Question about Dell 942 All-In-One InkJet Printer
Power problem Does the Dell 942 power up with the USB cable only, I cannot find a place for a power plug, thanks.
  • Dell Master
  • 2,404 Answers
According to the owners manual: http://support.dell.com/support/edocs/systems/PRN942/en/om/942_om_en.pdf The power connector is next to the USB connector in the back of the printer. You use the AC adaptor to hook up the printer to a wall outlet to give it power and then the USB Cable is hooked up to the computer so you can install the printer software to the computer so it recognizes the printer.
Posted on Jun 04, 2009
    Novelist:
  • 79 Answers
A picture is worth a thousand words: AC Adapter connects to #11:
I was recently given the FinePix E550 by someone who had purchased a newer camera. I do not have the usb cord to download pix and my Dell 942 All-in-One will not recognize the camera card. What do I need...
Hi
The problem you are experiencing with your Fuji FinePix E550 could be down to a number of reasons.
You do not say the memory card size you are using but the Dell 942 will probably only read cards xD-Picture Cards 1Gb or lower.
It maybe a better idea to remove the xD card from the camera and use a USB card reader to take the images off the card. Alternatively you could buy a replacement USB cable
Hope the suggestions help.
David
Dec 29, 2010 | Fuji FinePix E550 Digital Camera
Dell all in one 942 ink jet printer reads "clear paper jam" there is no paper stuck. How do I fix?
Try this; Remove the cartridges, disconnect the usb cable, turn off the machine, unplug the power chord and switch off the adaptor from the wall switch, leave the machine for few minutes while you do some cleaning, like cartridges contact points, clean the rear panel door, also open the front panel door and check for any foreign particles, you should remember that even a small/tiny piece of thread or hair can create this problem. Now connect the power chord, switch on the wall switch, and power on the printer without the cartridges installed and the usb cable connected. Use the Power Button the switch on the printer. Leave it Switched On for few minutes and again turn it off, install the cartridges, connect the usb cable and again reboot the unit. Press the power button once and again keep pressing when it starts booting. If the problem still persists, your printer needs service.
Good luck.
Thanks for using FixYa.
Jun 20, 2010 | Dell 942 All-In-One InkJet Printer
My dell photo 942 won't scan
I would try deleting the scanner driver and software and reinstall. then plug the usb cable from the printer to the pc.
Jul 31, 2009 | Dell 924 All-in-One InkJet Printer
I need power cords for my monitor
The monitor needs a power cord and a signal cable. The power cord is a standard 3-prong detachable cord just like the one on nearly every desktop computer and many other electronic appliances.
The signal cable may be one of two types, depending on your computer's video connector. The monitor has connectors for both VGA (a D-shaped connector with 15 pins) and DVI (a rectangular connector) inputs. You need a cable with whichever type of connector fits your computer.
You should be able to find the power cord at Radio Shack, any of the big office supply places, or retailers who sell computers. The signal cable may be available there as well, or you can order from a number of online vendors.
The monitor also allows you to plug in a USB cable from your computer so you can plug in USB devices like a keyboard or mouse. For that you need the same kind of USB cable you would use to connect a printer.
You can view or download a copy of the monitor user's guide at Dell's site here:
http://support.dell.com/support/edocs/monitors/1704fpt/EN/index.htm
If this solution has been what you need, please take a moment to rate it. Thanks for asking here!
Feb 21, 2009 | Dell UltraSharp 1704FPT 17" Flat Panel LCD...
Dell gx260
You have 500mA on usb port. If you cause a short on usb connectors, this can damage the motherboard.
Disconnect usb port on motherboard (work with power unplugged ), remove all ide and floppy cable,eventually remove and put back in place bios battery and Ram.
Restart Motherboard only with 1 module Ram (bios battery back in place), CPU and Fan (ensure cpu and fan are well in place), do not plug anything else than switch on button.
If it still does not work there is a good chance you blew the Motherboard.
Regards
Apr 18, 2008 | Dell OptiPlex GX260 PC Desktop
Offline and blinking lights
A couple suggestions. Unplug the usb cable from the pc to the printer, make sure there is no paper jammed in the machine, unplug the machine from the wall and see if you can move the print head left to right freely. If nothing is obstructing it plig the power cord in with out the usb cord plugged in. See if the machine goes to ready. If all of these fail, that means the main board has been damaged by a power surge, and it would be cheaper to replace the machine than repair it. Good luck!
Jun 28, 2007 | Dell 942 All-In-One InkJet Printer
Motherboard
Are you trying to install the Dell Media Card Reader? If so then the other end of the ?FlexBay USB cable that plugs into the card reader goes into a small rectangular connector towards the back of the motherboard. Specifically orient as follows; place the computer on its side, the power supply to your left and the front of the computer facing towards you. Starting at the back of the motherboard next to the power supply follow the back edge of the motherboard till you come to the approximate center of the board. About an inch towards you there will be a rectangular connector the FlexBay USB cable end should fit into. If this isn?t the cable from the Dell Media Card Reader let us know and we?ll try to help, otherwise please don?t forget to rate this posting.
Feb 11, 2007 | Dell Dimension 5100 (D51L1) PC Desktop
Dell 942 All-In-One InkJet Printer Logo
90 people viewed this question
Top Dell Office Equipment & Supplies Experts
jasbo
jasbo
Electro Med Services...
Are you a Dell Office Equipment and Supply Expert? Answer questions, earn points and help others
