. Motor should stop. Press switch a second time. Washer should start spinning as it continues to drain. If motor doesn't come on while lid switch is pressed, replace the switch. OR
http://www.youtube.com/watch?v=q942xn_2VXY
Pl click if helped.
Apr 28, 2013 | Whirlpool WTW4950XW Washer
The door wont open . I have tried to put it on for a cycle and you can here the the water for around 5 seconds then it stops and does nothing.
Check and make sure your pump or filter is not clogged, then next I would suspect you have a faulty door lock mechanism
More common issues with the door lock.
Is water hooked up to the washer?
The door will remained locked while draining water. If during installation the washer was plugged in and turned on without water hoses attached, the washer may attempt to drain for 8 minutes before the door unlocks. Let the washer run until the door unlocks. Do not turn off the washer or unplug the washer.
Does water remain in the washer after the final spin?
If water remains in the washer after the final spin, then the door will not unlock. Select Drain/Spin or Spin Only to remove any remaining water from the washer. The door should unlock at the end of the cycle. For models that have Rinse/Drain & Spin, push the Extra Rinse button to turn off the rinse to remove excess water.
Is the door locked and the Add A Garment light on?
If the Add A Garment light is on, then the washer door will unlock after the Pause/Cancel button is pressed once. Pressing the Start button will restart the washer at the same point where it left off in the cycle.
Is the door locked and the Add A Garment light off?
If the Add A Garment light is off, then the washer door will unlock after the Pause/Cancel button is pressed twice. The door will not immediately unlock while the cycle is running due to a possible high-water level in the washer, high-water temperature, tumbling or spinning. It may take up to five minutes for the washer to stop spinning and draining before the door will unlock. You will hear the door click when it unlocks.
Trying to gain access into a locked door can be a bit frustrating. Upon researching your question I found some links that may help you unlock your washer door. I attached all links below. I hope this helps!
http://www.managemylife.com/mmh/questions/204092-how-do-i-get-the-door-open-on-my-kenmore-washer
http://www.managemylife.com/mmh/questions/220303-does-front-loader-door-open http://www.managemylife.com/mmh/questions/134692-why-wont-the-door-open-on-my-kenmore-frontloading-washer
Jun 10, 2011 | Washing Machines
Push start and machine wont fill and draining/unlocking light sarts blinking about 2 seconds later
My machine had the exactly same problem:
1. Push Start button to wash, but Draining/Unlocking light will flash right away. The drum started to run and stopped
2. No error code shown up
3. Run Quick test: no error code
4. Run Universal Test: error code F25 (later, found nothing wrong with the CCU)
What I did:
1. Clean the bump: found coins and strings.
2. Clean the drain pipe from the pump to tub: found more coins.
3. Clean chamber of pressure switch at the tub: found nothing.
4. Clean the gap between tub and drum: found a credit card!
After the cleanings, the Draining/Unlocking light would still come back and I almost gave up. Amazingly, I ignored it and a few minutes later.... the machine started to run as normal!
It seems that CCU needs sometime to reset itself after the failure.
Jan 24, 2011 | Whirlpool WFC7500VW Washer
Maytag Neptune TL starts, fills with water a few sec then clicks loudly a few times and then stops, a few sec later it repeats this, then stops for good. Tried unplugging and restarting, but same thing...
Any error codes?
Do you want to troubleshoot? If so here is the Service Manual.
FAV6800A/FAV9800A Service Manual for reference. Sears Parts Direct for reference.
I would start by removing the front cover of the machine follow all safety warnings in the Service Manual.
Follow the first few steps in my Clutch Fix post to remove the front cover.
Then let me know if during the water fill cycle the machine rotates the wash basket CCW in a slow spin during the water fill cycle before the machine stops and we will go from there. Give me all the detail you see with the front cover off I need to know if the wash basket is rotating CCW during the washer fill cycle.
You can lift the washer top up a slight amount to observe the slow CCW spin of the wash basket. I’m checking that the outer tub bearings are not seized……Rich
To pump out the excess tub water with this process;
Enter Service Mode by simultaneously pressing and holding the Enviro Plus and Spin Only keys for three seconds or the display reads “00”
Pressing the Delicates key will lock the lid. Now press the Presoak key the drain pump will turn on. Stop with off button or hit the Presoak key.
This process is documented in the Service Manual. I would go to page 16 of the SM lower right hand part of page, Board Output Test and turn on the drain pump in service mode to pump out the tub.
Jun 26, 2010 | Maytag Neptune FAV6800AW Top Load Washer
Mcahinw will not start.
Hi, Press and hold the DRAIN/SPIN button for 3 seconds. If the Control Lock feature will not lock or unlock the appliance,unplug the unit for AT LEAST 30 minutes in order to reset the main control board.
Apr 12, 2010 | Kenmore 3.8 cu. ft. HE3 Front Load Washer
Started getting an F2 error code
I looked up the F02 code online and this is what it says:
If the drain time exceeds 8 minutes, the water valves are turned off and F02 is flashed.
Press PAUSE/CANCEL twice to clear the display.
NOTE: After 4 minutes the “Sud” error will be displayed, then 4 minutes later the F02 error code will be displayed.
Potential Causes
• Check the drain hose and make sure it is not plugged or kinked
• Check the electrical connections at the pump and make sure the pump is running.
• Check the drain pump filter for foreign objects
• If the above does not correct the problem replace the pump
Hope that helps.
May 18, 2009 | Whirlpool GHW9400 Duet Washer
Control lock light will not go off.
Do you have any error codes?
If water remains in the washer after the final spin, then the door will not unlock. Drain/Spin or Spin Only to remove any remaining water from the washer. The door should unlock at the end of the cycle.
If Pause/Cancel does not work:
  1. Unplug washer or disconnect power for one minute.
  2. Plug in washer or reconnect power.
  3. Re-select the cycle and press Start.
NOTE: If the error remains on the display, call for service.
Dec 19, 2008 | Whirlpool Duet GHW9150P Front Load Washer
GE WCVH6260 stops unexpectantly
Try buttons "dry" & "spin" together for a few seconds. This is the child lock display.
Or press "end of cycle" for over 5 seconds.
Or press "options & select" till the light goes off.
Works for other machines..............And please rate me if helped.
Check your drain with a good pour of water from a bucket, it must clear fast. It it doesn't snake it out; the prob lies there 99%. And don't push your exit hose too deep into the standpipe, 4 to 5 inches & not air tight.
Nov 20, 2008 | GE Energy Star WCVH6260F Front Load Washer
Door stuck Locked Control Locked light on
Try unplugging the washer for at 30 minutes to reset the computer, first. If this proves unsuccessful, you can retrieve you clothes by using the manual release. The following link explains how:
http://www.fixya.com/support/r622155-kenmore_elite_whirlpool_duet_door_jammed
Once you retrieve your clothes, try running diagnostics on it. You can envoke the diagnostic sequence by selecting DRAIN/SPIN, NO/SPIN and then pressing any button under OPTIONS 4 times (must be the same button). The display should go to "C00" as the washer begins a sequence of tests that checks the fill functions, door lock, dispenser functions, motor speed, spin and drain. Allow the washer to run through the entire sequence and shut off. If anything is wrong an error code should be generated. Hopefully, all you had was a minor glitch. Let me know how things turn out. I hope this helps you.
Aug 25, 2008 | Kenmore Elite 45986 Front Load Washer
GE WCVH6260F Front Load Washer Logo
223 people viewed this question
Top GE Washing Machines Experts
Dan Webster
Dan Webster
Tim Whalen
Are you a GE Washing Machine Expert? Answer questions, earn points and help others
