I need the input code for a sansui TV. I am using the remote for RCA Digital TV converter DTA800B1. I've lost the instructions and the volume and on/off buttons don't work. how do I do the input thing when I have the code? I'm not very good at using the computer or anything technical (old age) so please don't assume I know anything. Is there a way to get copies of instruction manuals you've lost?
  • 854 Answers
Product Manual:
http://www.1800customersupport.com/productdocuments/DTA800B1_RCA_FCC_Eng.pdf
Quick Start Guide:
http://www.1800customersupport.com/productdocuments/DTA800B1_RCA_QSG_1.pdf
Product support page:
http://www.1800customersupport.com/products.aspx?view=505&p=83&sc=32
Posted on Jun 04, 2009
I have an RCA TV converter box, model DTA800B1. I don't have the box or instructions, I am attempting to conneect it to an RCA TV with a built-in DVD player. I would appreciate the code that the TV...
There are a lot of possible RCA TV codes programmed into the DTA800B1 remote.
Try the following three digit codes: RCA 000, 001, 005, 072, 073, 074, 075, 076, 077, 078, 135,
138, 140, 144, 150, 156, 159, 162, 163, 169, 171, 178, 229, 246, 249, 260, 274, 275, 293, 302 in order.
To program the remote. Turn on your TV manually and press PGM (to the left of the zero in the number pad section). The LED should light and stay lit. Type in the first 3 digit code and press OK (in the center of the arrow keys near the top). See if the gray volume up/down keys work to change the volume. If it doesn't work press PGM again and enter the next code.
Note that the converter box remote will only turn on and off, switch the input from Channel 3 or 4 to AV in, adjust the volume and mute the TV. It will not control any of the DVD functions. Your original TV remote will not control the converter box.
The manual for the DTA800B1 is available here: http://www.1800customersupport.com/productdocuments/DTA800B1_RCA.pdf .
I hope this helps.
(who has the DTA800A which is the model without the analog pass-through.)
Sep 17, 2011 | RCA Televison & Video
We have also lost the manual for the RCA DTA800B1 converter box and need instructions to program the remote to work with a Sharp TV.
Press PGM on the remote control. The signal indicator on it remains lit.Enter the 3-digit program code with the number keys. Press OK The signal indicator will be o when the program is one.Press the volume keys on this remote control to check if they can adjust the volume of your TV set.• If you fail to control your TV set,repeat steps 2 to 4 to program again. Try another program code if there is more than one for your TV brand.• If the signal indicator remains lit after blinking four times, you may have
entered the wrong code. Repeat steps 3 to 4 to program again. Make sure you have correctly entered the code.• You can still use your TV remote control to turn on your TV set, select input source and control the volume.for conrmation.your sharp tv code is 005, 021, 071, 085, 087, 092, 128, 183, 208, 274, 298
Sep 16, 2011 | Televison & Video
Have an rca digital converter box model dta800b1 and a phillips universal remote can i program it so my box get the channels
Find the user guide for your universal remote and use the RCA cable tv/satellite codes, and one should work for your RCA DTA800B1 converter box. My Sharp Aquos remote liked the RCA satellite code.
Jun 04, 2010 | Televison & Video
Programming RCA converter box remote control with Phil/Mag TV---
Good day,
You should have the instruction guide. If not look below. It's there but look closely for the guide itself and how to increase it's size to readable.
Check on the back of the TV to see if there is a 3 and 4 setting, If so, set to 3.
With nothing connected to the tv, and using the tv's remote, scan for channels. It should come up with only channel 3.
Then using the remote with advanced options, set the the input to either antenna or auto.
Connect the antenna cable to input on the converter box. Using the supplied cable connect the output from the converter box to
the TV. Turn the TV on first, followed by the converter box.
Then follow the instructions.
Not really easy so you'll have to fight your way thru it.
Finding the right setting for the antenna will probably take the most time, requiring a station scan after each adjustment.
http://dtvconverterboxes.blogspot.com/2009/05/rca-dta800b1-owners-manual.html
Dec 28, 2009 | RCA Televison & Video
Lost code for rca DTA800B1 digital converter box
I have an RCA DTA800 converter box but I need the codes for my Magnavox...need help
Feb 19, 2009 | Jensen JER-422 Universal Remote Control
Lost codes for RCA DTA800B1 converter box
rca converter box syvania tv codes please thank you robert
Feb 01, 2009 | RCA Universal Remote Control
Remote codes for RCA Digital TV Converter Box (DTA800B1)
I was just looking for them and then found my manual and felt bad for you guys so I scanned it and uploaded it to photobucket ^^ please feel free to save the remote codes but you may have to zoom in alot to see them ^^
http://i37.photobucket.com/albums/e83/Megumi_Kurama/Scan007December152008.jpg
http://i37.photobucket.com/albums/e83/Megumi_Kurama/Scan006December152008.jpg
Sep 16, 2008 | Televison & Video
Televison & Video Logo
190 people viewed this question
Top Televison & Video Experts
Electro Med Services...
