Question about Black & Decker 14" Grass Hog Xp Trimmer/Edger
How can I remove the old spool kit from a grasshog xp1000? I have a new one to replace it but can't get the old one off.
After removing the screw, I had a heck of a time pulling off the old spool kit. I ended up running a rope through the holes that the cap clips into, stood on the rope and pulled up on the Grass Hog. Finally I managed to pull the old kit off. I managed to put the new one one, but I'm not 100% sure whether the cross-shaped piece at the bottom of the post is perfectly lined up with the new spool head. I was able to replace the screw and so far it seems ok.
Posted on Aug 16, 2012
Replacing the spool of string for my black and decker 12v electric trimer ? grasshog model
If it is the same as my old 12V version, flip it over and look at the bottom, this is the cap for the string, on the sides there are two push button latches, depress and pull the cap off. Then reach in and remove the old spool. Insert the new spool with the circular sawtooth design to the inside and push the end of the string through the hole in the side. Replace cap ensuring that both latches engage.
Jul 08, 2011 | Black & Decker String Trimmer Cordless 12"...
Need to replace the wirefeed? Purchased 8" orange
Hi gramcherry1...
1 Press the lock and rotate the spool counter-clockwise or some will remove the center knob.
2 Remove the locking ring if your weed eater has one.
3 Take off the automatic feed button.
4 Wipe away any dirt and debris.
5 Push down on the spool to release the locking tabs.
6 Remove the spool from the chamber.
Restringing the Weed Eater
1 Feed one end of the line into one of the holes of the spool, and secure the end that was inserted
2 Wrap the line in the direction of the arrows. Do this until until you fill the spool up with line.
3 Secure each of the lines into its own upper and lower grooves.
4 Re-install the spool into the chamber from which it was removed.
5 Pass the lines into the left and right holes and snap the spool into place.
6 Once the spool is in its sleeve and fed into its left and right eye holes, pull both ends simultaneously.
7 Reinstall the locking ring if necessary, reinstall the center knob.
Please take time to rate me
Jul 03, 2011 | Black & Decker Grasshog 12 Inch 18 Volt...
My grasshog motor runs but the spool does not rotate. Please tell me if this can be fixed or not
It probably can be fixed. You may want to see what is wrong before you do anything else. Look to see if something has been wound around the spool. Check to see if the cable may be broken. If it is the cable you want to see if the fix is more expensive than a replacement. Good luck...Lee
May 29, 2010 | Black & Decker Grasshog 12 Inch 18 Volt...
How to replace line on the double sided spool for my grasshog
HOW TO REPLACE LINE, PLS CAN YOU SHOW ME FROM THE PICTURES.
Oct 14, 2009 | Black & Decker 14" Grass Hog Xp...
My Balck&Decker Grasshog won't automatically feed line.
Just replace the LEVER, Item #29, Part #598435-00, for about $3.00 (B&D, Dewalt). Just pull old level straight out (pliers) and push replacement in. Level end expands to hold it in place. No other parts. Forget cleaning and replacement the spool, graphite or oiling... just replace the lever.
Aug 24, 2009 | Black & Decker 14" Grass Hog Xp...
How do I refill the spool with new cord. the whole towns out of the refills. I bought new line, but cannot figure out how to wind the cord onto the black thingy. Its a dual line feed.
The grasshog xp takes .080 heavy duty line, do not use any other grade other then .080!
First remove the orange cap by depresssing the two buttons. Next unscrew the screw and remove the tumbler. You'll want about 50' of line for each of the two spindle slots. Start on the spindle closest to you by inserting about an inch of line into the hole in the base and statr winding it snugly in the direction as show on the spool, take your time and do it nice and neat and the line will last you longer then if you rush and do it sloppy. At the end leave about 6/8 inches and temporarily fasten the end on one of the nitched holders. Start the inside spool from the opposite end that you started the other and repeat the same. Once they are both spooled and temporarily fastened at opposite ends from each other reattach the spool onto the edger, fasten the screw in place and un fasten each end at a time inserting the line through the wholes each on oppoing sides. Then reinstall the safety cap and you are done! For taking 15/20 minutes and 1/4 the cost of buying a new spool and saving throwing the old spool away it is well worth it =)
Jul 15, 2009 | Black & Decker 14" Grass Hog Xp...
I need directions to replace string on black and decker cordless 18v grasshog
Go to home depot. look at the floor model and the replacement spools they sell there. Reverse engineer the stringing process or but a pre-loaded spool.
Otherwise,
1. Squeeze the tabs on the side of the head of the unit to remove the spool cover.
2. remove spool.
3. place end of string in small hole in center ring of spool.
4. wide spool with string in the direction of the arrows printed on the spool. DO NOT OVERLOAD!.
5. snap string into notch on spool and cut string leaving 6" exposed.
6. thread 6" of string through hole in side of unit head, replace spool, and replace cover.
7. go cut grass.
Jul 07, 2009 | Black & Decker String Trimmer Cordless 12"...
Black & Decker 14" Grass Hog Xp Trimmer/Edger Logo
362 people viewed this question
Top Black & Decker Garden Experts
Nick Olsen
Roland W VanLue
Roland W VanLue
Tim Whalen
Are you a Black & Decker Garden Expert? Answer questions, earn points and help others
