Question about Sharp Office Equipment & Supplies
Sharp 2300n gets paper jam. It fold paper like an
Sharp MX-2300n gets paper jam. It folds paper like an acordion.After I clear the jams, It will do it again.What is causing the paper to fold up like this?
  • Anonymous Mar 23, 2014
    will it print on heavy card stock
  • Anonymous Mar 25, 2014
    how do i set up my sharp mx-2300n to print card stock 100 lb
    New Friend:
  • 91 Answers
When you clear the paper from the machine at the fusing unit, you can see 8 pawls, it looks like a hook but in a flat design. They should be touching the heat roller ( each has a spring to make it flexible ). If one not touching the heat roll it will caused the paper stuck to it so you will have the accordion paper jam.
Posted on Jun 04, 2009
  • cassian7 Oct 04, 2010
    How do you actually fix it??
Sharp mx 2300N error code H5-01
http://www.copytechnet.com/forums/sharp/76512-sharp-mx-2300n-error-code-h5-01-a.html
Feb 15, 2015 | Sharp MX-2300N Color Copier
Paper jam before printing process
more than likely your fuser is not turning the gear may be bad on the fuser or an internal gear.
Jun 30, 2014 | Sharp Mx-4111n Multifunction Copier
My sharp 2300-n notified me of a paper misfeed. After clearing all misfed paper, the copier is still telling me there is a misfeed, and is not allowing me to print or copy. Suggestions?
Make sure that all of the paper jams are removed. Check every available cavity, including your paper trays. Pull each tray out and make sure there are no jams right out of the paper trays. Sometimes a piece of paper can become lodged where you cannot see it.
If you are positive there is no paper stuck in the machine, then you have a paper-path sensor that is either dirty or faulty.
Oct 29, 2010 | Sharp MX-2300N Color Copier
Code : H5-01
Check for paper jam in or by fuser unit. Remove paper. On the keypad press P * C * and SIM 14 to reset copier. If you get 5 jams at the fuser unit in a row it gives this code. If it keeps jaming double check for paper, my have a faulty sensor.
Aug 31, 2010 | Sharp MX-2300N Color Copier
Error Message H5-01
H5-01 = detecting 5 consecutive POD_1N jams
Check the fusing section for jam paper. (winding, etc.)
Use SIM14 to
cancel the trouble.
Entering the simulation mode
1) Copy mode key ON → Program key ON → Asterisk (*) key
ON → CLEAR key ON → Asterisk (*) key ON → Ready for
input of a main code of simulation
enter 14
accpet yes clear..
machine should restart.
To fix this you need to have the fusing unit looked at... could be various problems causing this , from bad paper to bad rollers?
Nov 24, 2008 | Office Equipment & Supplies
Will it fold and staple A4 to make A5 booklet
Yes it will as long as it has a finisher like in shown in the picture.
Sep 15, 2008 | Sharp MX-2300N Color Copier
Hp c6180 keeps erroring that there's no paper, when it does recognize paper
folded corner is 2 things
a) it's gettig folded somewhere along the paper path ( you would have to stop it at every step to see at what point it gets folded)
b)usually the fuser claws are the problem ( right before the exit the part that gets hot has some claws that ride ON the heat roller 3-5 depending on the machine, one is going bad )
Aug 18, 2008 | HP Photosmart C6180 All-In-One InkJet...
Help
H5-01 indicates tha the paper sensor is defective in the fusing unit. The only way you can try to reset that one is buy turning the power off, wait 30 seconds and turn the power back on.
If the error code returns the fusing unit will have to be fixed to take care of the paper sensor.
Jul 20, 2008 | Sharp AR-M237 Digital Copier
Error code h5-01
Yes H5-01 is when it jams in the fuser 5 times in a row, check the fuser section for a jam, the paper jams up in there and does't trigger any sensors, once you have confirmed that its clear reset with sim code 14
May 31, 2008 | Sharp AR-BC260 Color Copier
331 people viewed this question
Top Sharp Office Equipment & Supplies Experts
Anthony Karuku
k24674
jasbo
jasbo
Are you a Sharp Office Equipment and Supply Expert? Answer questions, earn points and help others
