Ovens Logo
Posted on Jun 04, 2009
How do I set the clock on the Gaggenau EE698-604?
1 Related Answer
Anonymous
  • 12 Answers
  • Posted on Sep 01, 2008
SOURCE: Gaggenau EB 270/271 Electric Clock
To set the clock:
1. Press the clock key 3 items until the hr/min icon flash.
2. Press the + or - key until it come to your desired time.
3. Press the confirmation (check) key.
You have your time.
If not, call the service support.
I have a Gaggenau E-378-6 that will not heat, yet I can't find a manual with parts
Hi, I think the model should be EB786, but aside from that I have a question, does this problem follow a self clean cycle ? If so it is very likely the hi-limit safety/cut out that has been tripped ( assuming you've checked the 40amp breaker and set the clock ). I'll wait for your reply re; self clean cycle. Macmarkus :)
Gaggenau EB290 built in oven - F10 code
If you really cannot find in manual, contact the manufacturer for guidance.
4helpful
To set the clock:
You have your time.
4helpful
No Manual
To set the clock:
1. Press the clock key 3 times until the hr/min icon flash.
2. Press the + or - key until you come to your desired time.
3. Press the confirmation (key or tick) key.
DOUBLE OVEN,GAGGENAU
this oven could be in display mode this only allows non harmful functions to work eg lights etc but no heat this can be disabled through clock test prog reset but you will need an engineer to do it as complicated.
ring 08705 678910 for service and advise
good luck
Gaggenau EB294/295 Electric Double Oven
I am a gaggenau engineer this is usually a fault with the door lock mechanism it can be manually reset eg remove oven and side panel pull back locking arm there is a also a built in test prog in oven clock that will switch door lock back to reset position but these will need to be done by an engineer as oven very heavy.
ring 08705 678910 for service and/or advise
good luck
Top Ovens Experts
ZJ Limited
ZJ Limited
john h
Are you an Oven Expert? Answer questions, earn points and help others
