Question about Car Audio & Video
Just Got this installed and when I turn off my car and turn back on the amp does not go on I have to un plug and replug to get it working.
  • 57 Answers
Hello check the amp remote wire that goes from amp to back of stereo also do you have a fuse block on the power wire going to amp?
Posted on Jun 04, 2009
Mitsubishi wd-73738 turns itself back on
It sound like the remote is powering off the cable box but not the TV. The remote control may need to be reprogrammed to the TV. When you press power it may only power off the Cable box. At that point, try pressing the TV button on your remote and then Power. If it does not power off the tV after pressing the tV button, the remote may need to be reprogrammed to the tv. Cable companies usually have the codes needed to program their remotes to the TVs.
Jul 09, 2016 | Mitsubishi WD-73738 73" 3D Ready DLP HDTV...
My air con is not working. Previously a month ago stopped working for one day then started till today. Gas is full.
You shouldn't worry, it seems just a temporary connection error in one of the AC wiring plugs. If it happens again, turn the key switch to the start position, push the brake & pull the gear stick away to the "D" position, take out the small storage compartment above the AC control panel, with your middle & pointer fingers of both hands simultaneously push the AC panel out from above & behind, unplug the 4 plugs, spray the plugs & their sockets with the WD40, leave it work for 30 minutes, airjet spray to dry, replug & reassemble the panel & compartment.
Oct 06, 2010 | 2000 BMW 3 Series
Problem with my hp photosmart C6280 printer...when paper is in...says out of paper...looks like something is wrong where paper feeds...
Try to reset the your printer by turning it off and unplug the power cord from he power outlet then unhook the printer cable and let the unit sit for 5 minutes and replug everything back in. If this would not work try to un-install then re-install the printer's software. If this would not work still call the printer's manufacturer for the unit to be warranted.
Sep 09, 2010 | Computers & Internet
Error 5100
Hi there follow the steps below.
Remove the printer data cable & restart the PC & printer. Then fit back the data cable & turn on the printer. Hope that's start working , if no luck then un install the printer driver & restart the PC & Printer both again. Now install the driver of the printer and connect it with PC ,Turn on printer & go for a test print from the printer preference. Thanks & waiting for your reply.
Jun 08, 2010 | Canon MP140 PHOTO AIO All-In-One InkJet...
New ink but want print letters printer type epson c82
Remove the printer data cable & restart the PC & printer. Then fit back the data cable & turn on the printer. Hope thats start working , if no luck then un install the printer driver & restart the PC & Printer both again. NOw install the driver of the printer and connect it with PC ,Turn on printer & go for a test print from the printer preference. Thanks & waiting for your reply.
May 24, 2010 | Epson Stylus C82 InkJet Printer
Door handle light shock when opened . Disappear when unplegged and replugged again with opposite terminal
un plug the fridge prior to opening the door grab desired food option and close the door and then plug the fridge back or stop bein a ***** if its a small shock man up
Apr 03, 2010 | Dometic RM2620 Refrigerator
Rear lift gate will not open
try un plugging bcm and replugging back in had one before did that worked located in centre concole lots of work to unplug. if you want can also look at rear latch harness located under drivers side above spare tire may have loose connection.
Dec 22, 2008 | 2002 Pontiac Aztek
My volume will not come up
my volume went out all of a sudden will it ever come back on or how can i get it back on
Jul 20, 2008 | Durabrand DWT1905 TV
Incorrect cartridge
  1. Press the On button to turn the printer off.
  2. Unplug the power cord from the back of the printer.
  3. Remove all the ink cartridges.
  4. Wait two minutes.
  5. Plug the power cord into the back of the printer.
  6. Press the On button to turn the printer on.
  7. Install the ink cartridges when prompted.
Oct 25, 2007 | HP Photosmart C5180 All-In-One InkJet...
Car Audio & Video Logo
22 people viewed this question
Top Car Audio & Video Experts
xxxxxx xxx
Are you a Car Audio and Video Expert? Answer questions, earn points and help others
