Question about Compaq Computers & Internet
I have a laptop and some how my phillips cdrw/dvd cdd5263 driver has been deleted. My computer acts as though there is no cd drive anymore. I cannot connect it to the internet for the driver scans that I have seen because I cannot install the software for my aircard because it doesn't recognize the disk. Is there a way to download the driver onto a disk from another computer that I have and transfer it over?
    President:
  • Compaq Master
  • 1,314 Answers
First of all, there is no "driver" per se for the CDRW. If you computer cannot see it, it is because the unit is faulty. If it were not faulty, windows would be able to see it and install it's own drivers for it. The drive will have to be replaced.
Posted on Jun 04, 2009
I still can not get the Laptop running Xp Pro sp3 to see the CDRW/dvd combo drive. I followed all of the previous instructions but when I get to the Place where I'm supposed to delete Upper Filters. There...
make sure that the cdrw-dvd rom is getting enough power test all leads that are attached to the cd-dvd including electical extensions and make sure they have a secure connection or just replace them there might be bad/faulty or the drivers may have been corrupted or you might have a virus run your antivrus program you might have to physically unplug the leads for this cd/dvd burner then plug them back in this should activate the found new hardware wizard or you might have to uninstall then reinstall your DVD/CD or uninstall the driver then reinstall for this device Click start control panel administrive tools,computer management,device manager scroll down cd-dvd rom drives you might see a yellow question mark ? right click you will have options to update driver,roll back driver,or select properties general troubleshoot, select driver click to reinstall drivers click update driver or uninstall then reinstall
Apr 01, 2011 | Dell (8W007-A01) for Latitude, Inspiron...
Acer cdrw 8x4x32
Try calling them instead of sending emails. (408) 533-7700 – Phone
And you will probably need to update the drivers on your CD drives hardware. Hope this helps :)
Jan 16, 2008 | Computers & Internet
My laptop Dell Inspiron 1200 does not recognise my phillips cdrw dvd cdd5263 drive
Follow the following instructions:
1.) Start Menu
2.) Right-click My Computer and click on properties.
3.) At the tabs at the top, go to hardware.
4.) Click on device manager.
Once the window opens any device inside or connected to the computer will be under the respective groups. Anything unknown to the computer will have a little exclamation mark next to the icon. On most computers, if there are any the groups will already be expanded.
Once you've found the dvd drive that isn't recognised, update the driver by right clicking on the device -> update driver.
You do have to be connected to the internet but it sometimes searches the computer for the right driver. Hope this helped
Mar 22, 2011 | Microsoft Windows XP Home Edition
What is Phillips cdrw error code 41?
make sure that the dvd burner is getting enough power test all leads that are attached to the dvd burner including electical extensions and make sure they have a secure connection or just replace them there might be bad/faulty or
your drivers may have been corrupted or you might have a virus run your antivrus program
you might have to physically unplug the leads for this cd/dvd burner then plug them back in or
control panel admistrive tools,computer management,device manager scroll down cd dvd rom drives right click you can you can update driver,roll back driver,or
hope this helps
if this does not fix the problem it might be a registry problem
Close all open programs
Click on Start, Run, and type regedit and press Enter
Click on the plus signs (+) next to the following folders
HKEY_LOCAL_MACHINE
SYSTEM
CurrentControlSet
Control
Class
{4D36E965-E325-11CE-BFC1-08002BE10318}
This folder is the DVD/CD-ROM Drive Class Description in the registry. Look for any of the following names in the right hand column.
Upper Filters
Lower Filters
Upper Filters.bak
Lower Filters.bak
If any of the above keys shown in step 4 are listed, right-click on them and choose Delete
After deleting the keys, close the registry editor
Reboot your computer
Open My Computer and check to see if your CD or DVD drives have returned. You may also want to open Device Manager and verify that the yellow exclamation and error code on the CD or DVD drive is gone.
hope this helps
Jan 02, 2011 | Computers & Internet
Just looking for a driver fro crwd 2400p cdplayer. The OS the driver is needed for is Windows XP. This peripheral is a PCMCIA cdrw dvd player and was bought from PSISM.com (they keep saying this item is...
Follow the steps given below
Connect the External CDRW to the PC and you should be able to find the green light glowing and CDRW should make some noise like spinning.
Press the Eject button the CDRW and It should open. Put in the Software disk that you have received from your PC manufacturer and it should display the contents on the PC Screen
If not, Click on START button - Click on My Computer - You should find the CDRW displayed in Drives Location.
Double click on it and it should display the CD Contents.
This indicated the CDRW is working.
Nov 09, 2010 | EXP Computer EXP CRWD 2400P (CRWD-2400P)...
I need donwload philips cdrw dvd cdd5263 driver
Windows XP automatically contains device-drivers for all CD/DVD-readers.
It also contains software (from ROXIO) to enable the writing to CD-writable disks.
If you have movie on a DVD-disk, then look at software like 'PowerDVD' to decode and play the movie.
Nov 25, 2009 | Microsoft Windows XP Home Edition
Phillips dvd drive/cd burner does not burn cds
Might be the regestry, errors can accure throught the reg, nothing you did it just happens. Try this and see, "Start" "Run" type in "regedit" then ok in the left field click on the "+" next to Hkey_Local_Machine" + next to "System" + next to :CrurrentControlSet" + next to " Control" + next to "Class" then click on " {4D36E965-E325-11CE-BFC1-08002BE10317} " in the right fild click on "Upper Filters" then "delete" now "Lower Filters" then "Delete" restart pc. Hope this is helpfull.
Jun 22, 2009 | Computers & Internet
I have deleted the drivers for my phillips cdrw/dvd cdd5263
Hello sbrown20,
Do whats suggested at this article
http://support.microsoft.com/default...#91;LN];314060
Anyway, as Mark7171 said, there are no drivers for optical drives and Windows has its generic driver for it, which is good enough.
Should you have any further questions, please feel free to post them here. Please do not assign a rating until you feel your problem is resolved. I will try my best to help you further, if need be.
If you are satisfied with my solution or have no other questions, please close the problem by assigning a FixYa! rating for my solution. I would be very grateful for your show of appreciation.
Thank you for using FIXYA!
Cheers!
IrishDruid
Apr 20, 2008 | Computers & Internet
I need a DRIVER for my PHILLIPS CDRW800
You should'nt need a driver if it's an internal ide drive, they use Windows. I've had computers for years and never needed a CDRW driver. You may need some burning software though.
Mar 16, 2008 | Computers & Internet
Computers & Internet Logo
69 people viewed this question
Top Compaq Computers & Internet Experts
pankaj rautela
pankaj rautela
Alun Cox
Are you a Compaq Computer and Internet Expert? Answer questions, earn points and help others
