Question about Intex Automatic Salt Water System for Above Ground Saltwater Pool
What is a code 3 on a intex salt water system
    Problem Solver:
  • 10 Answers
Code 03 means operating hours. You have either set it for 3 hours or it has 3 hours left.
Posted on May 28, 2010
How long should code 93 flash on the intex salt water system
It means that your pool has finished the chlorination process and everything is perfect! any other questions google will help you
Jul 15, 2014 | Intex Automatic Salt Water System for ...
Salt Water System Model 8110 will not generate Chlorine
6000 gallon pool initial salt 129 lbs for count of 3000 ppm
Mar 05, 2017 | Intex Automatic Salt Water System for ...
Have an intex 16 x48" salt water pool generator
I checked the Intex web site and here is what they said:
There are several things you may need to check and do:
- Test the salt level first with Test Kit, and add salt as needed.
- Remove the electrolytic cell for inspection and clean it if necessary.
- If code 91 still appears despite the above steps, there might be a possible electrolytic cell
failure. Please contact Intex Service Center, and replace the cell if needed.
NOTE: Always turn the power off and disconnect power cord before cleaning and servicing.
I hope this helps.
Aug 24, 2011 | Intex Automatic Salt Water System for ...
Just purchased and installed Intex salt water system. It shows low flow and now, after 5 days of installment, the water is completely green (expecting Swam Thing to come out!) I need your guidance to...
Seems like you may not have the pump and the salt chlorinator in sync... If your water is dark green and not a big pool, you may want to drain and refill, if you have a large pool, you may want to shock and then try the following...
1.Make sure you have added the correct amount of salt...
2.Set your timer for your pump for 12 hrs.
3.Wait 15 minutes and then turn on your intex salt water system..
4.Set you hrs of operation on your salt water system for 10 to 11 hrs...
5.After running the system for 3 days, check your chlorine level..
If water clears and chlorine level is high, adjust the time.. You will have to re-sync the pump and chlorinator.. If the pump turns off before the chlorinator finishes it's cycle, you will get a "LOW FLOW" alarm..
I hope this helps and good luck.. Please rate and comment on the information provided.
Jul 26, 2011 | Intex Automatic Salt Water System for ...
I have a code 81 showing up on my salt water system
There is no code 81
If you have a valid receipt intex will replace your unit. You will just need to fax them the info they request. I had a new one within days
Jun 17, 2010 | Intex Automatic Salt Water System for ...
We keep getting code 92 (high salt). There water
From the FAQ, What should I do if code 92 appears?
- Test the salt level first with Test Kit, drain approximately 20% of the pool water and refill with fresh water.
- If code 92 still appears despite the above step, there might be a electrolytic cell failure. Please contact Intex Service Center, and replace the cell if needed.
Jul 18, 2009 | Intex Automatic Salt Water System for ...
Code 93 saltwater system
Hi, Code 93 is telling you that the system is done running, did you mean to say it said 92? That code would be for too much salt. If indeed it is a Code 92 you are getting, give Intex a call, or email. I have found their website to be very helpful, they have a F&Q's area. Good luck!
Jun 15, 2009 | Intex Automatic Salt Water System for ...
Intex Automatic Salt Water System for  Above Ground Saltwater Pool Logo
317 people viewed this question
Top Intex Pool & Spa Experts
avionik99
Level 1 Expert
Jay Finke
Jay Finke
Mike
Are you an Intex Pool and Spa Expert? Answer questions, earn points and help others
