Question about Acer Aspire 5315 Notebook
Acer Aspire 5315 Notebook will not power on
I am having problems powering on the laptop. When I turn on the laptop it powers up for about 5 secs, I can see the green power light turn and I can hear the fan. It then cuts off.
  • andrew865 Jun 04, 2009
    Thanks, I had tried all these things already. Possibly the processor has over heated and is now damaged as the laptop was crashing this week.
    Is there a way of clearing the CMOS, I can't seem to find a battery or jumper or pins in a convenient place.
  • Acer Master
  • 2,404 Answers
Disconnect the battery from the laptop and only hook up the ac adaptor. Turn the laptop on and if it still cuts off after 5 seconds then reseat the memory back into its slots. Also make sure your air vents are not clogged with dirt or dust as lack or air flow can cause the laptop to shut off. If that doesn't do it then take out the hard drive and dvd drive and turn on the laptop. If the laptop still cuts off then it has to be a faulty motherboard at that point which means to much voltage is going thru and the components on the motherboard are not regulating it properly.
Posted on Jun 04, 2009
Hi im avin problems with my acer aspire 5315 what it does is whem press the power button on the green light comes on then the fan kick in then the fan stops and the green light goes off with a bep
Posted on Jul 16, 2010
Acer 5315 will not boot. Also will not work in safe mode
turn off laptop , remove cables and battery then press and hold power button for 8 secs. Reinsert cables and battery then turn on the pc. Observe if there is power on the laptop by checking the keyboard if there is light on it. You may check it at the upper portion of your keyboard. If it still wont boot, you may have a bad memory or hard drive. Normally if it is a system problem, your unit won't turn on. Consult ACER for possible repair of your laptop
Oct 20, 2010 | Acer Aspire 5315 Notebook
My Acer Aspire 5315 wont turn on?
remove the battery then try to turn on the laptop. if this works you probably have a bad/shorted battery
Dec 08, 2009 | Acer Aspire 5315 Notebook
Acer aspire 5315 with no display
If you are connecting with external monitor, then you have to toggle the display Fn+F5 together, still not getting the display then,
Unplug battery and adapter,
Press and hold the power button for 20 sec
then try to turn on the computer
Nov 26, 2009 | Acer Aspire 5315 Notebook
Acer aspire 5315 doesnt boot blank screen
When you power up the laptop press F1 or F2 or "del" key to enter in bios setup.
Then check your harddisk is detect or not?
Then also make sure SATA option is disabled in bios.
Then go to boot option and set first boot device as your harddrive.Then save settings and exit.
But if you even not able to enter in bios then you have reset bios settings and Refix RAM memory .
For that open back cover fo laptop and find cmos cell on motherbord pull it for 10 minutes so all settings of bios goes to factory defaults.
Let me know if you need more assistanse.
Thanks.
Sep 25, 2009 | Acer Aspire 5315 Notebook
Solution for reset password
1. to reset password in acer aspire 5315 simply take a _small_ flathead screwdriver.. contact the two points leaving the battery, power on, power off and the password is cleared.
save the thread below for all your future solutions its all about ur laptop only. http://www.techsupportforum.com/hardware-support/laptop-support/200354-bios-recovery-acer-aspire-5315-a.html
Kindly do rate my solution.
Jun 26, 2009 | Acer Aspire 5315 Notebook
My acer aspire 5315 doesnt boot up the power
remove the battery and plug in power..if it works then your battery having problem..if not then ur power adpter having problem...
Apr 20, 2009 | Acer Aspire One PC Notebook
My Aspire 5315 will not start
I actually contacted Acer by email for this and got a reply in less than a day.
Try the steps below for a power reset, to eliminate a hardware problem with your notebook:
1. Disconnect the AC adapter from the laptop.
2. Remove the battery.
3. Press and hold the power button for about 30 seconds then release it. (You will not see anything happen)
4. Connect the AC Adapter to the laptop. Make sure the AC Adapter is plugged in.
5. Turn the computer on as normal.
6. Once Windows boots, insert the battery.
If the notebook still does not power on, we recommend the notebook be serviced by our authorized repair depot. You can set this up for service yourself by going to www.acerpanam.com; click on the link for Depot Repair. If you are out of warranty, or you would rather do this via phone, please contact Acer Technical Support at 1-800-816-2237, Mon-Fri 7am-9pm CST and Sat-Sun 8am-5pm CST excluding holidays. For out of warranty products please call 1-866-621-2237. Hours of operation are 7am-8pm CST, Mon-Fri, and Sat-Sun 8am-5pm CST excluding holidays.
Dec 17, 2008 | Acer Aspire 5315 Notebook
Acer Aspire 5315 Notebook Logo
827 people viewed this question
Mohammed Ebrahim M
Mohammed Ebrahim M
