Question about Texas Instruments TI-83 Plus Calculator
ERR: DIM MISMATCH
I am trying to find correlation coefficient and when I try to do LinReg(ax+b) it says ERR: DIM MISMATCH.
  • 13 Answers
Check the values you entered into L1 and L2. One of them is missing a value.
Posted on Jun 16, 2009
How to turn on diagnostic on casio fx cg 10
You got yourself a prizm, learn to use it and forget about the TI84 Plus. The DiagnosticsON is a command of the TI8 84 plus. You can activate it for statistics or deactivate it. For the Casios, the determination coefficient or the correlation factors are always displayed. If the regression model you are using has a correlation coefficient it will be displayed on the same screen the statistical values are displayed.
Please read your manual, it will help you a lot.
Sep 25, 2012 | Casio Prizm Fx-cg-10-l-ih Graphing...
I;m trying to do lin reg and my TI-83 PLUS keeps saying ERR:DIM MISMATCH
LinReg uses two Lists, they must contain the same number of elements. If you are using LinReg with no arguments the Lists are L1 and L2.
Nov 02, 2010 | Texas Instruments TI-83 Plus Calculator
LinReg(ax+b)
One (or more) of the variables a, x, and b are in archive memory.
Press 2ND MEM to get into the memory management editor. Press 1 to select ALL. Scroll through the list. If any of those three appear with an asterisk to the left, navigate to that line and press ENTER to unarchive it.
Mar 05, 2010 | Texas Instruments TI-83 Plus Calculator
How do u store linreg(ax+b)as y1 on ur graphic calculater
When you press [STAT] and right Arrow to highlight CALC you see two linear regression model [4:LinReg(ax+b)] and [8:LinReg(a +bx)]
If you select [4: ...] the command echoes on main calculator screen as LinReg(ax+b) and a blinking cursor
If you press [ENTER] you will get your equation, a, b, and r^2 if DiagnosticsOn command has been executed before. However you will not be able to see the line of best fit on top of the raw data scatter plot.
To save the equation of best fit in a function variable, ex Y1, you complete the command as follows
LinReg(ax+b) [VARS][=>][Y-VARS][1:Function][1:Y1]
The Y1 variable will appear on main calculator screen, and you have
LinReg(ax+b) Y1
Press [ENTER]
Screen display the equation, its parameter and its correlation coefficients (if so configured).
Press [GRAPH] to draw the line of best fit on top of the scatter plot.
Here are two screen captures to show you the equation and the line of best fit.
As you can see from the value of r^2, and the graph, a linear regression does not seem good.
Feb 01, 2010 | Texas Instruments TI-84 Plus Calculator
I own a TI-84 Plus (silver edition). Does this calculator have formulas built in for the least squares line so I might enter the data to get the values for b and m? If so will it give me the correlation...
Read this post. It answers all your questions and shows you HOW to do find your equation of best fit, correlation coefficients, etc.
Before doing statistics, you have to prepare the calculator by clearing old data that may generate errors.
A. To clear old data
  1. Press [2nd][+] (MEM) to open the memory management screen.
  2. Press [4:ClrAllLists]
  3. The command echoes on main screen, press [ENTER] to run it.
  4. Calculator displays Done.
B. Run the SetUpEditor command
  1. Press [STAT][5:SetUpEditor] [ENTER] ; calculator displays Done.
C. Turn DiagnosticsOn option (optional)
To obtain the correlation coefficient in a statistical analysis on the TI8xPlus family of calculators you must activate the DiagnosticsOn option. To access the command
  1. You press [2nd] [0] (CATALOG)
  2. While the list of commands is displayed, press [X^-1] (D)
  3. Cursor jumps to first command that starts with D, dayOfWk(
  4. Press the DownArrow 9 times to reach DiagnosticsOn
  5. Select it and press [ENTER]
  6. Command echoes on main calculator screen with blinking cursor
  7. Press [ENTER] to set the option
  8. Calculator displays Done.
From now on, if a correlation coefficient has meaning for a regression model, it will be calculated along with the other statistical results. If it has no meaning to the model it will not be calculated.
D. Enter the data
Press [STAT][1:Edit]
Type in the X values in L1 and the Y values in L2 (see picture 1)
To obtain the statistical results
  1. After you finish entering the data, press [2nd][Quit] to exit StatEditor.
  2. Press [STAT] and highlight Menu (CALC)
  3. In the list select [2:2-Var Stats]
  4. Command echoes on main screen.
  5. Press [ENTER] to calculate the stats
Here is what you get (with you data).
Notice the down arrow next to n=7. That means the results screen has more values. Press the down arrow to display.
You notice that the n=7 line now has an arrow pointing Up. Notice the Down Arrow on the bottom line (more data is coming). Here is the rest of the statistical results.
There is no arrow at the bottom of the picture. End of statistical results.
The screen captures with 2-Var Stats summarize all the satistics. Some of the values your are looking for are among the result. NOW it is you mission to identify what you need (I chewed all the work for you).
However there is no correlation coefficient, no line of best fit, etc. To obtain that you have to perform a regression analysis.
Perform a Regression analysis
To perform a regression analysis, you must try several regression models and then find the one that mimicks the raw data best. In this particular case, you have already decided to do a linear regression, and that is good for me. I do not have the time to take you through all of them. A linear regression it will be.
  1. Press [STAT] , highlight [CALC]
  2. In the list of regression models select [4:LinReg (ax+b)
  3. The command LinReg(ax+b) echoes on main calculator screen.
  4. If you press [ENTER] you will get you equation but you will not be able to draw the curve on top of your data to verify the goodness (no it is not a swear word) of the fit. So you must save the equation as a function in Y1 variable.
  5. While LinReg(ax+b) command is still in command line, press the [VARS] key.
  6. Highlight the [Y-VARS] menu and select [1:Function], then press [ENTER].
  7. In the Y function variable list select [1:Y1]
  8. At the command line, you have LinReg(ax+b) Y1.
  9. Press [ENTER] to save the equation of best fit in Y1.
Here are your results.
The slope is a and the y-intercept is b. You also have r and its square. You need to read your theory to know which of the two correlation coefficients you have been asked to obtain.
Since you saved the equation in the Y1 function you can draw it. You just have to press GRAPH and it will be drawn. But that will not tell how good the fit is, until you see the function drawn on top of the raw data.
Drawing the scatter plot and the raw data on the same screen.
Regardless of the curve of best fit, you can draw a scatter plot as follows.
  1. Press [2nd][Y=] (STATPLOT)
  2. Select [1:Plot1...Off] to open plot1 configuration screen
  3. Use arrow to highlight On
  4. Use the down arrow to move cursor to the line Type.
  5. Select the first icon for a scatter plot. NOTE: To navigate the 6 statistical stat plots on the line Type, use the right or left arrow (to backtrack), but not the Up or down arrows.
Here is the configuration screen
Here plot1 is active (ON), it is scatter plot (first icon) the Xlist is L1 by default but you can change it to some other list. Notice the highlighted A cursor on XLIST line. It means that the [ALPHA] keyboard is active.
On the line Mark you can choose the appearnce of the raw data point.
And here is your two graphs: the raw data scatter plot and the line of best fit on the same screen
Now, it is up to you to accept this model or to try another model.
Jan 28, 2010 | Texas Instruments TI-84 Plus Silver...
You are given the following data. x y 2 16 3 11 4 12 5 15 5 11 7 8 7 11 Find: - SS(x) - SS(y) - SS(xy) - The linear correlation coefficient, r - The slope b1 - The y-intercept, b0 - The equation of the...
OK, you convinced me to do your homework for you.
D. Enter the data
N
Jan 21, 2010 | Texas Instruments TI-83 Plus Calculator
TI-84 Plus Linear Regression (ax+b) ERR:DIM MISMATCH
Some old configuration settings, or old variables are spoiling your fun. Clear the RAM and start again.
Hope it helps.
Sep 28, 2009 | Texas Instruments TI-84 Plus Calculator
ERR:DIM MISMATCH
That is a piece of cake. just go to the two Lists that you are using for the equation and see if they are the same length.
May 10, 2009 | Texas Instruments TI-84 Plus Calculator
LinReg (ax+b)
just press (2nd) + (MEM)+(7) + (1)+ (2) and then try again.;)
Apr 23, 2008 | Texas Instruments TI-84 Plus Calculator
How to calculate the Linear correlation coefficient
go to [2nd] [0] then select [diagnosticon] and click [ENTER] then it atomatically adds it to the LinReg(ax+b)
Dec 09, 2007 | Texas Instruments TI-36 X Solar Calculator
Texas Instruments TI-83 Plus Calculator Logo
732 people viewed this question
Top Texas Instruments Office Equipment & Supplies Experts
k24674
Stevan Milanovic
Are you a Texas Instruments Office Equipment and Supply Expert? Answer questions, earn points and help others
