Question about HP 920 Plain Paper Fax
Paper failure Sends a fax. Will not connect to copy a paper. Starts to work..squeaks..comes up with same message: Paper failure: Reload paper then press Start.Just keeps sending this same message.
    Genius:
  • 2,120 Answers
If you can see the black rubber feed rollers, clean with isopropyl alcohol
Posted on Sep 10, 2008
HP OfficeJet 8500 ADF detects load, but does not detect feed. I have a brand new HP OfficeJet 8500. The ADF detects a document is loaded when I stick a piece of paper in it to be copied/scanned/faxed, but...
Remember that if you start to fiddle you void your guarantee, I know its a pain, but if I were you repack and either contact customer services and obtain a return invoice number if purchased over the internet and return to sellers. If purchased from a shop, return with your prove of purchase.
Mar 19, 2011 | HP Officejet Pro 8500 Wireless All-In-One...
Paper is not "picked up" to print.
TRY CLEANING THE PAPER ROLLER WITH DENATUYRED ALCAHOL OR MAY BE THERE IS SOME THING STUCK IN THE MACHINE GO AHEAD AND LOOK GOOD LUCK BROTHER TECH
Jan 28, 2009 | Brother IntelliFAX 2800 Laser Fax
My Brother Intellifax 2800will not print a fax. It says "Check Papoer-Reload paper by using llever - then press Fax Start." I do this then it says "Printing" and kicks on but then starts all over with...
is there a smug mark on the paper in the cassette. If there is then the feed roller needs to be cleaned ( alcohol ). If paper is out of the cassette & in to the delivery asm. then you have a small pice of paper stuck somewhere in the paper path ( hard to see if this is the prob. ) will need to dismatill the paper pathe asm. hope things work out.
C.W.H.
Not receiving faxes
Folio is not what you want. The usual is letter (LTR) or 8.5 x 11. You may have to check the settings to set the default paper size.
Jan 14, 2009 | Canon PC-1080F Plain Paper Laser Fax
Panasonic kx-f1100 fax prints and sends 1 page on 2 pgs- 2big!
I found the solution to my problem: Press Menu, Pound Key (#), 35 to set copy size, 36 to set fax size, press Start/Set, then use up/down arrows on right side of the machine to select 92%, 86%, 72%, or Off. Press Start/Set to select desired setting.
Press Menu to exit!
Dec 08, 2008 | Panasonic KX-FP81 Plain Paper Fax
Check paper reload paper
Remove the paper tray completely and make sure paper is not binding and lifting up OK.
Jun 30, 2008 | Brother IntelliFAX 4750 Plain Paper Laser...
Paper problem
Allow the recycling process to continue.
Mar 02, 2017 | Brother MFC-3220C Plain Paper Inkjet Fax
Problems receiving faxes in memory
Just had the same trouble. I loaded paper. Tried more paper, tried less paper. No luck. Finally in deparation and trying "everything" I could think of, I pressed "stop/reset" before pressing "start/copy" and now it's working. Very frustrating!
Aug 30, 2007 | Canon FAXPHONE L80 Laser
HP 920 Plain Paper Fax Logo
124 people viewed this question
mukhtar21 shaikh
mukhtar21 shaikh
