The TV just quit the fuse in side was blown a new was put in and it blew again ser # v12748958 3-07
  • macgiver463 Jun 04, 2009
    the TV just quit the fuse (4amp 125 volts)in side was blown a new was put in and it blew again it was near the power bourd
    some what
    Genius:
  • 1,689 Answers
Hi Macgiver,
have you tried replacing the fuse for the unit.
replacing this will eliminate blown capacitors, you may also want to use capacitors with more than 6 amps to hold on to the current in a stable manner.
if this did not fail over night, then you may take the 4amp capacitor back to avoid burning other parts of the set.
hope this helps,
regards.
voodoo
Posted on Jun 04, 2009
  • 13,433 Answers
There can be many reasons for a fuse blowing repeatedly, depends where the fuse is, if its on the power board, it could be a faulty power board or theres a short somewhere. It definitely needs to be looked at and tested. You could replace the power board if the fuse is blowing there repeatedly but if it blows even with a new power board then the problem is at another area.
Best to get it looked at to avoid extra part bills.
HI. My Yamaha D80 while playing gave a burned smell and than sound quit. Rest works. I opened rearcover and notice 3rd fuse in the back was blown. Changed it. Blew again. So I stopped fidling around.
If the fuse blows and a smell of burning is present then its obvious there i a fault somewhere ahead of the fuse, the fuse is a protection device.
Oct 08, 2016 | Yamaha Cars & Trucks
The television quit working during a storm and seemed to not be getting power. Took off the back and found the 5amp/125v fuse blown. Replaced it and it blew again as soon as I plugged it in
Hello
All telivisions are provided with fuses, and the function of fuse is to protect its internal circuit agains short circuit, and protect the other components in the TV. if fuse must blow, surely there must ba reason. Without rectify that reason, if you put the fuse and switch it again, it may poise to other more problems. So get it repaired with a qulaified service personal. Never put any more fuse in it and swich on the Tv. Ok.
Oct 18, 2010 | RCA Televison & Video
Power seat doesn't work
you should take a look at the switch, it may be shorted work it back and forth,if that don't do it for you then you will want to take the motor out it is ether shorted out or just need cleaning up ,to reduce the amp,draw . hope this helps if you would like any further help feel free to ask.Thank you
Jun 28, 2010 | 2008 Saturn Aura
Wiper fuse blows as soon as you insert one
first....be sure the fuse is the right ampage. second...if the ampage is correct, and it still blows, do the following. Disconnect the ground-side of your battery. Attached test lamp to ground-side of battery. Take probe end of test lamp and touch anypart of the motor body frame. If the test lamp (DOES NOT LIGHT UP), you have an electrical short. Recommend OBD (On-board Diagnostic) analysis test.
Apr 25, 2010 | 1998 Subaru Forester
Hi i have a 94 gmc k1500 4x4. i went to put it in to 4 wheel drive and he light did not come on on the floor and i was not in 4x4. so i saw that the fuse was blown so i put a new one in and i went to turn...
hi hows it going, i'm having the same problem have you figured it out? i was out driving today came home for 3hrs then went out again and noticed the 4x4 light was out and the fuse was blown and blew when i put a new fuse in it's about -31 degrees could have the cold done got something stuck? any help would be awesome
Dec 09, 2009 | 1993 GMC Sierra K1500
Hello I blew the crank fuse is it possiable that I blew another cause car wont start.
yes quite possible you may have blown another fuse too--- if the wiring's are grounded somewhere get it checked.and yes the car wont start until you change the fuse.also check that the fuse insertion socket is not rusted.if its rusted just clean it properly before putting in new fuse.
thanks,keep updated and please rate the solution positively.
Oct 08, 2009 | 1992 Chevrolet Camaro
Blown fuse on panasonic tv
Maybe the horizontal output IC are on short circuit.
Nov 04, 2008 | Panasonic PV-DM2799 27 in. TV/VCR/DVD...
Blown Mains Fuse
You should repleace the old transformer with the new one
Jun 13, 2008 | NAD C370 2-Channel Amplifier
Insignia LCD TV 26"
A blown fuse is a symptom not the cause... You might take a look at the caps E919,E920,E921 (all 680uf/35v). The board can be accessed by removal of center cover w/o removal of the entire back.
Bill
Nov 15, 2007 | Insignia IS-LCDTV32 32 in. Television
Televison & Video Logo
41 people viewed this question
Top Televison & Video Experts
Electro Med Services...
