Question about Microsoft Streets and Trips 2008 for PC
Registry settings for this application were not copied correctly
I have used this program for years without any problems, This is a Vista machine, theprogram was 2008 so i purchased the new 2009 version, installed as adminastrater and the exact same thing, even though it said it was successfully installed.
    Problem Solver:
  • 11 Answers
It was 2008-2009 thats why it said it i have a vista computer 2 mine did the same thing the version last up2 2009 2008-2009 thats why
Posted on Jun 04, 2009
Get the following error message: Your registry
If you are installing this on Windows 7 or 8 you will have to contact Microsoft directly. You can use Microsoft Technet or knowledge base to try to find a solution but I have found a bunch of this same error on their site and it appears to be a major problem.
I do know that the registry error is often a mistake and the program may run correctly after you reboot. This is a serious issue with Window 7.
Oct 15, 2013 | Microsoft Streets and Trips 2013 B17-00563
Tip
How to make your computer faster
1. Defragment your computer hard disk using free tools like SmartDefrag.
2. You should also defragment your Windows pagefile and registry.
3. Clean up hard drive disk space being taken up by temporary files, the recycle bin, hibernation and more. You can also use a tool like TreeSize to determine what is taking up space on your hard drive.
4. Load up Windows faster by using Startup Delayer, a free program that will speed up the boot time of Windows by delaying the startup of programs.
5. Speaking of startup programs, many of them are useless and can be turned off. Use the MSCONFIG utility to disable startup programs.
6. By default, the size of the paging file is controlled by Windows, which can cause defragmentation. Also, the paging file should be on a different hard drive or partition than the boot partition. Read here on the rules for best paging file performance.
7. In Windows XP and Vista, the Windows Search indexing service is turned on for all local hard drives. Turning off indexing is a simple way to increase performance.
8. If you don’t care about all the fancy visual effects in Windows, you can turn them off by going to Performance Options.
9. You can optimize the Windows boot time using a free program called Bootvis from Microsoft.
10. Clean your registry by removing broken shortcuts, missing shared DLLs, invalid paths, invalid installer references and more. Read about the 10 best and free registry cleaners.
11. One of the main reasons why PC’s are slow is because of spyware. There are many programs to remove spyware including Ad-Aware, Giant Antispyware, SUPERAntiSpyware, and more.
12. If you have a deeper spyware infection that is very hard to remove, you can use HijackThis to remove spyware.
13. Remove unwanted pre-installed software (aka junk software) from your new PC using PC Decrapifier.
14. Disable unnecessary Windows services, settings, and programs that slow down your computer.
15. Tweak Windows XP and tweak Windows Vista settings using free programs
16. Disable UAC (User Account Control) in Windows Vista
17. Tweak your mouse settings so that you can copy and paste faster, scroll faster, navigate quickly while browsing and more. Read here to learn how to tweak your mouse.
18. Delete temporary and unused files on your computer using a free program like CCleaner. It can also fix issues with your registry.
19. Delete your Internet browsing history, temporary Internet files, cookies to free up disk space.
20. Clean out the Windows prefetch folder to improve performance.
21. Disable the XP boot logo to speed up Windows boot time.
22. Reduce the number of fonts that your computer has to load up on startup.
23. Force Windows to unload DLLs from memory to free up RAM.
24. Run DOS programs in separate memory spaces for better performance.
25. Turn off system restore only if you regularly backup your Windows machine using third party software.
26. Move or change the location of your My Documents folder so that it is on a separate partition or hard drive.
27. Turn off default disk performance monitors on Windows XP to increase performance.
28. Speed up boot time by disabling unused ports on your Windows machine.
29. Use Process Lasso to speed up your computer by allowing it to make sure that no one process can completely overtake the CPU.
30. Make icons appear faster while browsing in My Computer by disabling search for network files and printers.
31. Speed up browsing of pictures and videos in Windows Vista by disabling the Vista thumbnails cache.
32. Edit the right-click context menu in Windows XP and Vista and remove unnecessary items to increase display speed.
33. Use the Windows Performance Toolkit and the trace logs to speed up Windows boot time.
34. Speed up your Internet browsing by using an external DNS server such as OpenDNS.
35. Improve Vista performance by using ReadyBoost, a new feature whereby Vista can use the free space on your USB drive as a caching mechanism.
36. If you have a slow Internet connection, you can browse web pages faster using a service called Finch, which converts it into simple text.
37. Use Vista Services Optimizer to disable unnecessary services in Vista safely.
38. Also, check out my list of web accelerators, which are programs that try to prefetch and cache the sites you are going to visit.
39. Speed up Mozilla Firefox by tweaking the configuration settings and by installing an add-on called FasterFox.
40. Learn how to build your own computer with the fastest parts and best hardware.
41. Use a program called TeraCopy to speed up file copying in Windows XP and Vista.
42. Disable automatic Last Access Timestamp to speed up Windows XP.
43. Speed up the Start Menu in Vista by hacking the MenuShowDelay key in the registry.
44. Increase the FileSystem memory cache in Vista to utilize a system with a large amount of RAM.
45. Install more RAM if you are running XP with less than 512 MB or Vista with less than 1 GB of RAM.
46. Shut down XP faster by reducing the wait time to kill hung applications.
47. Make sure that you have selected “Adjust for best performance” on the Performance tab in System Properties.
48. If you are reinstalling Windows, make sure that you partition your hard drives correctly to maximize performance.
49. Use Altiris software virtualization to install all of your programs into a virtual layer that does not affect the registry or system files.
50. Create and install virtual machines for free and install junk program, games, etc into the virtual machines instead of the host operating system. Check out Sun openxVM.
on Apr 06, 2010 | Computers & Internet
I want to copy a software from a dell laptop latitude d630 to a portoge m700 laptop . how do i do it?
If you mean how do you copy an application that's installed on one computer to another so it can be used there, the short answer is "you can't". An application needs to be properly installed using the original installation program supplied. Most applications put files into many different folders and you'd have to copy all of them. Also they make entries into the Windows Registry so the application is correctly accessible. Unless you get this information too, the application probably won't run at all.
If you just want to copy the data from an application - Word documents or data from a tax program, for example - you just have to copy that from the folders where it's stored. Many applications use the My Documents folder. Others create their own folders and provide a backup or copy utility in the application. Check the help information for your program for details.
Oct 18, 2010 | Computers & Internet
I am using Vista Premier. My Streets & Trips
uninstall. type regedit in run. In the left pane click HKEY Local Machine. Find Software and Click. Find Streets & Trips Delete it 'All". close the box. clean your drive. Restart & reinstall
Jul 30, 2010 | Microsoft Streets & Trips 2009 Full...
Microsoft streets and trips 2009 registry issues on vaio p588e/r
Hi, go to the "streets.exe" file in the program folder, right-click it and go to "Properties". Click the "Compatiblity" tab and uncheck "Run this program...". Try it now. It's what I had to do.
May 03, 2009 | Microsoft Streets & Trips 2009 Full...
Help!!
It may or may not be a virus. If it is a virus, it will NOT be easy to get rid of it. Download and run (free) SuperAntiSpyware:
http://www.superantispyware.com/?tag=GOOGLE-SUPERANTISPYWARE
or similar program.
Don't get your hopes up, though. Not that SuperAntiSpyware isn't a good free program, it will find it and remove it, but the virus is so vicious that most any spyware/antvirus program can't remove all of it. There's always that one little registry entry that can't be found. So, IF it is a virus, and IF SuperAntiSpyware or similar program can't get rid of it (it comes back after being removed), don't waste any more time! You'll need to erase your hard drive (using Sure Delete or similar program) and do a clean install of the operating system...of course, after backing up your existing files up first. Be careful not to drag the virus with you.
It may also just be a recently installed (or _uninstalled_) program that is messing up the works. If so, try uninstalling that program and use another similar program.
If you recently _uninstalled_ a program, you can try a registry cleaner. I use eusing.com's registry cleaner.
After all that, you will probably have to go to start>run>type in: cmd > type in: sfc/scannow (Have your installation cd ready.) to replace any system files that may have been damaged or deleted either by the registry cleaner or other "defective" software when it was installed or removed.
Additionally, (I can't remember what it is for Vista, so this is for XP, but should be similar in Vista) go to: start>settings(classic view)control panel>administrative tools>event viewer>applications
Post back any warnings you see (in full), as there may be a specific application that is causing the problem. That "problem" application may be spyware or a third party application that is not compatible with Vista.
IF you hold down the "Ctrl" and "Alt" keys and hit the "Del" key, select "task manager" info in there may help idenify the problem process or application.
Here's the Microsoft website for problems with Windows Vista:
http://support.microsoft.com/ph/11732#tab0
Try it, it may work for you.
Feb 13, 2009 | Microsoft Windows Vista Ultimate Edition
Your registry settings for this application was not
Hi
My personal openion is , by using just only Registry cleaners will not solve your problem
We need to get rid of every supported file.
so suggest you for
1) Uninstall the application
2) Restart
3) Use Regsitry Cleaners
4) After successfull cleanup of regsitry go into registry for manual removal by clicking Start -> Run --> Regedit
5) Now locate HKEY_LOCAL_USER -> Software ->
Here locate the application matches with the name of MS Streets (actually i have not used this, so i am not sure about the exact name, but i am sure that you will locate it)
And DELETE that key
6) Same is for HKEY_Current_User--> Software
7) Now go into System Drive (usually C drive) and locate the programfiles -> MS Streets
(again i have not used this, so i am not sure about the exact name, but i am sure that you will locate it)
And DELETE It.
8) Now restart the system
9) Now we need to use some JUNK FILE CLEANERS for get rid of other supported files
so i suggest you to go with Tune-Up Utilities 2008 version (its trial ware for 30 Day - Fully Functional)
so from that use your JUNK FILE CLEANER
10) After successfull clean up i incist you to execute the Defragmentation process on system drive (usually C drive) so that we can close the backdoor for support files.
11) So after doing all above MAINTANANCE then try to install the application once again
If problem persists.
Please let me know, then I personally get involved with this topic
Thanks
Sep 17, 2008 | Microsoft Streets and Trips 2008 for PC
Certificate File is missing in roxio
The following steps will completely remove any Roxio and Sonic software from your computer.
  1. Disable your startup applications using MSCONFIG. This will disable any unnecessary background or system tray applications from loading.
    • Go to Start -
Jun 25, 2008 | Roxio Easy Media Creator 7
Microsoft Streets & Trips 2005
Maybe if enough people come together and post our opinions they'll listen. Lets get everyone with these problems to post their problems. United we stand and devided we fall
Jun 01, 2008 | Microsoft Streets and Trips 2008 for PC
Microsoft Streets and Trips 2008 for PC Logo
577 people viewed this question
Top Microsoft Computers & Internet Experts
micky dee
Piyal Perera
Piyal Perera
Are you a Microsoft Computer and Internet Expert? Answer questions, earn points and help others
