Question about HP PSC 1315 All-In-One InkJet Printer
The printer cartridge light keeps flashing and reading error but I have a brand new black HP cartridge in the printer and the color cartridge has ink in it still. I have tried several times to take it out and put it back in.HP psc1301 all in one printer
    Brigadier General:
  • HP Master
  • 3,614 Answers
Make sure that there was no more seal on the cartridge, double check if it is properly seated on the carrier.
Also you do hard rest on the printer - hold the clear button down then press the power button until the panel blinks
Hope this initial info helps
Posted on Jun 04, 2009
1. Replaced Color and Black ink cartidges on my HP D5160: Color cartridge - NEW Black cartridge - REFILL SYMPTOMS> Red flashing exclaimation LED, black ink cartridge appears empty (0 dots in the...
Black printer ink in HP Printer may fail to be recognized by the printer. Most times an error message will be sent indicating that something is wrong with the black print cartridge. Sometimes the printer may accept to print with the black ink, but the printouts may have horizontal lines and very illegible letters. In such a case a manual cleaning of the print head should be carried out. In doing the manual cleaning, one should spray Windex heavily on paper towel and wipe off the surface of the print head.
http://en.kioskea.net/forum/affich-40171-printer-not-printing-black
Oct 26, 2010 | HP Photosmart D5160 InkJet Printer
My all-in-one printer A940 reads "error 50c" i have replaced both ink cartages what could b the problem?
Hi there Error 50c
Regarding the Dell A940 "Error 50c"....the user guide doesn't seem to mention "Error 50c". They do, however, mention a "Cartridge Error" on page 52 of the manual. They claim this means that the printer has detected a short circuit (fuse/resister) in the cartridge. As you may or may not have noticed in the manual, this is what they recommend doing about it:
1) Press Power to turn the printer off.
2) Lift the printer cover/lid (scanner unit) until the scanner support holds it open.
3) Turn the printer on.
The ink cartridge carrier moves and stops at the loading position unless the printer is busy.
4) Remove the color ink cartridge.
5) Lower the printer (scanner unit) until it is completely closed.
If the error message displays again, replace the black cartridge with a new black cartridge.
If the error message does not display, repeat steps 1–3 and then go to step 6.
6) Reinstall the color cartridge and remove the black ink cartridge.
7) Lower the printer (scanner unit) until it is completely closed.
If the error message displays again, replace the color cartridge with a new
color cartridge.
If there is no error message (indicated by flashing lights), repeat steps 1–3 and then reinstall both ink cartridges.
8) Lower the printer (scanner unit) until it is completely closed.
If you get the error message again, while both cartridges are installed, replace both of the cartridges.
Basically, what they want you to determine is,....if the short circuit is with the "black ink" cartridge or the "color ink" cartridge and then replace the cartridge that has the problem.
You may have to buy a new cartrige.
Please all I ask is call back and just gave a vote, it will gave me some satisfaction to know am helping some one, so I will keep on helping.
All The Best: Pineworks
Jul 17, 2009 | Dell A940 All-In-One InkJet Printer
Check Printer Light Keeps Flashing on C3180 PhotoSmart
No, you do not need 3 cartridges or anything like that. Some cartridges have chips. Yours do not. If the light keeps blinking it means that one of the electrical contacts on the cartridge has blown and now the printer doesn't recognize it. Try printing something, you will get a message "problem with color cartridge" or "color cartridge missing". That means that the printer doesn't recognize it. I suggest you buy a new one. Or, if you have an old one, try putting it in and see if the light still blinks.
Jun 02, 2009 | HP Photosmart C3180 All-In-One InkJet...
Will not print black , HP PSC 1610 All-in-One
Is it a new genuine cart? If so, I have had this problem. Run multiple copies of black only text, Run 50 copies, will still spit out blank pages.Then head clean. If no black repeat. I did this for around 200-250 copies then Volia! black. Hope this helps
Apr 28, 2009 | HP PSC 1610 All-In-One InkJet Printer
New ink cartridge will not work in hp6840 printer
its a broken spring clip on the side of the ink cartridge.
fixes are here;
http://www.fixyourownprinter.com/forums/inkjet/46650#83
and here;
http://www.fixyourownprinter.com/forums/inkjet/50913#243
hp is supposed to give you a brand new printer for free.
or its a reman ink and the printer is trying to force you to buy a new one.
Mar 26, 2009 | HP DeskJet 6840 InkJet Printer
Problem of incompatible cartridge occure in my new J 4580
i had the same problem with the hp 4580. i needed to replace the black ink which i did. then the error message appeared "incompatible print cartridge tri color"...chatted with hp customer support, wasted a hour. claimed its a hardware problem need to have it fixed. i asked would i be charge he said yes but the printer was under warranty. he asked other questions...bottom line i left the chat box....bought another hp 4580, used same cartridges, same message...THEN finally i replaced the color cartridge...and BAM! it worked on both printers. solution...replace the color cartridge...cons..if this happens again its a waste of money to keep buying the colored ink...
Feb 03, 2009 | HP J4680 Office Jet All-In-One Printer
HP Deskjet 6940 not printing after replacing ink cartridge
My HP Deskjet 6940 is not printing. The color (left) low ink light is dark and the black (right) low ink light is flashing. I replaced the black ink cartridge with a new one but the low ink light continues to flash. No tears/rips in the circuit strip and all the copper leads appear to be connected
Sep 29, 2008 | HP Deskjet 6940 InkJet Printer
Error check ink cartridge
Hi ,
As per the information provided by you it seems to be a hardware issue however u cvan try these steps .
Steps >
Take out the ink cartridges from the printer > without turning off the printer unplug the power cord > press # and 6 key together , now without releasing the keys plug in the power cord .
keep on holding the keys down until the machine turns off automatically .
after the unit turns on again it would do the allignment give a msg for insert ink cartridges . insert the cartridges at that time . and see how it works out .
Thanks
MAC.
May 24, 2008 | HP OfficeJet 6210 All-In-One InkJet...
Problem printing with HP Business inkjet 1200
I have a HP Business Inkjet 1220 Printer, and the block ink cartridge light is flashing. I replaced the cartridge with a brand new one, closed the door, and black ink light is still flashing. I put in another neew black ink cartridge, closed the door, and same issue- black cartidge ink light flashing. I cannot print- what to do?
Oct 28, 2007 | HP Business Inkjet 1200dtn Printer
HP PSC 1315 All-In-One InkJet Printer Logo
23 people viewed this question
mukhtar21 shaikh
mukhtar21 shaikh
