Question about Kenmore 3.8 cu. ft. HE3t Front Load Washer
My cloths don't come clean.....whites are dingy even with bleach. Normal stains on regular colors don't come out. If you put more than one pair of pants or two long sleeved shirts in a load they come out tangled in knots.
    Problem Solver:
  • 8 Answers
First I would start by cleaning your washer system with vinegar. Ran your machine like you would without clothes and pour a cup of vinegar like you would with the soap for a whole cycle. If this doesn't work chances are your drain is clog or your pump isn't working properly.
Posted on Jun 05, 2009
Bleach stains on black jeans
Bleach doesn't stain ! it removes the dye from the fabric.
I would suggest trying to re dye the fabric with a black dye as Jeans material might be more successful .
Synthetic fabric is not as easy to re dye end up using a permanent black marker on Synthetic Shirt that I got bleach on. .
Mar 12, 2014 | Clothing
Remove bleach stains
I don't think you're going to get bleach stains "out". The bleach has removed the tanning in the leather and it's not coming back. Have you tried polishing them with the same, or similar colored shoe polish like Ki Wi (sp?) shoe polish? if not, maybe a cobbler can tan them with products he has?
Mar 11, 2014 | Clothing
Kenmore calypso washer bleach
I would take the bleach hose off and verify it is not obstructed, if that doesn't look bad then the system that calls for bleach my be faulty, but I would check for obstructions first in the hose first.
Jan 15, 2014 | Whirlpool Washing Machines
Why does my washing comes out with stains on it.... they weren't there when it went into the wash...
yes sometimes ink pens can be washed when we are not aware it was in someones pocket. I use straight ammonia and a cloth to clean my washing machine drum a couple times a year because these things have happened to me before. The ammonia will cut the grime and pen stains out of the drum. Then take a squirt bottle and fill it with white vinegar and squirt all around inside the drum of the machine. Run a wash without any clothes with the hottest water to clean the drum and clear out the stains. Do this to the dryer also and clean out the filters. Take the dispensers out from the washing machine and clean those too and your cleaning is done for a while. Apparently the ink has been in the drum of your washing machine and putting the color into your clothes. You can bleach out the white clothes that turned blue. Use the stain remover for colored clothes. Hope this will help you.
Feb 01, 2011 | Whirlpool Washing Machines
I have a Michael Kors watch with a white rubber wristband that has turned dirty and dark in less than a year. I am quite unhappy with how it looks, but very happy with the watch. What to do???
Thanks for contacting FixYa.
  1. The easiest thing to try is a regular pencil eraser. It's perfect for removing marks and smudges from rubber and works like a charm! Use white erasers as the pink ones may leave pink smudges.
  2. If a regular pencil eraser doesn't work, try a Mr. Clean Magic Eraser or similar product. Simply moisten the sponge and rub it over the stained area.
  3. If that doesn't do it, grab your safety goggles and move on to the next step.
  4. Mix four parts water with one part bleach in a cup or small bowl. You will need less than ¼ cup of the finished solution, so only mix a small amount.
  5. Wearing eye protection, moisten a white cloth with the mixture. Do not use a colored cloth. You will likely transfer color from the cloth to the watch band and make your problem worse.
  6. Carefully dab the bleach against the stain on the watch band. Don't over apply the bleach or leave it for more than a few seconds or you may damage the rubber.
  7. If needed, increase the strength of the solution by adding a bit more bleach. Do this in small increments to expose the rubber watchband to as little bleach as necessary.
  8. Blot and repeat as necessary if you see improvement.
  9. Once the stain is removed, rinse the band well with water to remove all the bleach residue.
  10. If the stain remains, mix the Rit Dye Remover with a small amount of water to make a paste.
  11. Spread the paste onto the stained area and allow it to set for a minute.
  12. Rinse with water and dry with a soft cloth.
  13. Repeat if necessary.
Additional Tips and Advice
  • Once you have the band clean, treat it with Armor-All wipes made for vinyl car interiors. This easy tactic will help protect the band from stains and smudging. Repeat every few weeks for maximum effect.
  • Be careful with acetone on rubber watch bands. It can start to break down the rubber and make the band feel "sticky." Once done, this can be difficult to reverse.
Best regards.
Jan 31, 2011 | Fossil CH2331 Wrist Watch
Whites are dingy. Random stains appear on my husband's dress shirts that weren't there when I put them in the wash. We have a water softener; don't know if that plays into the problems. Please help!
Put washer through a clean cycle with bleach only. Check to be sure you are using HE soap. Check the bellows(door seal) make sure it is not jamming clothes.
Oct 29, 2010 | Whirlpool Duet GHW9150P Front Load Washer
Dingy Clothes
What is the answer for dingy clothes? I have the same problems and I'm getting ready to get rid of this washer because I'm tired of not getting clean clothes and having my towels smelly after taking them out of the washer.
Oct 03, 2009 | Whirlpool Duet GHW9150P Front Load Washer
Dingy whites
smaller loads - so articles arent drawn to the hole.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question.
Jul 10, 2009 | Whirlpool Calypso GVW9959K Top Load Washer
I live in the country in NC. My water is well
For brighter, softer, stain-free clothes, add 1/2 cup Arm and Hammer® baking soda to your regular detergent in the wash cycle, then add 3/4 cup Heinz® white vinegar to the rinse. Soak really dingy clothes for ten minutes in the baking soda-detergent mix before washing in the hottest water fabric will accept. Vinegar smells should vanish after clothes have dried. Many online voters said that this worked best.
Jun 30, 2009 | Fisher and Paykel GWL11 Top Load Washer
White Clothes even with bleach and hot water don't get clean???
i have used everything to solve this exact problem!  I have to say the best detergent or bleach i have used in the lg..is the purex with bleach for colours it seems to work better than anything ive used...spent a fortune to have to soak my whites before putting them in this washer.  I must say im disappointed..
May 06, 2007 | LG WM1814CW Front Load Washer
Washing Machines Logo
308 people viewed this question
Sal De
fordexpert
Jim Goldsmith
Jim Goldsmith
