Question about McCulloch FHH18A Electric Pressure Washer
Where do I go to get a new hose for the Mac FHH18a? My hose head blew off, and the pieces are long gone.
Sounded like an explosion. Something broke underneath and coolant has gone everywhere
you either blew a radiator hose, the radiator itself, or your head gasket, or water pump. any of those problems need to be addressed by a mechanic. if you can't diagnose it you arent qualified to fix it.
Oct 12, 2014 | Cars & Trucks
Muffler nuts vibrated off my mac leaf blower
You can tell if there was a gasket by looking at the two surfaces. Usually ther is a gasket on the exhaust.Look around the area the muffler seperated. I couldn't have gone far unless you blew it out of site. Good Luck-Ned-
Jul 23, 2014 | McCulloch Garden
Trigger don't release
I have a hose and gun that fits the McCulloch FHH18A that I no longer need as I had to buy a complete universal hose/gun and wand unit since I had broke the wand and the replacement wand was no longer available. If you are interested in it, email me at burmakow@nwciowa.edu and we can figure out a price.
Apr 28, 2012 | McCulloch FHH18A Electric Pressure Washer
Blew the heat pump hose. The plastic piece that the hose goes onto broke inside the hose. Can I buy just that piece?
if the broken off piece in the engine comes out by screwing or whatever you can probably find one at the parts store or god knows the dealer
Feb 27, 2011 | 2000 Ford Mustang
1996 SPORTSMAN 400 2 STROKE, INITIAL PROBLEM WAS OVERHEATING AND PRESSURE IN RAD AND BLEW COOLANT HOSE OFF THE TOP OF THE HEAD. HEAD GASKET WAS LEAKING,CHANGED HEAD GASKET. PRESSURE IN RAD CONTINUED AND...
take the head off the jug again take a black magic marker and marker all over the gasket service and then tape 600 grit sand paper to glass or mirror and rubb the head acrossed in a cris/cross pattern and check this will tell you if its warped and (wet) sand it till the marker is gone re applacation might be nessasary if you wan tto sand it or have it milled for 80- 100$ you can check the jug this way too but the stud need to be removed email me at allmotorman1981@aol.com for more info if you cant figure this out
Feb 07, 2011 | Polaris ATV
Car overheated and wont start, does crank over, it blew a radiator hose, replaced it, but still wont crank over
Sorry! sounds like this one is too far gone! If it blew the radiator hose off the engine, then the head gaskets or the cylinder head itself has failed. You will quite possibly need a new engine put in your Cavalier.
Nov 26, 2010 | 1991 Chevrolet Cavalier
Small crack in the wand.
This part number is for the wand and hose assy 41 7228-H18A01 WASH MANCHINE HAND ***'Y
This is the manual I used: http://ipl.ordertree.com/ipl/604/FHH18A.pdf
It is available from this source: http://www.ordertree.com/ModelInfo.asp?Final=1&SiteID=1&Mfg=139&Model=FHH18A click on the 4th item with the part number above listed and add to cart. $35.93
The shipping fees are listed here: http://www.ordertree.com/cms/shipping-policy/14.html
$9.95 + $12/95 for Canada shipping
If this is not your model or not part of what you needed just respond here and I will get back to you. Please ensure you include your exact model number when responding.
Thanks for using FixYa.
Kelly
May 14, 2010 | McCulloch FHH18A Electric Pressure Washer
Fhh18a water flows INTO the tanks during operation.
There should be a ball and spring in the valve where you attach the soap suction hose.
Jul 05, 2009 | McCulloch FHH18A Electric Pressure Washer
What are the steps to use Mc Culloch FHH18A powerwasher? What is the liquids I should use?
Hello awseibel:
  1. attach your garden hose to the inlet (at the back I believe)
  2. Attach high pressure hose with gun wand/nozzle
  3. turn on the water
  4. plug into electrical outlet
  5. turn on/off switch on
  6. spray away
  7. Any non-caustic soap can be used
  8. You must set the machine on low pressure to apply soap.
McCulloch FHH18A Electric Pressure Washer Logo
111 people viewed this question
Top McCulloch Garden Experts
Roland W VanLue
Roland W VanLue
roeb
Are you a McCulloch Garden Expert? Answer questions, earn points and help others
