Question about Sony KP-57WS510 57" Rear Projection HDTV
Sony KP-57WS510 57 inch rear projection - Rainbow colors and arch
Picture suddenly went from perfect to red/green separating and large green arch across the screen. When turned off for a while, picture returns to normal but in a few minutes it's distorted again.
This is exactly what happened to my TV...anybody know what's the repair procedure for this? Cooling problem..??what to do ? Thanks!!
    Scholar:
  • 150 Answers
Hi, you`ve lost your convergence ic`s, unless your very proficient at solder work I`d advise you call a tech, will require removing 2 large IC`s and possibly a few small support parts, resistors, chemical fuses etc. Every place is a little different but runs approx. 300.00 at my shop, gl, video-tek
Posted on Jun 05, 2009
Arched lines in dark screens whether it's Cable or DVD playing Model number: KP-57WV600 Sony 57inch rear projection TV
Ur convergence it dead.Do u know how to solders? Tries these websites. Tv repair World.com or Tvrepairkits.com have it.Buy a convergence kit used what in that kit ur tv well get back to normal.The shop will cost u $300 for parts and labors.
Jan 01, 2010 | Sony KP-57WV600 57" Rear Projection...
Picture Falling with arch
It is your convergence IC's going out, they cost about 40 $ for both, if you know someone that can solder, i would have them do it, once you see the new parts it is prity easy to find them on the board in your tv, repair shops usually charge 4 to 5 hundred
Jan 08, 2009 | Sony KP-46WT500 46" Rear Projection...
2 separate colors on screen
sounds like your convergence IC's have finally gone bad.. they seem to last 5 years on average.. have a look here: http://cmpalmer.blogspot.com/2006/11/fixing-my-own-tv-part-ii.html
Dec 19, 2008 | Sony KP-53V75 53" Rear Projection...
Color distortion and arched picture
Your TV most likely has one of two possible problems.
Problem #1: Convergence Chip Failure ( common problem )
Here are some of the most common symptoms and example photos of a convergence problem
  • Screen looks 3D
  • Colors don't line up
  • One or more colors can't be adjusted when using the convergence menu.
  • Screen is bowed or warped.
Here is a quick test....
Using your original remote go-to the tv settings then goto the convergence section.
Try to adjust the red and then the blue convergence.
You should be able to move them up, down, left, and right.
If you can't move them in all directions your convergence chips are bad and should be replaced. This is a common problem.
2c07611.pngSolution #1
You need to replace the convergence chips and convergence resistors. Check the site www.TvRepairKits.com. They have put together a kits for most models. If you don't see a kit for your set send them a quick note and they will put one together for you. Their kits include a photo instruction guide, original OEM Sanyo STK chips, convergence resistors, pico fuses, etc.
Problem #2 CRT Fluid is Cloudy
Projection TV tubes have a liquid coolant that is used to keep them from overheating. After many years the coolant in the blue and green tubes will become cloudy and cause the screen to look dull, red/orange, etc. You may even see halos around images.
Picture of a set that needs the fluid changed.
TV set after fluid change
2c07611.pngSolution #2
What you will need to do is replace the coolant and clean the crt. You can get a repair kit from www.TvRepairKits.com that includes replacement coolant, photos. instructions, etc.
Oct 31, 2008 | Sony KP-51WS510 51" Rear Projection...
It is problem of failure of convergence ICs or related circuit. Please confirm model number of your TV that is Sony KP-57WS500 to help you out.
It would be nice if you could past TV snap shot here for easy understanding.
Thank you.
Oct 02, 2008 | Sony KP-57WS500 57" Rear Projection...
Color Separation and Arched Picture
Please call a repair center. This is something you cannot repair your-self. It's usually around $200-400 for the repair depending on who does it.
May 07, 2008 | Sony KP-57WS500 57" Rear Projection...
Sony KP-57WS510 57 inch rear projection - Rainbow colors and arching
Same thing happened to me. I had to get it fixed. They said it was a "tube".
Now, my problem (7 months after getting it fixed) is that it suddenly seems a lot dimmer. I'm not 100% sure, and was wondering if there was some kind of diagnostic to run to find out for sure.
Mar 18, 2008 | Sony KP-57WS510 57" Rear Projection HDTV
Arching horizontal
You have convergence failure
See this and this
Call a Tec if inexperenced
Jan 26, 2008 | Sony KP-65WS500 65" Rear Projection...
Strips of color coming up from bottom of tv
youll need to replace the stk ics inside the tv. they are easilly found by looking for two larg heat sinks. im pretty sure sony runs stk392-510. you will have to look at the ics to verify.
Apr 16, 2007 | Sony KP-53S75 53" Rear Projection...
Sony KP-57WS510 57" Rear Projection HDTV Logo
1,128 people viewed this question
Top Sony Televison & Video Experts
Are you a Sony Televison and Video Expert? Answer questions, earn points and help others
